So bad news, my ideas didn't work... I tried to get it to log out every 5 minutes, then log back in, but I still only got it to last about 15-20 minutes at best before failing out. I did, However, make the following "enhancements"
#!/usr/bin/python
# Config File Location
# default is /etc/unifipresence.conf
confFile = "./unifipresence.conf"
#Imports
import json
import requests, requests.utils
import sys, traceback
import cookielib
import datetime
from ConfigParser import SafeConfigParser
from requests.packages.urllib3.exceptions import InsecureRequestWarning
config = SafeConfigParser()
config.read(confFile)
HubitatIP = config.get('DEFAULT', 'HubitatIP').strip("'\" \t")
CloudAuth = config.get('DEFAULT', 'CloudAuth').strip("'\" \t")
MakerAPI = config.get('DEFAULT', 'MakerAPI').strip("'\" \t")
AccessToken = config.get('DEFAULT', 'AccessToken').strip("'\" \t")
urlUniFiBase = config.get('DEFAULT', 'urlUniFiBase').strip("'\" \t")
unUniFi = config.get('DEFAULT', 'unUniFi').strip("'\" \t")
pwUniFi = config.get('DEFAULT', 'pwUniFi').strip("'\" \t")
siteUniFi = config.get('DEFAULT', 'siteUniFi').strip("'\" \t")
cookieFile = config.get('DEFAULT', 'cookieFile').strip("'\" \t")
tmpFile = config.get('DEFAULT', 'tmpFile').strip("'\" \t")
#Setup
requests.packages.urllib3.disable_warnings(InsecureRequestWarning)
def main():
sesUniFi = requests.Session()
sesUniFi.verify = False
jar = cookielib.MozillaCookieJar()
try:
jar.load(cookieFile, ignore_discard=True, ignore_expires=True)
sesUniFi.cookies = jar
except:
loginUniFi(sesUniFi)
pass # No cookie file, so login first
try:
url = urlUniFiBase + '/api/s/' + siteUniFi + '/stat/report/hourly.site'
r = sesUniFi.get(url)
except:
sys.exit("UniFi Connection Test Failed")
if not r.status_code == requests.codes.ok:
jar.save(cookieFile, ignore_discard=True, ignore_expires=True)
try:
url = urlUniFiBase + '/api/s/' + siteUniFi + '/stat/sta'
except:
sys.exit("UniFi Client Listing Failed")
clientsUniFi = r.json()
# print clientsUniFi
# for clientUniFi in clientsUniFi['data']:
# print clientUniFi['mac']
# Read/Create temp status file
# clientStatus = open(tmpFile,'w+')
# Loop through config
for clientConfig in config.sections():
# print '\nSection:', clientConfig
if not (config.has_option(clientConfig, 'DeviceID')):
print(datetime.datetime.now(), clientConfig, "must contain DeviceID")
if not (config.has_option(clientConfig, 'macAddr')):
print(datetime.datetime.now(), clientConfig, "must contain macAddr")
else:
DeviceID = config.get(clientConfig, 'DeviceID').strip("'\" \t")
macAddr = config.get(clientConfig, 'macAddr').strip("'\" \t")
lastStatus = getLastStatus(DeviceID)
# print 'Client %s\nDeviceID %s\nLast Status %s\nMacAddr %s' % (clientConfig, DeviceID, lastStatus, macAddr)
# search clientsUniFi for macAddr
currStatus = macSearch(macAddr, clientsUniFi)
# print(datetime.datetime.now()), "Current Status", currStatus
setLastStatus(DeviceID, currStatus)
if not ( lastStatus and currStatus == lastStatus):
print(datetime.datetime.now(), 'Update Hubitat for ' + clientConfig + ' with status ' + currStatus)
updateHubitat(HubitatIP, CloudAuth, DeviceID, currStatus)
#Defs
def getLastStatus(DeviceID):
try:
with open(tmpFile, "r") as jsonFile:
data = json.load(jsonFile)
return data[DeviceID]
except:
return False
def setLastStatus(DeviceID, status):
try:
data[DeviceID] = status
except:
data = {}
with open(tmpFile, "w") as jsonFile:
json.dump(data, jsonFile)
def loginUniFi(sesUniFi):
url = urlUniFiBase + "/api/login"
auth = {'username': unUniFi, 'password': pwUniFi}
try:
r = sesUniFi.post(url, data=json.dumps(auth))
except requests.exceptions.RequestException as e:
print(e)
sys.exit("UniFi login failed")
print(datetime.datetime.now()), "Login failed with status code ", r.status_code
sys.exit(1)
else:
print(datetime.datetime.now()), "UniFi logged in"
def macSearch(macAddr, clientsUniFi):
if clientUniFi['mac'].upper() == macAddr.upper():
return 'Present'
return 'Absent'
def updateHubitat(HubitatIP, CloudAuth, DeviceID, currStatus):
if currStatus == 'Present':
status = 'on'
else:
status = 'off'
if CloudAuth == "":
url = HubitatIP + "/apps/api/" + MakerAPI + "/devices/" + DeviceID + "/" + status + "?access_token=" + AccessToken
else:
url = HubitatIP + "/api/" + CloudAuth + "/apps/" + MakerAPI + "/devices/" + DeviceID + "/" + status + "/?access_token=" + AccessToken
# print url
try:
r = requests.get(url)
print(e)
sys.exit("Hubitat Update Failed")
print(datetime.datetime.now()), "Hubitat update failed with status code ", r.status_code
if int(r.status_code) == '500':
print(datetime.datetime.now()), "Is this really a Virutal Switch?"
# else:
# print(datetime.datetime.now()), "hubitat Updated"
if __name__ == '__main__':
main()
# Configuration
[DEFAULT]
#Hubitat details
HubitatIP = "https://cloud.hubitat.com"
CloudAuth = "cloud string" # first long string in MakerApi area. Leave blank within quotes if local
MakerAPI = '123'
AccessToken= 'access token string'
#UniFi Manager Base URL
urlUniFiBase = 'https://localhost:8443'
unUniFi = 'username' #create a read user for unifi
pwUniFi = 'unifiPass'
siteUniFi = 'default'
#Files
#location of cookie file, tempfile
cookieFile = 'autofile.unifipresence.cookie'
tmpFile = 'autofile.unifipresence.status'
#Client Information
# User1
[U1]
macAddr = '00:00:00:00:00:00'
DeviceID = '100'
# User2
[U2]
DeviceID = '101'
Hopefully this will be useful for someone. I could also implement a Unifi cloud URL if someone is interested in that... I just didn't need it, so I didn't use it.
