I have really tried with this device driver as I want my keypad to work properly.
I install it and try to use the complicated instructions to programme the user codes; it follows all the instructions but then when I try to actually use the keypad, i cannot get the status to change from On to Off or Home to Away. Am I doing something fundementally daft?
What do the logs say while you're working on it?
Hi, Thanks for the quick reply.
I set the Capture button (image1 and 2), click it and use 12341234 then allocate it to id 1 (image3 and image 4).
When i then type in the 12341234 code ie to actually use it rather than set it up image 5. This is where I am expecting the mode to change or the switch to turn on/off becasue then i can use it to set HSM.
Hope you can help. cheers
