looking very good.
found correct device profile.. no errors. seems to be ignoring luminence under my threshold now and battery..
ie
looking very good.
ie
Hello
i have bought one of those low cost tuya zigbee motion sensor and cant get it work with any driver i have found
i shared logs :
2023-03-24 08:42:50.410debugPur2 ignored resetToMotionInactive (software timeout) after 31s
dev:5632023-03-24 08:42:19.173debugPur2 sendZigbeeCommands (cmd=[he raw 0xEDAF 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xEDAF 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, he wattr 0xEDAF 0x01 0x0500 0x0010 0xF0 {8A4E4216006F0D00}, delay 2000, he raw 0xEDAF 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0xEDAF 1 0x01 0x0500 {10 00 00 00 00}, delay 2000])
and data from the sensor
_TZ3000_6ygjfyll
Endpoint 01 application: 46
Endpoint 01 endpointId: 01
Endpoint 01 idAsInt: 1
Endpoint 01 inClusters: 0001,0500,0003,0000
Endpoint 01 initialized: true
Endpoint 01 manufacturer: _TZ3000_6ygjfyll
Endpoint 01 model: TS0202
Endpoint 01 outClusters: 1000,0006,0019,000A
Endpoint 01 profileId: 0104
Endpoint 01 stage: 4
any help ?
Hi Kossev still me
Hi @pfacelina ,
As in the other thread - first try to check whether this sensor stays connected to Hubitat.
If you change the driver to the inbuilt one named 'Device' and you trigger a motion detection - do you see any events in the live logs?
That's a good sign - the device is paired and is communicating to the HE hub,
Next, check whether you are using the latest driver version. The faster way to do it is to click on the Import button within the driver editor, then click on Save.
Next - click on the Initialize button and wake up the sensor at the same time. If it doesn't work, pair it again to HE without deleting it.
sorry for beeing that bad but can you put a link
The link to the latest driver version is in the second post of this thread.
What I proposed to you as an alternative of updating the driver from a link is this :
What presence you need?
with you answer i guess active should switch to inactive but nothing change
Some Tuya (and not only) motion sensors do not report 'motion inactive'. I don't have the same device as yours, so I don't know how it should operate. But you can use these options in the driver :
thanks for your help but dont get any changing status on this so usless
thanks again kossev i have to go .
i will dig on to that later will feed you back after
When you have a chance, pair it again to HE with this driver (without deleting it) - do it really close to the hub, less than 1 meter away. Some Tuya sensors are difficult to pair from the first attempt, make several tries..
Good luck!
Dev version did not fix the motion. Two logs attached, so you see when should the motion activate.
dev:7982023-03-26 08:03:06.294infoTuya 2 in 1 liike ja hämärätunnistin Tuya check-in (application version is 43)
dev:7982023-03-26 08:03:06.289debugTuya 2 in 1 liike ja hämärätunnistin parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:FF380100001801002043E2FF2022E4FF2000, dni:FF38, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1, additionalAttrs:[[value:22, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:7982023-03-26 07:46:25.343infoTuya 2 in 1 liike ja hämärätunnistin battery is 100 %
dev:7982023-03-26 07:46:25.318debugTuya 2 in 1 liike ja hämärätunnistin Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:7982023-03-26 07:46:25.317debugTuya 2 in 1 liike ja hämärätunnistin Tuya cluster: dp_id=2 dp=4 fncmd=100
dev:7982023-03-26 07:46:25.295debugTuya 2 in 1 liike ja hämärätunnistin parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 FF38 01 00 0000 02 01 00C20402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FF38, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C2, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:7982023-03-26 07:30:20.226infoTuya 2 in 1 liike ja hämärätunnistin Illuminance is 1000 Lux
dev:7982023-03-26 07:30:20.206debugTuya 2 in 1 liike ja hämärätunnistin Tuya cluster: dp_id=2 dp=12 fncmd=1000
dev:7982023-03-26 07:30:20.194debugTuya 2 in 1 liike ja hämärätunnistin parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 FF38 01 00 0000 02 01 00C10C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FF38, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C1, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:7982023-03-26 07:12:33.019debugTuya 2 in 1 liike ja hämärätunnistin deviceHealthCheck - online (notPresentCounter=1)
dev:7982023-03-26 07:00:20.947infoTuya 2 in 1 liike ja hämärätunnistin Illuminance is 634 Lux
dev:7982023-03-26 07:00:20.925debugTuya 2 in 1 liike ja hämärätunnistin Tuya cluster: dp_id=2 dp=12 fncmd=634
dev:7982023-03-26 07:00:20.913debugTuya 2 in 1 liike ja hämärätunnistin parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 FF38 01 00 0000 02 01 00C00C0200040000027A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FF38, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, C0, 0C, 02, 00, 04, 00, 00, 02, 7A]]
dev:7982023-03-26 06:30:21.714infoTuya 2 in 1 liike ja hämärätunnistin Illuminance is 6 Lux
dev:7982023-03-26 06:30:21.689debugTuya 2 in 1 liike ja hämärätunnistin Tuya cluster: dp_id=2 dp=12 fncmd=6
dev:7982023-03-26 06:30:21.677debugTuya 2 in 1 liike ja hämärätunnistin parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 FF38 01 00 0000 02 01 00BF0C02000400000006, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FF38, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, BF, 0C, 02, 00, 04, 00, 00, 00, 06]]
dev:7982023-03-26 06:02:39.813infoTuya 2 in 1 liike ja hämärätunnistin Tuya check-in (application version is 43)
dev:7982023-03-26 06:02:39.808debugTuya 2 in 1 liike ja hämärätunnistin parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:FF380100001801002043E2FF2022E4FF2000, dni:FF38, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1, additionalAttrs:[[value:22, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:7982023-03-26 06:00:22.304debugTuya 2 in 1 liike ja hämärätunnistin Ignored illuminance event 0 % - change is less than 1 threshold!
