So, have you thought about a websocket ping/pong? Also, this would actually be a great addition to Device Watchdog imho. I'm not sure if HE supports a network type in the Device object (I haven't looked), but it would be a neat report to have where it icmp pings or ws ping/pongs devices along with the other checks.
I figured out how to install third party app reading some other threads.
I installed the parent app.
I installed the child app.
I set up a child ping rule to a local device with a push notification after 5 min.
I turned the local device off.
Never got the notification that the pings stopped.
What kind of device are you pinging?
Its an iPhone with an IP that is statically set in the my router.
I was also running a ping test from my computer which did stop when the iPhone was powered off.
Hmmmm, can you post your logs of the app and also a screen cap of the notification rule?
That looks cool and I will definitely check it out. The iPhone was just the first test I setup. I am wanting to ping other things in my network and get notifications when they stop responding. It would also be cool to have a tile that would change color on the dashboard. Also shorter internvals for ping would be cool.
Hi. Thanks for this app.
I'm assuming that where it says Pushover notification it's no longer limited to this form of notification. It lists my mobile (which runs the Hubitat app) and where I don't use the Pushover service at all.
Can you please confirm? And if so maybe you might want to change the wording.
Cheers.
That's right, any place that says pushover should also be able to send to the new HE notifications.
Try it! Half the fun of home automation is trying new stuff.
As I update apps I change the wording, not going to every app and updating just for that.
Hi @bptworld Bryan,
Your apps are great, however Web pinger doesn't quite do what I need.
Would it be possible to add a setting to the child app that inverts the switching and adds a delay before restoring the switch state. i.e If the website isn't available then turn off a switch, wait for x number of seconds then turn the switch back on?
Hope you don't mind be asking.
Regards
Tim
Sure
New version on github...
V2.0.1 - 09/06/19 - Add new section to 'Turn Switch(es) OFF if URL is not available, ON if everything is good'. Also added an optional reset timer.
One condition... you have to do the testing!
Thank you, that was amazingly quick.
I have it running currently and all seems to be fine. I’ll monitor it over the next week.
Tim
Hello Sir !
First of all, thank you or such an awesome app !
It works great to ping websites such as https://google.com/, but when I try to ping a LAN device connect over WiFi, like 192.168.X.XXX (which pings well from PC), the log says "Request failed to 192.168.X.XXX"...
Is there any way to ping LAN devices ? Maybe I am missing something..
PS : it's to be able to reboot my router independently from my internet box if the router's WiFi fails.
Best Regards,
Theodore
Sorry, not with this app
Ooooh damn
Do you think there could be any way to adapt it to make it work with LAN devices ?
Woaw thank you for this, it should work !
When I first red this thread I was like damn it's all about iPhones their.. But it's all about devices
Is there a particular website that is consistently not reachable that i can use to test that web pinger is working correctly on my hub?
Well that was easy...
