Are these not Z-Wave + ???
It's fine if I refresh but otherwise it does NOT update the HE status when I operate the front button.
Anyone else with this issue?
They are z-wave. So, you have to use the built in app, z-wave poller.
It does not show up in βpollerβ
What driver do you have assigned to the device?
The built-in "Remotec ZFM-80" driver
You got me stumped then. I would email support@hubitat.com
This will be fixed in platform release 2.1.0
Thanks @mike.maxwell!!
My Remotec ZFM-80 is being controlled correctly but its status in Hubitat is always displayed as 'on', even if it's off.
How do I go about fixing this?
Thx
I too have the same problem, it's not changing the status to "off" ever since I switched to c8 from c5 a couple of weeks ago. Is there a workaround to fix that?
Thanks.
@mike.maxwell this issue is still prevalent
This is related to the actual Z-Wave chipset, if I recall its using a command that's no longer supported by the firmware itself, I don't remember the specifics, but this is a very old device unfortunately.