dev:7982023-03-26 06:00:22.295debugTuya 2 in 1 liike ja hämärätunnistin Tuya cluster: dp_id=2 dp=12 fncmd=0
dev:7982023-03-26 06:00:22.289debugTuya 2 in 1 liike ja hämärätunnistin parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 FF38 01 00 0000 02 01 00BE0C02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:FF38, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, BE, 0C, 02, 00, 04, 00, 00, 00, 00]]
dev:7992023-03-26 08:26:59.363infoTuya TS0202 Motion Sensor Motion reset to inactive after 82s
dev:7992023-03-26 08:26:59.360debugTuya TS0202 Motion Sensor Zone status: zone status 0x0000 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:7992023-03-26 08:26:59.359debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [:]
dev:7992023-03-26 08:26:37.094infoTuya TS0202 Motion Sensor Motion is active 60s
dev:7992023-03-26 08:26:37.089debugTuya TS0202 Motion Sensor Zone status: zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:7992023-03-26 08:26:37.087debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [:]
dev:7992023-03-26 08:25:37.130infoTuya TS0202 Motion Sensor Detected motion
dev:7992023-03-26 08:25:37.123debugTuya TS0202 Motion Sensor Zone status: zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:7992023-03-26 08:25:37.121debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [:]
dev:7992023-03-26 08:12:04.159infoTuya TS0202 Motion Sensor Motion reset to inactive after 76s
dev:7992023-03-26 08:12:04.156debugTuya TS0202 Motion Sensor Zone status: zone status 0x0000 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:7992023-03-26 08:12:04.155debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [:]
dev:7992023-03-26 08:11:48.097infoTuya TS0202 Motion Sensor Motion is active 60s
dev:7992023-03-26 08:11:48.093debugTuya TS0202 Motion Sensor Zone status: zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:7992023-03-26 08:11:48.092debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [:]
dev:7992023-03-26 08:10:48.155infoTuya TS0202 Motion Sensor Detected motion
dev:7992023-03-26 08:10:48.148debugTuya TS0202 Motion Sensor Zone status: zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:7992023-03-26 08:10:48.146debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [:]
dev:7992023-03-26 07:58:13.279debugTuya TS0202 Motion Sensor sendZigbeeCommands (cmd=[he raw 0x985E 1 0x01 0x0000 {10 00 00 07 00}, delay 200, he raw 0x985E 1 0x01 0x0001 {10 00 00 20 00}, delay 200, he raw 0x985E 1 0x01 0x0001 {10 00 00 21 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 00 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 01 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 02 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 10 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 11 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 12 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 13 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 01 F0}, delay 200])
dev:7992023-03-26 07:58:13.261infoTuya TS0202 Motion Sensor refresh()...
dev:7992023-03-26 07:58:12.235infoTuya TS0202 Motion Sensor Initialization finished
version=1.3.0 (Timestamp: 2023/03/22 2:45 PM)
dev:7992023-03-26 07:58:12.233infoTuya TS0202 Motion Sensor manufacturer = _TZ3000_6ygjfyll
dev:7992023-03-26 07:58:11.958debugTuya TS0202 Motion Sensor sendZigbeeCommands (cmd=[he raw 0x985E 1 0x01 0x0000 {10 00 00 07 00}, delay 200, he raw 0x985E 1 0x01 0x0001 {10 00 00 20 00}, delay 200, he raw 0x985E 1 0x01 0x0001 {10 00 00 21 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 00 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 01 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 02 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 10 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 11 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 12 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 13 00}, delay 200, he raw 0x985E 1 0x01 0x0500 {10 00 00 01 F0}, delay 200])
dev:7992023-03-26 07:58:11.937infoTuya TS0202 Motion Sensor refresh()...
dev:7992023-03-26 07:58:10.353infoTuya TS0202 Motion Sensor preferencies updates are sent to the device...
