I did the test again.
There is a notification on the Galaxy Home Mini, which has never been set up.
This doesn't work either.
I don't know how to test this.
Current States
- battery : 100
- batteryLastReplaced : Thu Dec 22 14:37:36 KST 2022
- lastStatus : Thu Dec 22 14:42:53 KST 2022
- powerSource : unknown
- presence : not present
- smoke : clear
Summary
dev:4252022-12-22 02:53:21.519 PMdebugBattery Attribute 0x0021 Received
dev:4252022-12-22 02:53:19.576 PMdebugModel is TS0205
dev:4252022-12-22 02:53:17.546 PMdebugManufacturer is _TYZB01_dsjszp0x
dev:4252022-12-22 02:53:15.539 PMdebugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x01, data: [0x33, 0x00, 0x86], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0xe415, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x01, clusterId: 0x0001, destinationEndpoint: 0x01, options: 0x0040)
dev:4252022-12-22 02:53:13.500 PMdebugBattery level is 100% (3 Volts)
dev:4252022-12-22 02:53:11.479 PMdebugSmoke Detector is Battery Powered
dev:4252022-12-22 02:53:09.499 PMdebugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x01, data: [0x00, 0x00, 0x86], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0xe415, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x01, clusterId: 0x0502, destinationEndpoint: 0x01, options: 0x0040)
dev:4252022-12-22 02:53:07.434 PMdebugUnknown --> Cluster-> 0500 AttrInt-> 2 Value-> 0000
dev:4252022-12-22 02:53:05.412 PMdebugZone State is enrolled
dev:4252022-12-22 02:53:03.386 PMdebugZone Type is Fire Sensor
dev:4252022-12-22 02:52:51.286 PMdebugSmoke Detector all clear
dev:4252022-12-22 02:52:50.856 PMdebugRefreshing...
dev:4252022-12-22 02:52:50.853 PMdebugConfiguring...
dev:4252022-12-22 02:52:48.593 PMdebugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x01, data: [0x00, 0x00, 0x86], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0x7e25, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x01, clusterId: 0x0502, destinationEndpoint: 0x01, options: 0x0040)
dev:4252022-12-22 02:52:48.213 PMdebugUnknown --> Cluster-> 0500 AttrInt-> 2 Value-> 0000
dev:4252022-12-22 02:52:47.271 PMdebugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x01, data: [0x33, 0x00, 0x86], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0x7e25, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x01, clusterId: 0x0001, destinationEndpoint: 0x01, options: 0x0040)
dev:4252022-12-22 02:52:47.239 PMdebugBattery level is 100% (3 Volts)
dev:4252022-12-22 02:52:46.258 PMdebugSmoke Detector is Battery Powered
dev:4252022-12-22 02:52:46.243 PMdebugBattery level is 100% (3 Volts)
dev:4252022-12-22 02:52:46.214 PMdebugSmoke Detector is Battery Powered
dev:4252022-12-22 02:52:43.490 PMdebugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x01, data: [0x00, 0x00, 0x86], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0x7e25, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x01, clusterId: 0x0502, destinationEndpoint: 0x01, options: 0x0040)
dev:4252022-12-22 02:52:43.460 PMdebugUnknown --> Cluster-> 0500 AttrInt-> 2 Value-> 0000
dev:4252022-12-22 02:52:43.413 PMdebugZone State is enrolled
dev:4252022-12-22 02:52:43.398 PMdebugUnknown --> Cluster-> 0500 AttrInt-> 2 Value-> 0000
dev:4252022-12-22 02:52:43.373 PMdebugZone Type is Fire Sensor
dev:4252022-12-22 02:52:43.352 PMdebugZone State is enrolled
dev:4252022-12-22 02:52:43.329 PMdebugZone State is enrolled
dev:4252022-12-22 02:52:42.122 PMdebugSmoke Detector all clear
dev:4252022-12-22 02:52:22.369 PMdebugRefreshing...
dev:4252022-12-22 02:52:22.360 PMdebugConfiguring...
dev:4252022-12-22 02:43:24.208 PMdebugBattery Attribute 0x0021 Received
dev:4252022-12-22 02:43:22.249 PMdebugModel is TS0205
dev:4252022-12-22 02:43:20.232 PMdebugManufacturer is _TYZB01_dsjszp0x
dev:4252022-12-22 02:43:18.204 PMdebugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x01, data: [0x33, 0x00, 0x86], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0x7e25, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x01, clusterId: 0x0001, destinationEndpoint: 0x01, options: 0x0040)
dev:4252022-12-22 02:43:16.187 PMdebugBattery level is 100% (3 Volts)
dev:4252022-12-22 02:43:14.153 PMdebugSmoke Detector is Battery Powered
dev:4252022-12-22 02:43:12.154 PMdebugSmartShield(text: null, manufacturerId: 0x0000, direction: 0x01, data: [0x00, 0x00, 0x86], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0x7e25, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x01, clusterId: 0x0502, destinationEndpoint: 0x01, options: 0x0040)
dev:4252022-12-22 02:43:10.125 PMdebugUnknown --> Cluster-> 0500 AttrInt-> 2 Value-> 0000
dev:4252022-12-22 02:43:08.086 PMdebugZone State is enrolled
dev:4252022-12-22 02:43:06.072 PMdebugZone Type is Fire Sensor
dev:4252022-12-22 02:42:53.993 PMdebugSmoke Detector all clear
dev:4252022-12-22 02:42:53.713 PMdebugRefreshing...
dev:4252022-12-22 02:42:53.710 PMdebugConfiguring...
dev:4252022-12-22 02:38:16.990 PMdebugResetting to Clear...
dev:4252022-12-22 02:37:36.065 PMdebugRefreshing...
dev:4252022-12-22 02:37:36.032 PMdebugSmoke Detector Setting Battery Last Replaced to Current date for newly paired sensor
dev:4252022-12-22 02:37:36.022 PMdebugConfiguring...
dev:4252022-12-22 02:25:45.819 PMinfoSmoke Detector smoke is clear
dev:4252022-12-22 02:25:42.530 PMinfoSmoke Detector smoke is tested
dev:4252022-12-22 02:25:39.467 PMinfoSmoke Detector smoke is tested
dev:4252022-12-22 02:25:31.095 PMinfoSmoke Detector smoke is detected
dev:4252022-12-22 02:07:11.636 PMdebugSmoke Detector pollPresence()
dev:4252022-12-22 01:07:11.615 PMdebugSmoke Detector pollPresence()
dev:4252022-12-22 12:07:11.594 PMdebugSmoke Detector pollPresence()
dev:4252022-12-22 11:07:11.574 AMwarnSmoke Detector not present!
dev:4252022-12-22 11:07:11.570 AMdebugSmoke Detector pollPresence()
dev:4252022-12-22 10:07:11.549 AMdebugSmoke Detector pollPresence()
dev:4252022-12-22 09:07:11.527 AMdebugSmoke Detector pollPresence()
dev:4252022-12-22 08:07:11.507 AMdebugSmoke Detector pollPresence()
dev:4252022-12-22 07:07:11.485 AMdebugSmoke Detector pollPresence()
