Question to the followers -
Wondering if folks have continued to use this through the current level of HE upgrades 2.4.0.x and found all functioning as it should ?
Thanks in advance for all replies.
Sorry about my absence from this thread, having a child really has swallowed all the time I might have normally done some coding.
To answer your questions, I got some way to getting Powermaster integrated and working, and some of the basic features were working (arming and status), but zone data was unreliable and I never had the time to finish that off. As a result if you want a reliable integration then Powermax is the way to go, and I use that daily and it works flawlessly (in my opinion). If you fancy giving Powermaster a go then thats great, but Im afraid it will probably need more debugging still since with Visonic every system is a bit different.
Oh yeah, get that. And (as some might agree)...if you are having another don't wait too many years as there's something about grouping all that into one block/period of your life that seems to work better than dragging it out. Even though that doesn't seem intuitive.
Ha, "Home Automation" advice you didn't count on finding in the HE Community.
Lol, definitely no more! Poor planet doesnt need more humans!
Ive had Powermaster on my to do list for so long I'd love to know how many hairs Ive lost as a result! Having got the Serial repeating part working it should be fairly doable, since you can trace each message and which ones dont get the right response, but realistically I dont want to set a target any more and it will probably depend on busyness of work.
a) seems to be a pretty common view of those in the childbearing years these days.
b) So with where the Powermaster stuff is at;
can we expect your previously distributed hardware to work,
and the App to function on a basic level like Arming/Disarming the Powermaster
and the Alarm conditions being relayed to the App/Hubitat?
Just maybe not Zone configuration or specificity?
Thats certainly a much more realistic target when I have limited time. Let me see how I get on this week with finalising what Ive got and then can maybe get you some code to test with.
Hi new here. I have a PowerMax Pro here in the US since 2011 and it is working fine using the local land line only. Been thinking of ways to access it thru wifi or buying a new PowerMaster 30 G2 but would need all new sensors. $$. I found a article on how to use a Home Assistant.
But I already have a Hubitat C8.
So I need a Wimos D1 and a Arduino Nano to start with.
Just got done reading a bunch of the threads on Home Assistant's forum relevant to Visonic panel integration. You were certainly a big part of improving on that initiative. Seems there's a whole lot more folks in that space that wanted/needed this integration.
Still dismayed how few Visonic PowerMaster PG2 panel adopters there are among the Home Automation crowd. It clearly was a positive evolution of the "Power series" of panels with more capable sensors particularly in range.
Hope all is well.
Id love to finish the integration but time has become so much more in demand since having a child. I've even bought everything ready to test with, just a lack of time! I think integrating via HA and then bringing into Hubitat is a sensible option for now, but it probably only needs a few hours of somebody with the right skills to sort out this integration. I even added all the debug tools into the Wemos code so you can track which messages are causing the integration to fail to sync.
Knee deep into this with Powermaster-30 G2
Having varying degrees of success, first listening, seeing some data but not getting a full likst of the zones to populate, then enrolling and (only once) getting a chance to Arm/Disarm. So it looks like we're talking...just not consistently. I figure I'm not successfully pairing the WeMos so I'm still working on it. Changed the pin once to the second 5650 and that's when I got a shot at control but just once.
Am I overlooking your latest firmware for the WeMos ?
firmware_date "Jun 27 2021 - 11:02:55"