dev:7992023-03-26 07:58:10.350debugTuya TS0202 Motion Sensor sendZigbeeCommands (cmd=[he wattr 0x985E 0x01 0x0500 0x0013 0x20 {02} {}, delay 200, he wattr 0x985E 0x01 0x0500 0xF001 0x20 {00} {}, delay 200])
dev:7992023-03-26 07:58:10.349debugTuya TS0202 Motion Sensor sending the changed AdvancedOptions
dev:7992023-03-26 07:58:10.348debugTuya TS0202 Motion Sensor changing IAS Keep Time to : 10 seconds (0)
dev:7992023-03-26 07:58:10.346debugTuya TS0202 Motion Sensor Tuya TS0202 Motion Sensor sending IAS Keep Time : 10 seconds (0)
dev:7992023-03-26 07:58:10.339debugTuya TS0202 Motion Sensor Tuya TS0202 Motion Sensor sending IAS sensitivity : high (2)
dev:7992023-03-26 07:58:10.330debugTuya TS0202 Motion Sensor changing IAS sensitivity to : high (2)
dev:7992023-03-26 07:58:10.326debugTuya TS0202 Motion Sensor state.deviceProfile=TS0202_MOTION_IAS, settings.forcedProfile=Tuya TS0202 Motion sensor (IAS), getProfileKey()=TS0202_MOTION_IAS
dev:7992023-03-26 07:58:10.303infoTuya TS0202 Motion Sensor Debug logging is will be turned off after 24 hours
dev:7992023-03-26 07:58:10.283infoTuya TS0202 Motion Sensor Debug logging is true; Description text logging is true
dev:7992023-03-26 07:58:10.281infoTuya TS0202 Motion Sensor Updating Tuya TS0202 Motion Sensor (Tuya TS0202 Motion Sensor) model TS0202 manufacturer _TZ3000_6ygjfyll deviceProfile=TS0202_MOTION_IAS
dev:7992023-03-26 07:58:10.279infoTuya TS0202 Motion Sensor updated()...
dev:7992023-03-26 07:58:09.185debugTuya TS0202 Motion Sensor sendZigbeeCommands (cmd=[he raw 0x985E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x985E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, he wattr 0x985E 0x01 0x0500 0x0010 0xF0 {DA4B7F16006F0D00}, delay 2000, he raw 0x985E 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0x985E 1 0x01 0x0500 {10 00 00 00 00}, delay 2000])
dev:7992023-03-26 07:58:09.182debugEnrolling IAS device: [he raw 0x985E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x985E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, he wattr 0x985E 0x01 0x0500 0x0010 0xF0 {DA4B7F16006F0D00}, delay 2000, he raw 0x985E 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0x985E 1 0x01 0x0500 {10 00 00 00 00}, delay 2000]
dev:7992023-03-26 07:58:09.110infoTuya TS0202 Motion Sensor configure()..
dev:7992023-03-26 07:58:09.029infoTuya TS0202 Motion Sensor device model TS0202 manufacturer _TZ3000_6ygjfyll was set to : deviceProfile=TS0202_MOTION_IAS : deviceName=Tuya TS0202 Motion Sensor
dev:7992023-03-26 07:58:09.013debugTuya TS0202 Motion Sensor found exact match for model TS0202 manufacturer _TZ3000_6ygjfyll : profileName=TS0202_MOTION_IAS deviceName =Tuya TS0202 Motion Sensor
dev:7992023-03-26 07:58:08.996infoTuya TS0202 Motion Sensor Tuya TS0202 Motion Sensor InitializeVars( fullInit = true )...
dev:7992023-03-26 07:58:08.975infoTuya TS0202 Motion Sensor Initialize( fullInit = true )...
dev:7992023-03-26 07:58:06.821debugTuya TS0202 Motion Sensor sendZigbeeCommands (cmd=[he raw 0x985E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x985E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, he wattr 0x985E 0x01 0x0500 0x0010 0xF0 {DA4B7F16006F0D00}, delay 2000, he raw 0x985E 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0x985E 1 0x01 0x0500 {10 00 00 00 00}, delay 2000])
dev:7992023-03-26 07:58:06.813debugEnrolling IAS device: [he raw 0x985E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x985E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, he wattr 0x985E 0x01 0x0500 0x0010 0xF0 {DA4B7F16006F0D00}, delay 2000, he raw 0x985E 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0x985E 1 0x01 0x0500 {10 00 00 00 00}, delay 2000]
dev:7992023-03-26 07:58:06.768infoTuya TS0202 Motion Sensor configure()..
