Removing a Zigbee device - ZBMini
I haven't had to remove a zigbee device in a long while, so wanted to check if there are any "bad" things that happen if I do it with the "remove" button from the device page? The device is no longer powered (it was a switch had went bad during the installation process), Thanks for your help.
Not with zigbee. You can remove it and move on with your life.
If any devices were using it as a repeater (which sounds unlikely in your case), they’d eventually find another route to the hub on their own.
