@support_team I am having a similar issue as (https://community.hubitat.com/t/remote-admin-not-working/97132)
I have an active subscription for Remote Admin however the remote access is not available. My Hubitat is running 2.3.2.141. I can access the hub via remoteaccess.aws.hubitat.com
However when I check the Registered hubs it does not show that I have an active subscription.
Got it! Thank you. I don't see any issues with your service or subscription. Mind sharing a screenshot of your Registered Hubs page? The service is active and functional, or else you wouldn't be able to access the hub via remoteaccess.aws.hubitat.com. The one time reboot may be needed if the service is not active on the hub, but that is not your case.
Thank you. Interesting. There seems to be a problem with my.hubitat.com not reflecting the correct status of your subscription, however the service is working properly. Will need to further investigate this problem, but for now, please use remoteaccess.aws.hubitat.com.