dev:7992023-03-26 07:46:58.301infoTuya TS0202 Motion Sensor battery is 100 %
dev:7992023-03-26 07:46:58.294debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:985E01000110210020C82000201D, dni:985E, endpoint:01, cluster:0001, size:10, attrId:0021, encoding:20, command:0A, value:C8, clusterInt:1, attrInt:33, additionalAttrs:[[value:1D, encoding:20, attrId:0020, consumedBytes:4, attrInt:32]]]
dev:7992023-03-26 07:12:56.430debugTuya TS0202 Motion Sensor ignored resetToMotionInactive (software timeout) after 120s
dev:7992023-03-26 07:12:09.223infoTuya TS0202 Motion Sensor Motion reset to inactive after 73s
dev:7992023-03-26 07:12:09.220debugTuya TS0202 Motion Sensor Zone status: zone status 0x0000 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:7992023-03-26 07:12:09.219debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [:]
dev:7992023-03-26 07:11:56.433infoTuya TS0202 Motion Sensor Motion is active 60s
dev:7992023-03-26 07:11:56.409debugTuya TS0202 Motion Sensor Zone status: zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:7992023-03-26 07:11:56.408debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [:]
dev:7992023-03-26 07:11:24.020debugTuya TS0202 Motion Sensor deviceHealthCheck - online (notPresentCounter=1)
dev:7992023-03-26 07:10:56.467infoTuya TS0202 Motion Sensor Detected motion
dev:7992023-03-26 07:10:56.441debugTuya TS0202 Motion Sensor Zone status: zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:7992023-03-26 07:10:56.440debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [:]
dev:7992023-03-26 07:10:35.429infoTuya TS0202 Motion Sensor Motion reset to inactive after 85s
dev:7992023-03-26 07:10:35.426debugTuya TS0202 Motion Sensor Zone status: zone status 0x0000 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:7992023-03-26 07:10:35.425debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [:]
dev:7992023-03-26 07:10:10.383infoTuya TS0202 Motion Sensor Motion is active 60s
dev:7992023-03-26 07:10:10.344debugTuya TS0202 Motion Sensor Zone status: zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:7992023-03-26 07:10:10.343debugTuya TS0202 Motion Sensor parse (_TZ3000_6ygjfyll, 1.3.0 2023/03/22 2:45 PM) descMap = [:]
dev:7992023-03-26 07:09:10.481infoTuya TS0202 Motion Sensor Detected motion
dev:7992023-03-26 07:09:10.454debugTuya TS0202 Motion Sensor Zone status: zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
finaly got it to work and now i have information when active and inactive
thanks all
Hi @petteri.joutseno ,
as I don't see a way to distinguish automatically between the same models same application versions that send inverted or normal motion events, in the next driver update I will add an explicit option to invert it. I will notify you when the new option is available for testing.
Update: can you test the option in the latest beta version? ( ver. 1.3.1 2023/03/29 12:43 PM) :
@petteri.joutseno did the latest version work for your sensor?
Do you have the 'Invert Motion' toggle on or off?
No help with inverted. I’ll get Tuya hubs. Hopefully Tuya integration works with those.
@kkossev,
My driver was pointing to the development driver.
I noticed this morning that the Tuya sensor, TS0601, was always active.
Note this sensor is only used to turn off a bedroom light if let on for too long, not for activation purposes.
Anyway, I messed around with a bit and removed and re-inserted the battery. And, I think after that I observed that the motion kept on activating and deactivating with lux value.
In summary, I could not get it to work with the latest development version and had to revert back to the stable version (worked after removing the device and re-pairing, the same did not work with the development version).
Not sure how helpful the logs will be as I kept changing between stable and development version.
dev:17832023-04-01 03:08:06.518 PMinfoSamah's room sensor Motion reset to inactive after 66s
dev:17832023-04-01 03:08:06.516 PMdebugSamah's room sensor (DP=0x01) motion event fncmd = 1
dev:17832023-04-01 03:08:06.514 PMdebugSamah's room sensor Tuya cluster: dp_id=4 dp=1 fncmd=1
dev:17832023-04-01 03:08:06.510 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00330104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 33, 01, 04, 00, 01, 01]]
dev:17832023-04-01 03:08:06.296 PMinfoSamah's room sensor Illuminance is 104 Lux
dev:17832023-04-01 03:08:06.292 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=12 fncmd=104
dev:17832023-04-01 03:08:06.287 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00320C02000400000068, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 32, 0C, 02, 00, 04, 00, 00, 00, 68]]
dev:17832023-04-01 03:07:00.468 PMinfoSamah's room sensor Detected motion
dev:17832023-04-01 03:07:00.466 PMdebugSamah's room sensor (DP=0x01) motion event fncmd = 0
dev:17832023-04-01 03:07:00.465 PMdebugSamah's room sensor Tuya cluster: dp_id=4 dp=1 fncmd=0
dev:17832023-04-01 03:07:00.460 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00310104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 31, 01, 04, 00, 01, 00]]
dev:17832023-04-01 03:07:00.260 PMdebugSamah's room sensor Ignored illuminance event 98 % - change is less than 1 threshold!
