The driver from @a4refillpad for the IKEA blinds has been working great. Is there a way to modify the driver so the logs aren’t flooded with DEBUG comments? These blinds report quite often and the majority of the reports are DEBUG.
Here is a snippet from this morning of a 30 minute window
Not sure exactly what driver you're using (a link to a post with it or at least the code itself is always helpful), but from a quick search based on a guess and looking at that code: you should just be able to turn off the "Enable debug logging?" option on the device if you're using the same driver I found. (The same way it works for most drivers, except this one doesn't appear to auto-disable after install or enabling.)
