I've thought about this idea in the past. It would be great at a system level for Hubitat to create a virtual device and link it to a real device on the backend. It would make swapping out devices a lot easier.
As for this app, it only works with devices that have drivers written in a certain way. Its purpose was to provide access to multi-channel device endpoints before parent / child devices were a thing. I don't plan on maintaining it or modifying it as Hubitat has supported child devices for a long time.
Hi Eric I had your virtual sync, virtual energy switch & PANO4 DH set up in ST a while back and it was working beyond expectation so thank you for that. I have migrated over to HE and have every other device working perfectly but for the life of me I cannot get this to workin HE, to me it seems it is the PAN04 DH that is is the issue as it is flakey and unresponsive I remember in ST there were more settings available in particular parameter 31 (Primitive Frame ) which when set to 2 fixed the flakey switching. Also not sure of what the configure,reset and refresh tiles actually do?
Last night there was a platform update I have the C-7 version this update included a lot of fixes for z wave on the C-7 and your DH is now working properly with the PAN04.
So thank you again for sharing this driver.
I’m a long time ST user and am migrating to HE. I have an Aeotec Smartstrip and am using your drivers and sync app on the ST. I am trying to understand how to use your HE versions but I’m confused. What driver do I use for the Smartsrtip? Also I am using your virtual energy driver for the virtual switches. I can’t seem to find a comparable driver in HE. I think I found the smartstrip driver and the sync app in this thread, but I can’t find the virtual driver. If it’s not too much trouble, can set me straight on all this? By the way, thanks for the great work on this.
Thanks for the quick response. I see the drivers but not the Virtual Device Sync app. Can I use the one for Inovelli you identified earlier in the thread?
I installed the Smartstrip and it went very clean. One thing, I can’t see how to show the energy usage. In SmartThings it displayed along with switch status. What am I missing? I need to be able to test power level in an automation routine. Thanks again for the excellent work.
The meter reports were not being received correctly in Hubitat so there was nothing I could do to get the readings. They all had blank values for the report.
I have 2 Aeon Smartstrip devices. When I run the Virtual Device Sync it creates 4 virtual switches for one Smartstrip. When I run it to create virtual switches for the second Smartstrip, it wants to create switches for the ones that already exist. How do I get it to make the virtual switches for both Smartstrips? When I ran it in SmartThings it worked as expected but not so in Hubitat.
I've just made all my own dimmers for each channel and used RM to turn them up/down in sync. I was just using the app at the top of this topic, but got that error.