dev:17832023-04-01 03:07:00.257 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=12 fncmd=98
dev:17832023-04-01 03:07:00.252 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00300C02000400000062, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 30, 0C, 02, 00, 04, 00, 00, 00, 62]]
dev:17832023-04-01 03:06:35.542 PMinfoSamah's room sensor Motion reset to inactive after 16s
dev:17832023-04-01 03:06:35.540 PMdebugSamah's room sensor (DP=0x01) motion event fncmd = 1
dev:17832023-04-01 03:06:35.538 PMdebugSamah's room sensor Tuya cluster: dp_id=4 dp=1 fncmd=1
dev:17832023-04-01 03:06:35.534 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 002F0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 2F, 01, 04, 00, 01, 01]]
dev:17832023-04-01 03:06:35.322 PMinfoSamah's room sensor Illuminance is 98 Lux
dev:17832023-04-01 03:06:35.318 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=12 fncmd=98
dev:17832023-04-01 03:06:35.313 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 002E0C02000400000062, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 2E, 0C, 02, 00, 04, 00, 00, 00, 62]]
dev:17832023-04-01 03:06:19.574 PMinfoSamah's room sensor Detected motion
dev:17832023-04-01 03:06:19.572 PMdebugSamah's room sensor (DP=0x01) motion event fncmd = 0
dev:17832023-04-01 03:06:19.571 PMdebugSamah's room sensor Tuya cluster: dp_id=4 dp=1 fncmd=0
dev:17832023-04-01 03:06:19.566 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 002D0104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 2D, 01, 04, 00, 01, 00]]
dev:17832023-04-01 03:06:19.282 PMinfoSamah's room sensor Illuminance is 95 Lux
dev:17832023-04-01 03:06:19.278 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=12 fncmd=95
dev:17832023-04-01 03:06:19.273 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 002C0C0200040000005F, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 2C, 0C, 02, 00, 04, 00, 00, 00, 5F]]
dev:17832023-04-01 03:06:09.664 PMinfoSamah's room sensor Motion reset to inactive after 59s
dev:17832023-04-01 03:06:09.662 PMdebugSamah's room sensor (DP=0x01) motion event fncmd = 1
dev:17832023-04-01 03:06:09.660 PMdebugSamah's room sensor Tuya cluster: dp_id=4 dp=1 fncmd=1
dev:17832023-04-01 03:06:09.656 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 002B0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 2B, 01, 04, 00, 01, 01]]
dev:17832023-04-01 03:06:09.451 PMdebugSamah's room sensor Ignored illuminance event 97 % - change is less than 1 threshold!
dev:17832023-04-01 03:06:09.448 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=12 fncmd=97
dev:17832023-04-01 03:06:09.396 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 002A0C02000400000061, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 2A, 0C, 02, 00, 04, 00, 00, 00, 61]]
dev:17832023-04-01 03:06:08.916 PMinfoSamah's room sensor Received device announcement, data=[07, E5, E0, 8C, FA, 38, 14, C0, 38, C1, A4, 80] (Sequence Number:07, Device network ID: E0E5, Capability Information: 80)
dev:17832023-04-01 03:06:08.911 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0000 0013 00 00 0040 00 E0E5 00 00 0000 00 00 07E5E08CFA3814C038C1A480, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[07, E5, E0, 8C, FA, 38, 14, C0, 38, C1, A4, 80]]
dev:17832023-04-01 03:06:08.212 PMdebugSamah's room sensor Ignored illuminance event 97 % - change is less than 1 threshold!
dev:17832023-04-01 03:06:08.209 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=12 fncmd=97
dev:17832023-04-01 03:06:08.204 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 002A0C02000400000061, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 2A, 0C, 02, 00, 04, 00, 00, 00, 61]]
dev:17832023-04-01 03:06:07.063 PMinfoSamah's room sensor Illuminance is 97 Lux
dev:17832023-04-01 03:06:07.060 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=12 fncmd=97
dev:17832023-04-01 03:06:07.053 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 002A0C02000400000061, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 2A, 0C, 02, 00, 04, 00, 00, 00, 61]]
dev:17832023-04-01 03:05:25.765 PMdebugSamah's room sensor Tuya check-in (cluster revision=Òôº+Òôº+Òõº+Uöº+Uöº+)
dev:17832023-04-01 03:05:25.761 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E50100004EDFFF4223D2F4BA2B13D2F4BA2B12D2F5BA2B120000000011000000001155F6BA2B1355F6BA2B12, dni:E0E5, endpoint:01, cluster:0000, size:4E, attrId:FFDF, encoding:42, command:0A, value:Òôº+Òôº+Òõº+Uöº+Uöº+, clusterInt:0, attrInt:65503]
dev:17832023-04-01 03:05:10.275 PMinfoSamah's room sensor Detected motion
dev:17832023-04-01 03:05:10.273 PMdebugSamah's room sensor (DP=0x01) motion event fncmd = 0
dev:17832023-04-01 03:05:10.272 PMdebugSamah's room sensor Tuya cluster: dp_id=4 dp=1 fncmd=0
dev:17832023-04-01 03:05:10.267 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00290104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 29, 01, 04, 00, 01, 00]]
dev:17832023-04-01 03:05:10.062 PMdebugSamah's room sensor Ignored illuminance event 826 % - change is less than 1 threshold!
