Hi just paired D1 wireless double switch WXKG07LM and this kind of logs:
dev:72021-03-07 16:53:22.146 infoButton 2 was pushed
dev:72021-03-07 16:53:22.140 infoMultistate - endpoint: 2, taps: 0, physicalButton: 2, physicalButtons: 0, button: 2
dev:72021-03-07 16:53:22.132 infoMultistate - description:read attr - raw: 4E490200120A5500210000, dni: 4E49, endpoint: 02, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0000 | parseMap:[raw:4E490200120A5500210000, dni:4E49, endpoint:02, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0000, clusterInt:18, attrInt:85, valueParsed:0]
dev:72021-03-07 16:53:20.313 warnUnknown model (lumi.remote.b286acn02) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 4E490200120A5500210200, dni: 4E49, endpoint: 02, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0200 | parseMap:[raw:4E490200120A5500210200, dni:4E49, endpoint:02, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0002, clusterInt:18, attrInt:85, valueParsed:2]
dev:72021-03-07 16:53:20.303 infoButton 2 was double tapped
dev:72021-03-07 16:53:20.298 infoButton 2 was pushed
dev:72021-03-07 16:53:20.293 infoMultistate - endpoint: 2, taps: 2, physicalButton: 2, physicalButtons: 0, button: 2
dev:72021-03-07 16:53:20.286 infoMultistate - description:read attr - raw: 4E490200120A5500210200, dni: 4E49, endpoint: 02, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0200 | parseMap:[raw:4E490200120A5500210200, dni:4E49, endpoint:02, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0002, clusterInt:18, attrInt:85, valueParsed:2]
dev:72021-03-07 16:53:18.517 warnUnknown model (lumi.remote.b286acn02) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 4E490200120A5500210100, dni: 4E49, endpoint: 02, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:4E490200120A5500210100, dni:4E49, endpoint:02, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:72021-03-07 16:53:18.509 infoButton 2 was pushed
dev:72021-03-07 16:53:18.505 infoMultistate - endpoint: 2, taps: 1, physicalButton: 2, physicalButtons: 0, button: 2
dev:72021-03-07 16:53:18.478 infoMultistate - description:read attr - raw: 4E490200120A5500210100, dni: 4E49, endpoint: 02, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:4E490200120A5500210100, dni:4E49, endpoint:02, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:72021-03-07 16:53:14.365 warnUnknown model (lumi.remote.b286acn02) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 4E490100120A5500210000, dni: 4E49, endpoint: 01, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0000 | parseMap:[raw:4E490100120A5500210000, dni:4E49, endpoint:01, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0000, clusterInt:18, attrInt:85, valueParsed:0]
dev:72021-03-07 16:53:14.359 infoButton 1 was pushed
dev:72021-03-07 16:53:14.353 infoMultistate - endpoint: 1, taps: 0, physicalButton: 1, physicalButtons: 0, button: 1
dev:72021-03-07 16:53:14.334 infoMultistate - description:read attr - raw: 4E490100120A5500210000, dni: 4E49, endpoint: 01, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0000 | parseMap:[raw:4E490100120A5500210000, dni:4E49, endpoint:01, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0000, clusterInt:18, attrInt:85, valueParsed:0]
dev:72021-03-07 16:53:11.571 warnUnknown model (lumi.remote.b286acn02) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 4E490100120A5500210200, dni: 4E49, endpoint: 01, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0200 | parseMap:[raw:4E490100120A5500210200, dni:4E49, endpoint:01, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0002, clusterInt:18, attrInt:85, valueParsed:2]
dev:72021-03-07 16:53:11.554 infoButton 1 was double tapped
dev:72021-03-07 16:53:11.548 infoButton 1 was pushed
dev:72021-03-07 16:53:11.542 infoMultistate - endpoint: 1, taps: 2, physicalButton: 1, physicalButtons: 0, button: 1
dev:72021-03-07 16:53:11.535 infoMultistate - description:read attr - raw: 4E490100120A5500210200, dni: 4E49, endpoint: 01, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0200 | parseMap:[raw:4E490100120A5500210200, dni:4E49, endpoint:01, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0002, clusterInt:18, attrInt:85, valueParsed:2]
dev:72021-03-07 16:53:09.251 warnUnknown model (lumi.remote.b286acn02) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 4E490100120A5500210100, dni: 4E49, endpoint: 01, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:4E490100120A5500210100, dni:4E49, endpoint:01, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:72021-03-07 16:53:09.242 infoButton 1 was pushed
dev:72021-03-07 16:53:09.236 infoMultistate - endpoint: 1, taps: 1, physicalButton: 1, physicalButtons: 0, button: 1
dev:72021-03-07 16:53:09.228 infoMultistate - description:read attr - raw: 4E490100120A5500210100, dni: 4E49, endpoint: 01, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:4E490100120A5500210100, dni:4E49, endpoint:01, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
The driver version is v1.0.1.1123 and sequence what I used in logs is
- one tap with left switch
- double tap with left switch
- long press with left switch
- and same with right switch
I don't know what those logs mean and why it shows that the device is unknown?
