Remotetek scene master not registered after zwave Js flip
Hi there,
I have changed my c8pro to zwave js and one device that will not register is remotely scene master. I have tried demoting battery etc but still will not register, could this be driver stack issue ?
https://manual.zwave.eu/backend/make.php?lang=en&sku=B_REMEZRC90
Could try:
http://<Hub IP Address>/hub/zwave2/reinterview?node=<0x9999>
After running command i got error 500 (i have changed hub ip address correctly)
http:// Hub IP Address /hub/zwave2/reinterview?node=0x00c8
I have again rolled back to traditional zwave stack until this matures. For reference i have tried removing and adding battery, waking the module and even re-adding the unit, none of which worked
