Repeat actions while holding button
I just picked up a couple wiz rgbw bulbs to replace my cree connected that I have on our nightstands in the bedroom. I was hoping they would have a more gentle start. The cree bulbs don't dim down very far and I wake up rather startled. Still working the kinks out, I think I'm on the right track. They jury is still out if they will stay.
These bulbs do not work with start and stop dimming commands. They do however respond to adjust dimmer. Right now set the dimmer to adjust +/- 10 when my remote button is held. Is there a rule timer that can do repeating actions while the button is held rather the repeating the hold button several time to get to the desired level?
APortman
You could add this to your button rule:
While button X is pressed, repeat 10 times every 1s
Dim up by 10
end-rep
And dim down by 10 for the other button
You could do something like this in Button Controller
Button 1
Held
Repeat 10 times every 0:00:05
    Adjust: Cree +10
END-REP
Released
Cancel Timed Actions: button 1 held
This worked perfectly. Thank you very much.