dev:17832023-04-01 03:05:10.060 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=12 fncmd=826
dev:17832023-04-01 03:05:10.054 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00280C0200040000033A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 28, 0C, 02, 00, 04, 00, 00, 03, 3A]]
dev:17832023-04-01 03:05:09.166 PMinfoSamah's room sensor Motion reset to inactive after 14s
dev:17832023-04-01 03:05:09.164 PMdebugSamah's room sensor (DP=0x01) motion event fncmd = 1
dev:17832023-04-01 03:05:09.163 PMdebugSamah's room sensor Tuya cluster: dp_id=4 dp=1 fncmd=1
dev:17832023-04-01 03:05:09.158 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00270104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 27, 01, 04, 00, 01, 01]]
dev:17832023-04-01 03:05:08.949 PMinfoSamah's room sensor Illuminance is 826 Lux
dev:17832023-04-01 03:05:08.945 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=12 fncmd=826
dev:17832023-04-01 03:05:08.940 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00260C0200040000033A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 26, 0C, 02, 00, 04, 00, 00, 03, 3A]]
dev:17832023-04-01 03:05:07.157 PMinfoSamah's room sensor battery is 100 %
dev:17832023-04-01 03:05:07.155 PMdebugSamah's room sensor Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:17832023-04-01 03:05:07.154 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=4 fncmd=100
dev:17832023-04-01 03:05:07.149 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00250402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 25, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:17832023-04-01 03:04:57.178 PMinfoSamah's room sensor battery is 100 %
dev:17832023-04-01 03:04:57.175 PMdebugSamah's room sensor Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:17832023-04-01 03:04:57.174 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=4 fncmd=100
dev:17832023-04-01 03:04:57.169 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00240402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 24, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:17832023-04-01 03:04:55.116 PMinfoSamah's room sensor Detected motion
dev:17832023-04-01 03:04:55.114 PMdebugSamah's room sensor (DP=0x01) motion event fncmd = 0
dev:17832023-04-01 03:04:55.112 PMdebugSamah's room sensor Tuya cluster: dp_id=4 dp=1 fncmd=0
dev:17832023-04-01 03:04:55.108 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00230104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 23, 01, 04, 00, 01, 00]]
dev:17832023-04-01 03:04:54.909 PMdebugSamah's room sensor Ignored illuminance event 850 % - change is less than 1 threshold!
dev:17832023-04-01 03:04:54.906 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=12 fncmd=850
dev:17832023-04-01 03:04:54.901 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00220C02000400000352, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 22, 0C, 02, 00, 04, 00, 00, 03, 52]]
dev:17832023-04-01 03:04:53.644 PMinfoSamah's room sensor Motion reset to inactive after 7s
dev:17832023-04-01 03:04:53.642 PMdebugSamah's room sensor (DP=0x01) motion event fncmd = 1
dev:17832023-04-01 03:04:53.641 PMdebugSamah's room sensor Tuya cluster: dp_id=4 dp=1 fncmd=1
dev:17832023-04-01 03:04:53.636 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00210104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 21, 01, 04, 00, 01, 01]]
dev:17832023-04-01 03:04:53.420 PMdebugSamah's room sensor Ignored illuminance event 850 % - change is less than 1 threshold!
dev:17832023-04-01 03:04:53.417 PMdebugSamah's room sensor Tuya cluster: dp_id=2 dp=12 fncmd=850
dev:17832023-04-01 03:04:53.412 PMdebugSamah's room sensor parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 00200C02000400000352, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 20, 0C, 02, 00, 04, 00, 00, 03, 52]]
dev:17832023-04-01 03:04:48.246 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL battery is 100 %
dev:17832023-04-01 03:04:48.243 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:17832023-04-01 03:04:48.241 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Tuya cluster: dp_id=2 dp=4 fncmd=100
dev:17832023-04-01 03:04:48.235 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 001F0402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1F, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:17832023-04-01 03:04:48.015 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Keep Time (dp=0x0A) is 30 seconds (0)
dev:17832023-04-01 03:04:48.013 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Tuya cluster: dp_id=4 dp=10 fncmd=0
dev:17832023-04-01 03:04:48.007 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 001E0A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1E, 0A, 04, 00, 01, 00]]
dev:17832023-04-01 03:04:47.797 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL received sensitivity : high (2)
dev:17832023-04-01 03:04:47.795 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Tuya cluster: dp_id=4 dp=9 fncmd=2
dev:17832023-04-01 03:04:47.789 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 001D0904000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1D, 09, 04, 00, 01, 02]]
dev:17832023-04-01 03:04:47.576 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL battery is 100 %
dev:17832023-04-01 03:04:47.573 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:17832023-04-01 03:04:47.571 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Tuya cluster: dp_id=2 dp=4 fncmd=100
dev:17832023-04-01 03:04:47.565 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 001C0402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1C, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:17832023-04-01 03:04:47.352 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Illuminance is 850 Lux
