I don't see anywhere to remove the label from a tile. Is this possible or a planned feature? Some tiles like Super tiles could benefit from removing the label.
You can already remove the template name from the top of the tile (a switch in options)
With supertiles, the name at the bottom of the tile is the display device name so can be set to whatever you like (as the device label)
Andy
If you mean removing the template label from the top of a normal Dashboard item, you click on the gear icon, select the Options tab, then select " Hide Tile Template Names".
Edit: And beat by the Cobra as I was typing... fast to strike.
I meant the label at the bottom of the tile which is OK when the tile is a switch or dimmer etc. With a supertile I have all my temperature readings on one tile and don't really need the label of the tile at the bottom. On my mobile the labels font is twice that of the font created in the super tile.
WHat I have foudn however is change the super tiles name in devices to _ which at least makes it look better but not perfect.
Unfortunately, supertile cannot change this font
The saving grace is the _ character seems to work OK. Hopefully hubitat puts an option to remove the label for a tile in future
