I have a rule for my ceiling fans to run them every half hour for 5 minutes. The bedroom fan has a MR101Z with its notoriously weak radio. On occasion (like once every 100 times or so) it misses the turn off command and stays on all day, despite having 2 zigbee outlets in the room pretty close to it. I would like the rule to refresh the status and make sure it turned off. I'm not sure how to achieve that.
Here is my current rule setup:
IF (Master Bedroom Fan is off AND
Mode is Day, Away) THEN
Set Fan Speed: Master Bedroom Fan to low
Delay 0:05:00
IF (Master Bedroom Fan is low) THEN
Set Fan Speed: Master Bedroom Fan to off
I set it up to be triggered at minutes 0,30. This way if we're using the fan it will not run and leave the fan as is. And if we change the fan speed while it runs, it doesn't turn it off.