dev:17832023-04-01 03:04:47.349 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Tuya cluster: dp_id=2 dp=12 fncmd=850
dev:17832023-04-01 03:04:47.343 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 001B0C02000400000352, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1B, 0C, 02, 00, 04, 00, 00, 03, 52]]
dev:17832023-04-01 03:04:47.132 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Detected motion
dev:17832023-04-01 03:04:47.130 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL (DP=0x01) motion event fncmd = 0
dev:17832023-04-01 03:04:47.128 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Tuya cluster: dp_id=4 dp=1 fncmd=0
dev:17832023-04-01 03:04:47.122 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 02 01 001A0104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1A, 01, 04, 00, 01, 00]]
dev:17832023-04-01 03:04:44.141 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL NOT PARSED : descMap = [raw:catchall: 0104 0500 01 01 0040 00 E0E5 00 00 0000 01 01 01F086, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[01, F0, 86]]
dev:17832023-04-01 03:04:44.084 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 0500 01 01 0040 00 E0E5 00 00 0000 01 01 01F086, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[01, F0, 86]]
dev:17832023-04-01 03:04:43.812 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL NOT PARSED : descMap = [raw:catchall: 0104 0500 01 01 0040 00 E0E5 00 00 0000 01 01 130086, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[13, 00, 86]]
dev:17832023-04-01 03:04:43.807 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 0500 01 01 0040 00 E0E5 00 00 0000 01 01 130086, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[13, 00, 86]]
dev:17832023-04-01 03:04:43.687 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL NOT PARSED : descMap = [raw:catchall: 0104 0500 01 01 0040 00 E0E5 00 00 0000 01 01 120086, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[12, 00, 86]]
dev:17832023-04-01 03:04:43.682 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 0500 01 01 0040 00 E0E5 00 00 0000 01 01 120086, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[12, 00, 86]]
dev:17832023-04-01 03:04:43.527 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL IAS Zone Address received (bitmap = 1F378516006F0D00)
dev:17832023-04-01 03:04:43.522 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E5010500181000F01F378516006F0D00, dni:E0E5, endpoint:01, cluster:0500, size:18, attrId:0010, encoding:F0, command:01, value:1F378516006F0D00, clusterInt:1280, attrInt:16]
dev:17832023-04-01 03:04:43.437 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Motion reset to inactive after 6s
dev:17832023-04-01 03:04:43.433 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL IAS Zone status repoted: descMap=[raw:E0E50105000C0200190000, dni:E0E5, endpoint:01, cluster:0500, size:0C, attrId:0002, encoding:19, command:01, value:0000, clusterInt:1280, attrInt:2] value= 0
dev:17832023-04-01 03:04:43.429 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E50105000C0200190000, dni:E0E5, endpoint:01, cluster:0500, size:0C, attrId:0002, encoding:19, command:01, value:0000, clusterInt:1280, attrInt:2]
dev:17832023-04-01 03:04:43.181 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL IAS Zone Type repot is 'Fire Sensor' (40)
dev:17832023-04-01 03:04:43.177 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E50105000C0100312800, dni:E0E5, endpoint:01, cluster:0500, size:0C, attrId:0001, encoding:31, command:01, value:0028, clusterInt:1280, attrInt:1]
dev:17832023-04-01 03:04:42.946 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL IAS Zone State repot is 'Not Enrolled' (0)
dev:17832023-04-01 03:04:42.942 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E50105000A00003000, dni:E0E5, endpoint:01, cluster:0500, size:0A, attrId:0000, encoding:30, command:01, value:00, clusterInt:1280, attrInt:0]
dev:17832023-04-01 03:04:42.686 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL IAS Zone State repot is 'Not Enrolled' (0)
dev:17832023-04-01 03:04:42.682 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E50105000A00003000, dni:E0E5, endpoint:01, cluster:0500, size:0A, attrId:0000, encoding:30, command:01, value:00, clusterInt:1280, attrInt:0]
dev:17832023-04-01 03:04:42.607 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL battery is 0 %
dev:17832023-04-01 03:04:42.602 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E50100010A21002000, dni:E0E5, endpoint:01, cluster:0001, size:0A, attrId:0021, encoding:20, command:01, value:00, clusterInt:1, attrInt:33]
dev:17832023-04-01 03:04:42.358 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL IAS Zone State repot is 'Not Enrolled' (0)
dev:17832023-04-01 03:04:42.354 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E50105000A00003000, dni:E0E5, endpoint:01, cluster:0500, size:0A, attrId:0000, encoding:30, command:01, value:00, clusterInt:1280, attrInt:0]
dev:17832023-04-01 03:04:42.290 PMwarnTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL ignoring BatteryResult(0)
dev:17832023-04-01 03:04:42.288 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL batteryVoltage = 0.0 V
dev:17832023-04-01 03:04:42.285 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E50100010A20002000, dni:E0E5, endpoint:01, cluster:0001, size:0A, attrId:0020, encoding:20, command:01, value:00, clusterInt:1, attrInt:32]
dev:17832023-04-01 03:04:42.000 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL reported Power source battery (03)
