Renaming Tile Changes The Name On Another Tile
I've created a number of new Easy Dashboards and have to say I'm impressed!
I do, however have a problem with any device name that was created via the 'Create Duplicate Tile On Save' checkbox on the tile editor screen for individual tiles. I have a device which is a combination smoke/CO detector. After adding the device to an Easy Dashboard, I was able to either select Smoke or CO in the Tile Type drop down. I used the above mentioned checkbox to duplicate the tile, and in that tile I selected the other Tile Type. I then attempted to rename the tiles so the CO tile read CO in the name and the other Smoke for the Smoke Tile Type. However, changing one name, changes the other tiles name to the same name. Also the icon is the same for both Tile Types, so that indicator is of no help.
I have tried renaming in both Firefox and Edge with the same results. The OS is Windows 11 Pro, Hub version 1.3.9.150.
Am I missing something?
Confirmed issue, you can expect a fix in the next release. Thanks for your feedback.
Thanks Bobby for the quick response. You guys are awesome!
Tested and still present in 2.3.9.153.
Please note that 153 is not publicly available, yet. It's currently in beta. This behavior isn't changing in the next release but we added a tooltip for clarification:
