Hi!
Has anyone already tried to use repeat for the false action? for true it works correctly, but in my case, I need to test false and repeat do not work.
adds only once +1 although the rule status in the logs is false and repating.
Hi!
Is it the repeat when false or is it the adjust thermostat temp repeating. Not sure why you would do that with a thermostat? Have you tried repeating other actions in false or tried repeating that action in true?
