Summary
dev:26582023-05-03 17:00:04.700infommwave humidity is 108 % RH
dev:26582023-05-03 17:00:04.698debugmmwave Tuya cluster: dp_id=2 dp=105 fncmd=108
dev:26582023-05-03 17:00:04.696debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 0027690200040000006C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 27, 69, 02, 00, 04, 00, 00, 00, 6C]]
dev:26582023-05-03 17:00:04.635debugmmwave ignored motion inactive event after 10s
dev:26582023-05-03 17:00:04.633debugmmwave motion event 0x65 fncmd = 0
dev:26582023-05-03 17:00:04.630debugmmwave Tuya cluster: dp_id=2 dp=101 fncmd=0
dev:26582023-05-03 17:00:04.628debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00266502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 26, 65, 02, 00, 04, 00, 00, 00, 00]]
dev:26582023-05-03 17:00:01.962infommwave humidity is 108 % RH
dev:26582023-05-03 17:00:01.960debugmmwave Tuya cluster: dp_id=2 dp=105 fncmd=108
dev:26582023-05-03 17:00:01.958debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 0025690200040000006C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 25, 69, 02, 00, 04, 00, 00, 00, 6C]]
dev:26582023-05-03 17:00:01.898debugmmwave ignored motion inactive event after 8s
dev:26582023-05-03 17:00:01.896debugmmwave motion event 0x65 fncmd = 0
dev:26582023-05-03 17:00:01.893debugmmwave Tuya cluster: dp_id=2 dp=101 fncmd=0
dev:26582023-05-03 17:00:01.891debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00246502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 24, 65, 02, 00, 04, 00, 00, 00, 00]]
dev:26582023-05-03 16:59:59.219infommwave humidity is 108 % RH
dev:26582023-05-03 16:59:59.217debugmmwave Tuya cluster: dp_id=2 dp=105 fncmd=108
dev:26582023-05-03 16:59:59.214debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 0023690200040000006C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 23, 69, 02, 00, 04, 00, 00, 00, 6C]]
dev:26582023-05-03 16:59:59.149debugmmwave ignored motion inactive event after 5s
dev:26582023-05-03 16:59:59.147debugmmwave motion event 0x65 fncmd = 0
dev:26582023-05-03 16:59:59.145debugmmwave Tuya cluster: dp_id=2 dp=101 fncmd=0
dev:26582023-05-03 16:59:59.142debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00226502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 22, 65, 02, 00, 04, 00, 00, 00, 00]]
dev:26582023-05-03 16:59:56.662debugmmwave Tuya descMap?.command = 11 descMap.data = [00, 24, 40]
dev:26582023-05-03 16:59:56.659debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 11 01 002440, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[00, 24, 40]]
dev:26582023-05-03 16:59:56.477infommwave humidity is 108 % RH
dev:26582023-05-03 16:59:56.475debugmmwave Tuya cluster: dp_id=2 dp=105 fncmd=108
dev:26582023-05-03 16:59:56.473debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 0021690200040000006C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 21, 69, 02, 00, 04, 00, 00, 00, 6C]]
dev:26582023-05-03 16:59:56.410debugmmwave ignored motion inactive event after 2s
dev:26582023-05-03 16:59:56.408debugmmwave motion event 0x65 fncmd = 0
dev:26582023-05-03 16:59:56.406debugmmwave Tuya cluster: dp_id=2 dp=101 fncmd=0
dev:26582023-05-03 16:59:56.404debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00206502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 20, 65, 02, 00, 04, 00, 00, 00, 00]]
dev:26582023-05-03 16:59:55.727infommwave Tuya check-in (application version is 4A)
dev:26582023-05-03 16:59:55.724debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:2C71010000180100204AE2FF2038E4FF2001, dni:2C71, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:4A, clusterInt:0, attrInt:1, additionalAttrs:[[value:38, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:01, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:26582023-05-03 16:59:55.671infommwave mmwave tamper alarm is clear (dp=05,fncmd=0)
dev:26582023-05-03 16:59:55.669debugmmwave Tuya cluster: dp_id=1 dp=5 fncmd=0
dev:26582023-05-03 16:59:55.667debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 001F0501000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1F, 05, 01, 00, 01, 00]]
dev:26582023-05-03 16:59:55.625infommwave battery is 5 %
dev:26582023-05-03 16:59:55.623debugmmwave Tuya battery status report dp_id=2 dp=102 fncmd=5
dev:26582023-05-03 16:59:55.621debugmmwave Tuya cluster: dp_id=2 dp=102 fncmd=5
dev:26582023-05-03 16:59:55.619debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 001A6602000400000005, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1A, 66, 02, 00, 04, 00, 00, 00, 05]]
dev:26582023-05-03 16:59:55.573debugmmwave ignored motion inactive event after 1s
