Nah, gives me an error message within the rule setup.
Oh, I thought the END-IF after END-REP... Because then I get this:
And does this even work? Because I was basically following the instructions on the documentation page, for the Repeat Until loop:
Think of the repeat and end-repeat, and the if and end-if as containers. You have a big box on the outside and a smaller box on the inside. You can't have a box half inside the other box and half outside, the small box needs to be completely closed inside the big box before you can close the big box
"Basically," yes, but not quite. The instructions use a simple conditional, not a "full" conditional (IF expression THEN
). A simple conditional acts only on the action on the same line as it and doesn't need (in fact, cannot have) an END-IF
, which is why you don't see one there but do see one suggested to you (in the correct place) above.
Also, those examples take advantage of the fact that a simple conditional on a Repeat action has a sort of special meaning, stopping then repeat when the condition is no longer true. In Rule 5.1, you can do this in a bit more intuitive fashion with a "Repeat while" plus your condition/expression.
Some of those examples, IIRC, do use a full conditional along with a "Stop Repeating Actions," which can work too--as long as your repeat is marked "stoppable." But they were alao written for Rule 4.x, where there were fewer options.
I don't fully understand why you are triggering off humidity but it seems as though you want to trigger this off the window opening. You're doing this by triggering off humidity then waiting for the window to be opened for 5 minutes. This could be one second after the humidity trigger or one year, who knows? My preference would be to structure this rule to trigger on the window then check humidity as a condition for the notification.
Thank you both, for the explanation. Now, I get it. I'll change the rule this weekend and give you feedback.
Oh, yeah, I see the confusion. Sorry, I didn't explain it enough. This rule serves the purpose to remind me to close the window, so far so obvious. In my bathroom, there are two instances why the window is open.
Someone took a shower/bath, so the air humidity is very high, and needs to be reduced to prevent mold.
Someone had a No. 2, so the methane level is very high, and needs to be reduced to prevent burning in the eyes and noses of everyone else living in the house.
Using just the open window as a trigger, with all the waiting etc. would just help with instance No. 2, but not the humidity. That's why I choose humidity as the trigger and the open window as a required expression. This is giving me the advantage, that if someone just used the toilet and opened a window, the rule would fire right away, because the humidity is already low enough. On the other hand, if someone took a long hot bath and would open the window, the rule is waiting until the humidity is low enough.
Trust me on this, the rule basically works wonderful on this instance, just the over repetition was the problem.
I get what you're saying here but your rule is triggering for every change (report) of humidity < 60. Wouldn't the rule trigger less if you trigger on the window being open and waited for humidity like this?
Wait for Expression: Humidity of Humidity of Temperatur... is < 60 --> duration: 0:05:00
I get your concern, but with the change you are suggesting, it will fire up just as often. As long as the window isn't open, nothing is going to happen any way, because the required expression is false.
@Vincent_The_Staat Your approach is different than mine but I appreciate the discussion. Just shows there is more than one way to achieve the desired result. You've given me some ideas that I'm going to try out.
That's great to hear. Please let me know about your projects. I'm always looking for new ideas to tinker with, myself.
