@razorwing
Try this custom device driver for your ECOLink. I swapped the open/closed.
* Ecolink Contact Sensor Custom (modified from original Z-Wave Door/Window Sensor)
* importUrl: "https://raw.githubusercontent.com/PrayerfulDrop/Hubitat/master/drivers/ecolink-custom.groovy"
* Copyright 2019 Aaron Ward
* Original code ported and modified for hubitat from: https://github.com/luder888/SmartThingsPublic/blob/master/devicetypes/luder888/zwave-door-window-sensor-as-smoke-detector.src/zwave-door-window-sensor-as-smoke-detector.groovy
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Changes:
* 1.0.0 - initial code port and modifications
metadata {
definition (
name: "Ecolink Contact Sensor Custom",
namespace: "aaronward",
author: "Aaron Ward",
capability "Contact Sensor"
capability "Battery"
capability "Configuration"
preferences() {
input("logEnable", "bool", title: "Enable logging", required: true, defaultValue: false)
def result = null
if (description.startsWith("Err 106")) {
if (state.sec) {
if(logEnable) log.debug description
} else {
result = createEvent(
descriptionText: "This sensor failed to complete the network security key exchange.",
eventType: "ALERT",
value: "failed",
isStateChange: true,
} else if (description != "updated") {
def cmd = zwave.parse(description, [0x20: 1, 0x25: 1, 0x30: 1, 0x31: 5, 0x80: 1, 0x84: 1, 0x71: 3, 0x9C: 1])
if (cmd) {
if(logEnable) log.debug "valid command"
result = zwaveEvent(cmd)
if(logEnable) log.debug "parsed '$description' to $result"
return result
def updated() {
if (logEnable) {
log.debug "Logs enabled. Logs will be disabled in 15 minutes."
runIn(900,logsOff)
def cmds = []
if (!state.MSR) {
cmds = [
command(zwave.manufacturerSpecificV2.manufacturerSpecificGet()),
"delay 1200",
zwave.wakeUpV1.wakeUpNoMoreInformation().format()
} else if (!state.lastbat) {
cmds = []
} else {
cmds = [zwave.wakeUpV1.wakeUpNoMoreInformation().format()]
response(cmds)
def configure() {
commands([
zwave.manufacturerSpecificV2.manufacturerSpecificGet(),
zwave.batteryV1.batteryGet()
], 6000)
def logsOff(){
log.warn "Debug logging disabled."
device.updateSetting("logEnable",[value:"false",type:"bool"])
def sensorValueEvent(value) {
if (value) {
createEvent(name: "contact", value: "closed")
} else {
createEvent(name: "contact", value: "open")
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd)
sensorValueEvent(cmd.value)
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd)
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
def zwaveEvent(hubitat.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
sensorValueEvent(cmd.sensorValue)
def zwaveEvent(hubitat.zwave.commands.sensoralarmv1.SensorAlarmReport cmd)
sensorValueEvent(cmd.sensorState)
def zwaveEvent(hubitat.zwave.commands.notificationv3.NotificationReport cmd)
def result = []
if (cmd.notificationType == 0x06 && cmd.event == 0x16) {
result << sensorValueEvent(1)
} else if (cmd.notificationType == 0x06 && cmd.event == 0x17) {
result << sensorValueEvent(0)
} else if (cmd.notificationType == 0x07) {
if (cmd.v1AlarmType == 0x07) { // special case for nonstandard messages from Monoprice door/window sensors
result << sensorValueEvent(cmd.v1AlarmLevel)
} else if (cmd.event == 0x01 || cmd.event == 0x02) {
} else if (cmd.event == 0x03) {
result << createEvent(descriptionText: "$device.displayName covering was removed", isStateChange: true)
if(!state.MSR) result << response(command(zwave.manufacturerSpecificV2.manufacturerSpecificGet()))
} else if (cmd.event == 0x05 || cmd.event == 0x06) {
result << createEvent(descriptionText: "$device.displayName detected glass breakage", isStateChange: true)
} else if (cmd.event == 0x07) {
