Weather Watcher puts current conditions and a clean multi-day forecast on your Hubitat dashboard, and gives you the same data as device attributes you can use in rules.
This project was heavily inspired by the weather forecast tile included in the Rachio Community app, which unfortunately only works while the controller has an active schedule (that is, not during winter). There are a lot of weather apps on Hubitat that grab current conditions and forecasts for rules, but none were really quite right for my dashboard. So, here we are.
Weather Watcher (and most of this post) was written entirely with Grok Bot, an AI assistant.
What it does
- Current conditions (optional): a block above the forecast with a large icon (night version after sunset), the temperature, condition, feels-like and today's high / low, plus Humidity, Wind and Rain today chips.
- Show current conditions / Show forecast: two checkboxes, so a tile can show current conditions, the forecast, or both (current on top). Show forecast is on by default; Show current conditions is off by default because it makes the tile about 70% taller.
- Forecast tile: 1 to 7 days, with day labels, icons, high / low, chance of rain and rain amount. The tile is a single SVG image, so it scales to any tile size.
- Device attributes for rules: each Weather Watcher creates a device with the tile (
weatherWatcher) plus weather attributes you can use in Rule Machine, webCoRE and other apps: currenttemperature,humidity,feelsLike,windSpeed,windDirection,windCardinalandweather, plus per-day highs, lows, conditions and rain. - Weather sources:
- Open-Meteo (free, worldwide, the default)
- NWS / weather.gov (free, US only; current conditions from the nearest observation station)
- Keyed provider (OpenWeatherMap One Call compatible, bring your own API key)
- Five icon packs: Rob's filled, Rob's outline, Monochrome (erikflowers), Meteocons, and Meteocons animated.
- Night icons for today: after sunset, today's icon switches to its night version.
- Looks: dark or light theme, transparent background, corner radius, font and size, optional colour overrides.
- Tile URL: choose Local (LAN only) or Cloud (works away from home).
- Last-updated line: an optional small line with the location and time, for example "Grosse Pointe Woods, Oct 29, 12:44 AM", with your own date format.
- You can create as many Weather Watchers as you like, each with its own location and style.
Installation
Option A: Hubitat Package Manager search (recommended)
- Open Hubitat Package Manager โ Install โ Search by Keywords.
- Search for Weather Watcher, select Weather Watcher by Rob Cummings, and click Next to install.
- HPM installs the icon library bundle, the Weather Watcher Device driver, and the Weather Watcher Manager and Weather Watcher apps. It also turns on OAuth for the Weather Watcher app.
Option B: Hubitat Package Manager, install from a URL
- HPM โ Install โ From a URL
- Paste:
https://raw.githubusercontent.com/cummingsrob/hubitat-weather-watcher/main/packageManifest.json - HPM installs the same pieces and turns on OAuth, as in Option A.
Option C: Manual (bundle)
- Developer tools โ Bundles โ Import ZIP, then import
bundle.zipfrom the repo. This adds the libraries, the driver and both apps. - Enable OAuth: go to Apps Code โ open Weather Watcher (the child app, not the Manager) โ OAuth (top right) โ Enable OAuth in App โ Update โ Save.
OAuth is required. The tile image is served by the app's own endpoint. If OAuth is off, the app shows "Enable OAuth for this app in Apps Code" in the Dashboard section. Turn it on as above, then open the app and click Done.
Setup
- Apps โ Add User App โ Weather Watcher Manager, then Add a Weather Watcher.
- Pick a weather source, your location (the hub location by default), and the units, days, theme and icon pack, then click Done. A device with the same name is created.
- Dashboard: add that device with template Attribute, attribute weatherWatcher. (Recommended)
- Image tile alternative: paste the forecast image link (Open tile image in the app). Use the cloud link if you view dashboards away from home. An Image tile keeps a copy of the link, so it stops working if you click Regenerate access token. The Attribute tile follows automatically.
Links
- GitHub (README, changelog, requirements): GitHub - cummingsrob/hubitat-weather-watcher ยท GitHub
- HPM manifest: https://raw.githubusercontent.com/cummingsrob/hubitat-weather-watcher/main/packageManifest.json
- Current version: 0.2.20
Credits and license
Apache License 2.0. Design and code are partly adapted from Rachio-Community (Anthony Santilli, lnjustin), Apache 2.0. Icons: erikflowers/weather-icons (SIL OFL 1.1) and Meteocons by Bas Milius (MIT). Forecast data: Open-Meteo (CC BY 4.0) and the US National Weather Service. See NOTICE and ICONS-LICENSE.txt in the repo.
Questions, bug reports and ideas are welcome here or on GitHub. But mostly here.
