It's possible I forgot a step here but I'm unsure. I have the remote hub subscription. I go to my.hubitat.com > registered hubs and it finds my hub. However it says the firmware is incompatible and that I need firmware 2.2.6 or later to Connect to Hub. However, I can view the hub details and it reports the hub is active and that I'm running 2.2.7.126. Am I missing a step?
I had this yesterday when using android app. Killed the app & relaunched to try again, was then OK.
Suggest you Force close your browser, so it closes down completely, wait a few minute & try again. If that does not work then sorry I've no ideas.
Good luck
Hmm. I tried that and cleared my browser data... and still doesn't work.
But you're right it is a browser issue because I can launch Edge and login just fine. Something in Chrome is causing the issue.
