[RELEASE] Zooz ZEN32 Scene Controller (community driver)
Check Parameter 22 you can set it using this driver, size 1, value 1 will disable it. I set this on all my Zooz switches.
https://www.support.getzooz.com/kb/article/608-zen32-scene-controller-advanced-settings/
Enable / disable programming on the relay button
Parameter 22: Enable or disable programming functionality on the relay button. If this setting is disabled, then inclusion, exclusion, manual LED indicator change mode no longer work when the relay button is activated (factory reset and scene control will still work) - that means you can now use triple-tap triggers on the relay button for scenes and remote control of other devices.
Values: 0 – programming enabled (default). 1 – programming disabled.
