[Release] zigbee2mqtt EcoSmart Remote ZBT-CCTSwitch-D0001
It't not clear to me whether the internal drivers they write are groovy or java and complied in, have a suspicion they reason the are closed source is that they are not groovy.
I have done the gambit from openhab, hass, pimatic, wink, smartthings, and now hubitat. I am getting a bit annoyed by we are not big enough answer, and their zigbee implmenation is so/so - I never had any problems with zigbee devices either on ST or Wink, did have problems with their cloud going out to lunch. I find HE zigbee to be pretty bad, and am keeping most bulbs on the hue hub. I had a fine mesh for years and with HE I had to put in extra repeaters, even then I constantly miss motion sensors and the delays seem be be longer for turning on lights on motion detectors in all zigbee then when I was doing hacked up X-10 drivers with ST on the cloud.
Also not a big fan on RM - I have a handful for rules and its taken more than an hour to just "code" a simple dimming rule for a button press like so -
Why cant I just use a scripting language like almost any other HA system.
The Pros for me are
  1. Local Control
  2. Packaged commercial stuff so for 90% of the things just work for basics
  3. Zwave and Zigbee Radios
  4. Maker API and websocket interface which gives abiltity to interface with other systems like nodered, Homebridge, influxdb etc.
Cons are:
  1. Increasingly getting opinionated about what they will support and what they won't
  2. Theri programming model doesn't really allow them to leverage the community as much as as ST did, they adopted a lot from ST but It seems like they have really cut off community from doing any real dev for Zigbee, unlike ST. Now I haven't delved into custom zigbee drivers much so just saying it based on cursory perusal.
  3. The undocumented websocket interface hope its stick around and becomes official
  4. And the is the biggest gripe rule definition is horrendous, non-portable and tedious, if you lose or have to do a device lost a ton of hours of work will be lost.
For me I will stick with HE for now because I have a mix of Zwave and Zigbee and it does give me a unified interface for them under local control. However I need to "extend' it and I am really looking for an alternative to HE may be something node-red would help, not too sure about latencies that will come in the system. But I just dont have time to define the rules that I need to do my automations, and i am not talking about complex things a simple 4-5 condition if-then-else switch take forever to define.
However with all other things going on in their universe i dont know how much of this is on their list.
