I am reminded that "where it really matters", and in situations of inaccessibility -
redundancy of sensors & repeaters is important and worth the $...not only for unit failure, battery failure(buy the best), but also for a cross-check;
e.g. is that temperature that seems to be anomalously high, or that motion, corroborated by another sensor of the same type, or even better, a different type?
As he types in the wee hours of the morning after being woken by a motion sensor triggering in an outbuilding, ...not by a person but... likely by a mouse that climbed higher than he/she was expected to.
well I have tried and tried to get the 8226 flashed with konnected tried 3 different wires 2 different boards 2 different PC's . I have installed the V1 drivers as stated in the instructions.. All I get is a spinning wheel
Hi @johnr ,
I am on the lookout for a new outdoor temp senesor. Any thoughts to report back on the Sensitive strip after using it for a couple of years? I also wondered if the Sensetive strip sends readings with reasonaly regular intervalls?
As a temperature sensor it works fine. I would save it reports between in average between intervalls between 45min - 1h 30min depending on how the temperature changes.
The negative things about this sensor:
There is no optimized driver for it. Using the the generic temperature driver will not display the lux value.
The humidity readings are not reliable, right now it has showed 100% humidity for two weeks, by other sensors shows around 70%.
