[Released] Rule Machine 3.0
@bravenel a while ago i wanted a conditional action repeat but I had set up wrong as i was told the actions IFs done get evaluated so esentaly it would run forever. So stop on truth change had to be the main conditions truth change correct?
but in the documentation it says this
A Repeat Actions, like any action, can have a condition specified. If the condition is false, the Repeat Actions block of actions will not be executed. If the condition becomes false during repetition, the repetition will be stopped (not in the case of Repeat a selected number of times). This provides three features well known to computer programmers; A while-loop, a for-loop and repeat-until loop. The while-loop runs only if the condition is true, and stops if it is false. A for-loop runs for a fixed number of times, but if a condition exists, it will only start that iteration if the condition is true; the condition is not retested during iteration. A repeat-until loop runs until a condition becomes true, running at least once.
While loop - repeat while the condition is true:
IF (condition) Repeat Actions
     some actions...
End Repetition
which to me states otherwise that if the IF (condition) changes to false it stop. no mention having to tick stop on truth change eather. Is it that whatever the condition is it would have to also be a condition in the main part of the rule even if its not in the rule defined.
