Remotec ZRC90 multiple button press actions from single press
I have noticed in the event log for one of my Remotec ZRC90 remotes that sometimes it is recording several button presses for a single press as example below:
pushed 1 Bed 1 Remote button 1 was pushed DEVICE physical 2018-11-30 11:41:06.768 AM GMT
pushed 1 Bed 1 Remote button 1 was pushed DEVICE physical 2018-11-30 11:41:06.694 AM GMT
pushed 1 Bed 1 Remote button 1 was pushed DEVICE physical 2018-11-30 11:41:06.636 AM GMT
pushed 1 Bed 1 Remote button 1 was pushed DEVICE physical 2018-11-30 11:41:06.530 AM GMT
pushed 1 Bed 1 Remote button 1 was pushed DEVICE physical 2018-11-30 11:41:06.514 AM GMT
pushed 1 Bed 1 Remote button 1 was pushed DEVICE physical 2018-11-30 11:41:06.365 AM GMT
pushed 1 Bed 1 Remote button 1 was pushed DEVICE physical 2018-11-30 11:41:06.273 AM GMT
pushed 1 Bed 1 Remote button 1 was pushed DEVICE physical 2018-11-30 11:41:06.190 AM GMT
pushed 1 Bed 1 Remote button 1 was pushed DEVICE physical 2018-11-30 11:41:05.886 AM GMT
pushed 1 Bed 1 Remote button 1 was pushed DEVICE physical 2018-11-30 11:41:05.874 AM GMT
I use the button to toggle a lamp so it's causing a bit of freeze when it happens and sometimes the lamp finally turns off and then on again or vice versa.
I have changed the batteries, even though they were at 90% but it made no difference. It seems to do it more when it is on the outer edge of the Zwave mesh. Does it keep sending the command until it gets a response? I thought it might be a physical problem with the actual button, but as it improves nearer the hub that seems unlikely. Do battery powered devices still use the full zwave mesh or do they have to be in direct range of the hub? Any other thoughts?
Not sure what the issue is but I would imagine the weaker the signal the flakier the device will be.
If you are moving the device to different locations ensure you do a zwave repair before testing each time. This way the controller finds the best route back to the hub.
Whenever I do a Zwave repair the nodes for these remotes don't get included. That's why I wondered if battery powered devices have to be in direct connection to the hub.
I may not have noticed it before because none of the buttons were previously set to toggle a device so it wouldn't have changed behaviour if commands were sent multiple times. But looking at the live logs, one button press on one of these remotes can result in commands still being received minutes later see below. Something is wrong here surely @bravenel or @mike.maxwell ? Edit - using standard built in Remotec ZRC90 driver btw
dev:10272018-11-30 01:28:23.330 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:28:23.273 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:28:22.902 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:28:19.379 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:28:05.072 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:28:01.914 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:28:01.342 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:28:01.327 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:28:01.063 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:28:01.000 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:28:00.762 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:28:00.626 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:59.920 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:59.505 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:59.097 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:33.377 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:28.363 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:27.472 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:26.856 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:26.844 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:26.767 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:26.745 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:26.733 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:26.661 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:26.364 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:19.934 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:19.661 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:19.339 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:19.138 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:19.101 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:19.094 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:18.926 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:18.454 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:17.656 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:08.601 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:05.957 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:05.852 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:05.189 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:05.110 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:05.107 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:04.604 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:27:00.926 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:56.908 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:55.421 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:52.752 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:52.525 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:52.284 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:52.272 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:52.155 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:51.852 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:51.269 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:51.156 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:51.065 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:50.807 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:50.769 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:50.472 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:48.183 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:42.470 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:42.431 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:42.063 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:41.833 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:37.125 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:34.060 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:32.084 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:29.655 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:27.401 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:27.293 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:25.994 pm infoBed 1 GT is off [digital]
dev:10272018-11-30 01:26:25.872 pm infoBed 1 GT was turned off [digital]
