I still have some too. On the advice of the master, I simply don't fix what isn't broken. Have to admit to being a bit apprehensive, despite understanding the conditional logic introduced in RM 3.0
As it turns out, it's not really difficult to wrap your head around at all. It just takes some adjustment away from old habits. I converted a few multi-rules into a single 4.0 rule and it all went well. I found a few just didn't make the situation any better to convert them, and some are just single conditions/actions that just would make no sense to spend my time converting.
I'm sure I'm going to screw up a few where I needed private boolean but didn't include it, but that's just part of learning.
Is this a bug? I created a rule, and it just had that first if-then-endif statement. Then I went back to modify it to add a couple of more doors, and that second IF statement appeared and I can't get rid of it without deleting the whole rule.
In this circumstance, if you were to click on Done with Conditional Action before clicking on Done with Condition, it would leave the rule in a weird incomplete state. If you then open the actions again, it will likely misbehave.
The fix for this is that lower row of buttons should not be available until after Done with this Condition is clicked on. I can't be sure this is what happened to you, but it could be something like this.
I was trying to add a new conditional actions event to ensure my push notification happens every 10 mins until the contact is closed and get this error
It looks like you didn't complete your condition or backed out before adding one. If you go back in and edit that condition to add something, then you can delete it.
Is it possible for multiple lines of (separate and not conflicting) IF statements to be true and run simultaneously?
IF condition 1 (TRUE)
IF sub-condition 1.1 (TRUE)
THEN do action 1.1
ELSE do action 1.2
END-IF
IF condition 2 (FALSE)
IF sub-condition 2.1 (TRUE)
THEN do action 2.1
END-IF
IF condition 3 (TRUE)
THEN do action 3.1
ELSE do action 3.2
END-IF
Will actions 1.1 and 3.1 be run by the rule, if the rule is triggered in some manner?
Edit: For anyone wondering, it will run multiple complex IF statements.
A request. Is it possible to have logging levels modified slightly? At present, it seems to be all or nothing (despite the 3 logging options). With Rule 4 (great job btw), it seems that we will be having larger and more complex rules. And I want logging only if there is a change. There is a LOT of skipped in the logs with logging enabled! A lot.
What I'd like is for anything that is skipped to not log, but for anything that is actioned/done to be logged. I tried actions but it includes skipped actions as well, and when I disabled actions, there was only the trigger in the logs. I thought events might work, but I dont think that logged anything in my particular rule.
Trying to set one dimmer to the colour of another dimmer. How to do that in Rule 4?
Also, in attempting to do that, I found a bug. Capture device (dimmer) causes the page to crash with no "done" button to press. The device selected does not carry forward to next screen, and "cancel" is the only option.
No, you don't have to add an END IF before the ELSE-IF, it would actually break the flow.
Can you post a screenshot? Would love to see if it is "just" a visualization issue
And true that although I didn't get an error when duplicating @toy4rick 's rule, you wouldn't want to do it that way, but would rather follow @bravenel 's example. Otherwise, once the message started, there would be nothing other than pausing the rule to stop it until the time was no longer true. What you could do is have the contact be the trigger and set the time in restrictions. However, you would still want ELSE Stop Repeating actions