result << createEvent(name: "motion", value: "active", descriptionText:"$device.displayName detected motion")
} else if (cmd.notificationType) {
def text = "Notification $cmd.notificationType: event ${([cmd.event] + cmd.eventParameter).join(", ")}"
result << createEvent(name: "notification$cmd.notificationType", value: "$cmd.event", descriptionText: text, displayed: false)
} else {
def value = cmd.v1AlarmLevel == 255 ? "active" : cmd.v1AlarmLevel ?: "inactive"
result << createEvent(name: "alarm $cmd.v1AlarmType", value: value, displayed: false)
result
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpNotification cmd)
def event = createEvent(descriptionText: "${device.displayName} woke up", isStateChange: false)
def cmds = []
if (!state.MSR) {
cmds << command(zwave.manufacturerSpecificV2.manufacturerSpecificGet())
cmds << "delay 1200"
if (!state.lastbat || now() - state.lastbat > 53*60*60*1000) {
cmds << command(zwave.batteryV1.batteryGet())
} else {
cmds << zwave.wakeUpV1.wakeUpNoMoreInformation().format()
[event, response(cmds)]
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
} else {
map.value = cmd.batteryLevel
state.lastbat = now()
[createEvent(map), response(zwave.wakeUpV1.wakeUpNoMoreInformation())]
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def result = []
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
log.debug "msr: $msr"
updateDataValue("MSR", msr)
retypeBasedOnMSR()
result << createEvent(descriptionText: "$device.displayName MSR: $msr", isStateChange: false)
if (msr == "011A-0601-0901") { // Enerwave motion doesn't always get the associationSet that the hub sends on join
result << response(zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId))
} else if (!device.currentState("battery")) {
if (msr == "0086-0102-0059") {
result << response(zwave.securityV1.securityMessageEncapsulation().encapsulate(zwave.batteryV1.batteryGet()).format())
} else {
result << response(command(zwave.batteryV1.batteryGet()))
result
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x25: 1, 0x30: 1, 0x31: 5, 0x80: 1, 0x84: 1, 0x71: 3, 0x9C: 1])
// log.debug "encapsulated: $encapsulatedCommand"
if (encapsulatedCommand) {
state.sec = 1
zwaveEvent(encapsulatedCommand)
def zwaveEvent(hubitat.zwave.Command cmd) {
createEvent(descriptionText: "$device.displayName: $cmd", displayed: false)
private command(hubitat.zwave.Command cmd) {
if (state.sec == 1) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
} else {
cmd.format()
private commands(commands, delay=200) {
delayBetween(commands.collect{ command(it) }, delay)
def retypeBasedOnMSR() {
switch (state.MSR) {
case "0086-0002-002D":
if(logEnable) log.debug "Changing device type to Z-Wave Water Sensor"
setDeviceType("Z-Wave Water Sensor")
break
case "011F-0001-0001": // Schlage motion
case "014A-0001-0001": // Ecolink motion
case "014A-0004-0001": // Ecolink motion +
case "0060-0001-0002": // Everspring SP814
case "0060-0001-0003": // Everspring HSP02
case "011A-0601-0901": // Enerwave ZWN-BPC
if(logEnable) log.debug "Changing device type to Z-Wave Motion Sensor"
setDeviceType("Z-Wave Motion Sensor")
break
case "013C-0002-000D": // Philio multi +
if(logEnable) log.debug "Changing device type to 3-in-1 Multisensor Plus (SG)"
setDeviceType("3-in-1 Multisensor Plus (SG)")
break
case "0109-2001-0106": // Vision door/window
if(logEnable) log.debug "Changing device type to Z-Wave Plus Door/Window Sensor"
setDeviceType("Z-Wave Plus Door/Window Sensor")
break
case "0109-2002-0205": // Vision Motion
if(logEnable) log.debug "Changing device type to Z-Wave Plus Motion/Temp Sensor"
setDeviceType("Z-Wave Plus Motion/Temp Sensor")
break
