Replacing 1 device for 2
Doing something backwards here....and I won't go into my reasoning.
I'm replacing a ZSE11 quad sensor with a zse44 (temp/humidity) and Zen11 (motion/illum).
I have my zse11 connected to various tools. Some of the attributes to Rule Machine, others to Dashboard tiles.
Is there a way I can, during inclusion of my ZSE44 tell it to replace all Temp and Humidity attributes of the ZSE 11 and also while including the Zen11 tell it to replace the motion/illum attributes?
I don't think there is, but before I go through all the manual pain in the butt...wanted to ask.
I know there is a full device swap feature, but I've never seen any option for an attribute replacement.
No way to do that directly. Your best bet is to pick the one that gives you the most automatic matches and then manually address the incorrect ones.
Thanks....this was what I was thinking. Such a rare situation to have HE make a feature for that.
Rules broken when you delete a device are a) easy to find and b) easy to fix.
I would recommend you try try swap with dashboard device and let rules break.
Very good point!!! Thank you!!!
