Hi,
I'm planning to create 2 x repeats functions; seems there is no way to do so in Rule Machine? (I'm using Rule Machine 5.0).
The plan is to repeat every 2 hours and inside that repeat, to repeat for every 5 seconds.
Hi,
There is probably a reason for this restriction but I get around it by using the Run Actions command:
Here is my panic button rule:
...and my Sub Flash Lights Red rule
Note:
I prefix my called Rules with no triggers with Sub for clarity.
Yeah, nested repeats are not allowed. But as @UKMedia advises, you can put the inner repeat in a separate rule, and run it from the first rule. That second rule would not have a trigger event. It's just sort of a subroutine for the first rule.
