Repeated error logs on Sengled and Zigbee bulbs
I am getting these errors below repeatedly on my Sengled colour bulbs (about every 40 seconds) and other Zigbee bulbs. I have tried unpairing and re-pairing the bulbs and running configure but they still log the errors. Is there something i can do to shutoff or fix the errors?
org.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: colorPlus.connectDevice() is applicable for argument types: (groovy.json.internal.LazyMap) values: [[firstRun:false]] (method connectDevice)
dev:5832023-09-09 10:11:40.112errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: colorPlus.connectDevice() is applicable for argument types: (groovy.json.internal.LazyMap) values: [[firstRun:false]] (method connectDevice)
dev:5822023-09-09 10:11:40.086errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: colorPlus.connectDevice() is applicable for argument types: (groovy.json.internal.LazyMap) values: [[firstRun:false]] (method connectDevice)
dev:5812023-09-09 10:11:40.059errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: colorPlus.connectDevice() is applicable for argument types: (groovy.json.internal.LazyMap) values: [[firstRun:false]] (method connectDevice)
dev:5802023-09-09 10:11:40.035errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: colorPlus.connectDevice() is applicable for argument types: (groovy.json.internal.LazyMap) values: [[firstRun:false]] (method connectDevice)
This appears to be an issue with the device driver.
Which driver are you using? Did you install a user (community) driver for this or are you using a system (built-in driver)?
You can find details on the Devices page in the "Source" and "Type" columns (or on the device detail page in the Device information at the bottom of the page).
I’m using the built in Sengled Element Color Plus driver, the Advanced Zigbee RGBW bulb and the Advanced Zigbee CT bulb drivers depending on the bulb manufacturer. They all log this error.
Out of curiousity has the bug been found?
