Bulb buttons is an application - driver set that installs a virtual device with buttons for Color and Color Temperature Selection based on the user bulb selection. The user can then use these buttons on Dashboards to provide single push color / color temperature. Users can select from 22 buttons to implement:
12 pre-programmed color buttons
8 pre-programmed color temperature buttons
1 color toggle button that toggles through the 12 colors.
1 color temp buttons.
Requirement: Bulb must have associated capability implemented:
That sounds like a better idea than making one button push another.
Only other suggestion I'd have (trying to figure it out now) is to rename the states to correspond to the button numbers. Or some similar way to associate button numbers to what they do, without having to open your GH page to see the cross-reference.
Previous post: The driver has Attributes that correspond to the "Hubitat" color name. I use Attribute tiles above the button. There is no way to change the label of a button.
I believe this is the way to get the bulb tile in place.
In the dashboard builder, press the +, set the row/column, select your light, then select Bulb as the template.
Press Add Tile.
As for the color picker tiles, I have no idea.
I followed the same process above, but chose color bulb for the template.
All I ever get is a pop-up asking me to set a color.
