I'm seeing logs like this for my Iris motion sensor using the built in driver:
2018-11-30 10:52:26.970 am infoMBR Motion Sensor by Door (Iris 2) temperature is 62.08°F
2018-11-30 10:52:17.939 am infoMBR Motion Sensor by Door (Iris 2) temperature is 62.08°F
2018-11-30 10:52:09.989 am infoMBR Motion Sensor by Door (Iris 2) temperature is 62.08°F
2018-11-30 10:51:59.890 am infoMBR Motion Sensor by Door (Iris 2) temperature is 62.08°F
2018-11-30 10:51:50.821 am infoMBR Motion Sensor by Door (Iris 2) temperature is 62.08°F
[dev:397](http://192.168.13.46/logs#dev397)2018-11-30 10:51:41.788 am [info](http://192.168.13.46/device/edit/397)MBR Motion Sensor by Door (Iris 2) temperature is 62.08°F
Any idea why it would do that? Is that a zigbee issue? I've seen this with other devices but starting with this one as it's a built in driver and pretty common device.
I've seen the same issue, here is a contact sensor that had two open messages before the close message. I know the door was opened and then closed only once. It causes headaches with my rules if the door is opened and closed in a couple of seconds and then the second phantom open message comes in and I start getting alerts. I've seen it with Iris, NYCE, and Visonic sensors,
dev:1692018-11-30 10:37:39.319 am infoGarage Refrigerator Door Sensor was closed
dev:1692018-11-30 10:37:28.053 am infoGarage Refrigerator Door Sensor was opened
dev:1692018-11-30 10:37:22.543 am infoGarage Refrigerator Door Sensor was opened
Iris motion devices only report the temperature when it actually changes; they do not do it on a non-adjustable firmware built-in schedule. This is what a normal report should look like:
I have XBee and Smart Outlets for repeaters, I've tried new batteries, healing the mesh, rediscovering the devices, and turning off everything else that is on 2.4 Ghz in the house but I still have the problem.
