[RELEASE] Tuya Zigbee Valve driver (w/ healthStatus)
Sorry, this driver is not suitable for controlling double valves.. A simple on/off for the second valve could be possible, but not the full functionality (no auto shut-off, etc..)
I should have checked here first! I have a SONOFF SWV-ZF2E arriving later today, having just “assumed” that it would work okay with HE.
Does this mean that one valve can be used with this driver and it works as planned, and the other valve will do nothing at present? Or could I control the second one with simple on/off? That would be a start, at least.
When you receive the ZF-2E and pair it to your HE hub, send me in a DM the fingerprint (Device driver, ‘Get Info’). I will need some debug logs later on as well.
Done, thank you!
Since the current development branch version 1.8.0 contains significant code changes (working on the new SONOFF SWV-ZF2 dual-valve support), I've archived the previous stable version for reference:
:package: Tuya Zigbee Valve v1.7.1
If you encounter any issues with v1.8.0, you can download and revert to this latest stable version 1.7.1