dev:26582023-05-03 16:59:55.571debugmmwave motion event 0x65 fncmd = 0
dev:26582023-05-03 16:59:55.569debugmmwave Tuya cluster: dp_id=2 dp=101 fncmd=0
dev:26582023-05-03 16:59:55.567debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00196502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 19, 65, 02, 00, 04, 00, 00, 00, 00]]
dev:26582023-05-03 16:59:55.524debugmmwave ignored motion inactive event after 1s
dev:26582023-05-03 16:59:55.522debugmmwave motion event 0x65 fncmd = 0
dev:26582023-05-03 16:59:55.519debugmmwave Tuya cluster: dp_id=2 dp=101 fncmd=0
dev:26582023-05-03 16:59:55.517debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00186502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 18, 65, 02, 00, 04, 00, 00, 00, 00]]
dev:26582023-05-03 16:59:55.471debugmmwave ignored motion inactive event after 1s
dev:26582023-05-03 16:59:55.469debugmmwave motion event 0x65 fncmd = 0
dev:26582023-05-03 16:59:55.467debugmmwave Tuya cluster: dp_id=2 dp=101 fncmd=0
dev:26582023-05-03 16:59:55.465debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00176502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 17, 65, 02, 00, 04, 00, 00, 00, 00]]
dev:26582023-05-03 16:59:55.420debugmmwave ignored motion inactive event after 1s
dev:26582023-05-03 16:59:55.418debugmmwave motion event 0x65 fncmd = 0
dev:26582023-05-03 16:59:55.416debugmmwave Tuya cluster: dp_id=2 dp=101 fncmd=0
dev:26582023-05-03 16:59:55.414debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00166502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 16, 65, 02, 00, 04, 00, 00, 00, 00]]
dev:26582023-05-03 16:59:55.372infommwave Motion reset to inactive after 1s
dev:26582023-05-03 16:59:55.370debugmmwave motion event 0x65 fncmd = 0
dev:26582023-05-03 16:59:55.368debugmmwave Tuya cluster: dp_id=2 dp=101 fncmd=0
dev:26582023-05-03 16:59:55.365debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00156502000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 15, 65, 02, 00, 04, 00, 00, 00, 00]]
dev:26582023-05-03 16:59:55.319warnmmwave ignoring getBatteryPercentageResult (600)
dev:26582023-05-03 16:59:55.317debugmmwave Tuya battery status report dp_id=2 dp=4 fncmd=300
dev:26582023-05-03 16:59:55.315debugmmwave Tuya cluster: dp_id=2 dp=4 fncmd=300
dev:26582023-05-03 16:59:55.313debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 0014040200040000012C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 14, 04, 02, 00, 04, 00, 00, 01, 2C]]
dev:26582023-05-03 16:59:55.269warnmmwave ignoring getBatteryPercentageResult (600)
dev:26582023-05-03 16:59:55.267debugmmwave Tuya battery status report dp_id=2 dp=4 fncmd=300
dev:26582023-05-03 16:59:55.265debugmmwave Tuya cluster: dp_id=2 dp=4 fncmd=300
dev:26582023-05-03 16:59:55.262debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 0013040200040000012C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 13, 04, 02, 00, 04, 00, 00, 01, 2C]]
dev:26582023-05-03 16:59:55.231warnmmwave ignoring getBatteryPercentageResult (600)
dev:26582023-05-03 16:59:55.229debugmmwave Tuya battery status report dp_id=2 dp=4 fncmd=300
dev:26582023-05-03 16:59:55.227debugmmwave Tuya cluster: dp_id=2 dp=4 fncmd=300
dev:26582023-05-03 16:59:55.224debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 0012040200040000012C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 12, 04, 02, 00, 04, 00, 00, 01, 2C]]
dev:26582023-05-03 16:59:55.180warnmmwave ignoring getBatteryPercentageResult (600)
dev:26582023-05-03 16:59:55.178debugmmwave Tuya battery status report dp_id=2 dp=4 fncmd=300
dev:26582023-05-03 16:59:55.172debugmmwave Tuya cluster: dp_id=2 dp=4 fncmd=300
dev:26582023-05-03 16:59:55.170debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 0011040200040000012C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 11, 04, 02, 00, 04, 00, 00, 01, 2C]]
dev:26582023-05-03 16:59:55.064warnmmwave ignoring getBatteryPercentageResult (600)
dev:26582023-05-03 16:59:55.061debugmmwave Tuya battery status report dp_id=2 dp=4 fncmd=300
dev:26582023-05-03 16:59:55.058debugmmwave Tuya cluster: dp_id=2 dp=4 fncmd=300
dev:26582023-05-03 16:59:55.055debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 0010040200040000012C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 10, 04, 02, 00, 04, 00, 00, 01, 2C]]
dev:26582023-05-03 16:59:55.009warnmmwave non-radar event 3 fncmd = 20
dev:26582023-05-03 16:59:55.007debugmmwave Tuya cluster: dp_id=2 dp=3 fncmd=20
dev:26582023-05-03 16:59:55.004debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 000F0302000400000014, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0F, 03, 02, 00, 04, 00, 00, 00, 14]]
