I have two hubitat controller coo and c7 in mesh I configured one zwave remote Keyfob in c8 but I need to control some other device through key fob in c7 controller how can it be done? I already shared the device with c7 but at logs there is no event
Hi, I can control at my C8 the controller where I paired the remote.
I shared the device with C7 and I can see the device. But at C7 log there is no data and when I press button of keyfob for action defined it doesn't do anything.
The C8 is in another level far appart so C7 and C8 is connected is same ipv4 network C8 cannot see the keyfob when Im near of C7
The fob will only be bound to 1 hub. What this means is that the radio signal will only go to that hub, NOT the other hub. So if you move it towards the c7, the signal will be much weaker.