dev:26582023-05-03 16:59:54.963warnmmwave non-radar event 3 fncmd = 20
dev:26582023-05-03 16:59:54.961debugmmwave Tuya cluster: dp_id=2 dp=3 fncmd=20
dev:26582023-05-03 16:59:54.958debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 000E0302000400000014, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0E, 03, 02, 00, 04, 00, 00, 00, 14]]
dev:26582023-05-03 16:59:54.906warnmmwave non-radar event 3 fncmd = 20
dev:26582023-05-03 16:59:54.904debugmmwave Tuya cluster: dp_id=2 dp=3 fncmd=20
dev:26582023-05-03 16:59:54.902debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 000D0302000400000014, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0D, 03, 02, 00, 04, 00, 00, 00, 14]]
dev:26582023-05-03 16:59:54.854warnmmwave non-radar event 3 fncmd = 20
dev:26582023-05-03 16:59:54.852debugmmwave Tuya cluster: dp_id=2 dp=3 fncmd=20
dev:26582023-05-03 16:59:54.850debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 000C0302000400000014, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0C, 03, 02, 00, 04, 00, 00, 00, 14]]
dev:26582023-05-03 16:59:54.804warnmmwave non-radar event 3 fncmd = 20
dev:26582023-05-03 16:59:54.801debugmmwave Tuya cluster: dp_id=2 dp=3 fncmd=20
dev:26582023-05-03 16:59:54.799debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 000B0302000400000014, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0B, 03, 02, 00, 04, 00, 00, 00, 14]]
dev:26582023-05-03 16:59:54.752warnmmwave mmwave non-radar event 2 fncmd = 8
dev:26582023-05-03 16:59:54.750debugmmwave Tuya cluster: dp_id=2 dp=2 fncmd=8
dev:26582023-05-03 16:59:54.747debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 000A0202000400000008, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0A, 02, 02, 00, 04, 00, 00, 00, 08]]
dev:26582023-05-03 16:59:54.703warnmmwave mmwave non-radar event 2 fncmd = 8
dev:26582023-05-03 16:59:54.700debugmmwave Tuya cluster: dp_id=2 dp=2 fncmd=8
dev:26582023-05-03 16:59:54.698debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00090202000400000008, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 09, 02, 02, 00, 04, 00, 00, 00, 08]]
dev:26582023-05-03 16:59:54.653warnmmwave mmwave non-radar event 2 fncmd = 8
dev:26582023-05-03 16:59:54.650debugmmwave Tuya cluster: dp_id=2 dp=2 fncmd=8
dev:26582023-05-03 16:59:54.648debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00080202000400000008, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 08, 02, 02, 00, 04, 00, 00, 00, 08]]
dev:26582023-05-03 16:59:54.605warnmmwave mmwave non-radar event 2 fncmd = 8
dev:26582023-05-03 16:59:54.603debugmmwave Tuya cluster: dp_id=2 dp=2 fncmd=8
dev:26582023-05-03 16:59:54.601debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00070202000400000008, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 07, 02, 02, 00, 04, 00, 00, 00, 08]]
dev:26582023-05-03 16:59:54.559warnmmwave mmwave non-radar event 2 fncmd = 8
dev:26582023-05-03 16:59:54.557debugmmwave Tuya cluster: dp_id=2 dp=2 fncmd=8
dev:26582023-05-03 16:59:54.554debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00060202000400000008, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 06, 02, 02, 00, 04, 00, 00, 00, 08]]
dev:26582023-05-03 16:59:54.500infommwave Motion is active 0s
dev:26582023-05-03 16:59:54.498debugmmwave (DP=0x01) motion event fncmd = 1
dev:26582023-05-03 16:59:54.496debugmmwave Tuya cluster: dp_id=4 dp=1 fncmd=1
dev:26582023-05-03 16:59:54.493debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00050104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 05, 01, 04, 00, 01, 01]]
dev:26582023-05-03 16:59:54.450infommwave Motion is active 0s
dev:26582023-05-03 16:59:54.447debugmmwave (DP=0x01) motion event fncmd = 1
dev:26582023-05-03 16:59:54.445debugmmwave Tuya cluster: dp_id=4 dp=1 fncmd=1
dev:26582023-05-03 16:59:54.443debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00040104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 04, 01, 04, 00, 01, 01]]
dev:26582023-05-03 16:59:54.384infommwave Detected motion
dev:26582023-05-03 16:59:54.382debugmmwave (DP=0x01) motion event fncmd = 1
dev:26582023-05-03 16:59:54.379debugmmwave Tuya cluster: dp_id=4 dp=1 fncmd=1
dev:26582023-05-03 16:59:54.377debugmmwave parse (_TZE204_sooucan5, 1.3.2 2023/04/17 8:48 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2C71 01 00 0000 02 01 00030104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2C71, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 03, 01, 04, 00, 01, 01]]
No, I do not have a Tuya Zigbee hub.