dev:17832023-04-01 03:04:41.996 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E50100000A07003003, dni:E0E5, endpoint:01, cluster:0000, size:0A, attrId:0007, encoding:30, command:01, value:03, clusterInt:0, attrInt:7]
dev:17832023-04-01 03:04:41.887 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Keep Time (dp=0x0A) is 30 seconds (0)
dev:17832023-04-01 03:04:41.885 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Tuya cluster: dp_id=4 dp=10 fncmd=0
dev:17832023-04-01 03:04:41.880 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 01 01 00020A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 02, 0A, 04, 00, 01, 00]]
dev:17832023-04-01 03:04:41.864 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:17832023-04-01 03:04:41.859 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:17832023-04-01 03:04:41.707 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL sendZigbeeCommands (cmd=[he raw 0xE0E5 1 0x01 0x0000 {10 00 00 07 00}, delay 200, he raw 0xE0E5 1 0x01 0x0001 {10 00 00 20 00}, delay 200, he raw 0xE0E5 1 0x01 0x0001 {10 00 00 21 00}, delay 200, he raw 0xE0E5 1 0x01 0x0500 {10 00 00 00 00}, delay 200, he raw 0xE0E5 1 0x01 0x0500 {10 00 00 01 00}, delay 200, he raw 0xE0E5 1 0x01 0x0500 {10 00 00 02 00}, delay 200, he raw 0xE0E5 1 0x01 0x0500 {10 00 00 10 00}, delay 200, he raw 0xE0E5 1 0x01 0x0500 {10 00 00 11 00}, delay 200, he raw 0xE0E5 1 0x01 0x0500 {10 00 00 12 00}, delay 200, he raw 0xE0E5 1 0x01 0x0500 {10 00 00 13 00}, delay 200, he raw 0xE0E5 1 0x01 0x0500 {10 00 00 01 F0}, delay 200])
dev:17832023-04-01 03:04:41.683 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL refresh()...
dev:17832023-04-01 03:04:40.727 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL zigbee default command response cluster: IAS Zone (0x0500) cluster command: 0x00 status: success (0x00)
dev:17832023-04-01 03:04:40.721 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 0500 01 01 0040 00 E0E5 00 00 0000 0B 01 0000, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:17832023-04-01 03:04:40.662 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Initialization finished
dev:17832023-04-01 03:04:40.661 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL manufacturer = _TZE200_3towulqd
dev:17832023-04-01 03:04:40.645 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL zigbee default command response cluster: IAS Zone (0x0500) cluster command: 0x00 status: success (0x00)
dev:17832023-04-01 03:04:40.640 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 0500 01 01 0040 00 E0E5 00 00 0000 0B 01 0000, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:17832023-04-01 03:04:40.290 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL received sensitivity : high (2)
dev:17832023-04-01 03:04:40.288 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Tuya cluster: dp_id=4 dp=9 fncmd=2
dev:17832023-04-01 03:04:40.282 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 01 01 00010904000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 01, 09, 04, 00, 01, 02]]
dev:17832023-04-01 03:04:39.273 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL received sensitivity : high (2)
dev:17832023-04-01 03:04:39.270 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Tuya cluster: dp_id=4 dp=9 fncmd=2
dev:17832023-04-01 03:04:39.265 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 01 00 0000 01 01 00010904000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 01, 09, 04, 00, 01, 02]]
dev:17832023-04-01 03:04:39.232 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:17832023-04-01 03:04:39.227 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 E0E5 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:17832023-04-01 03:04:39.059 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL IAS write attribute response is success
dev:17832023-04-01 03:04:39.054 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 0500 01 01 0040 00 E0E5 00 00 0000 04 01 00, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:17832023-04-01 03:04:38.975 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL write attribute response is success
dev:17832023-04-01 03:04:38.971 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 0000 01 01 0040 00 E0E5 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:17832023-04-01 03:04:38.920 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL IAS write attribute response is success
dev:17832023-04-01 03:04:38.915 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 0500 01 01 0040 00 E0E5 00 00 0000 04 01 00, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:17832023-04-01 03:04:38.824 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL received device manufacturer _TZE200_3towulqd
dev:17832023-04-01 03:04:38.814 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E501000068040042105F545A453230305F33746F77756C71640000002003010000204305000042065453303630310700003003FEFF003000, dni:E0E5, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_3towulqd, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:43, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:17832023-04-01 03:04:38.792 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL write attribute response is success
dev:17832023-04-01 03:04:38.787 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:catchall: 0104 0000 01 01 0040 00 E0E5 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E0E5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:17832023-04-01 03:04:38.763 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL received device manufacturer _TZE200_3towulqd
dev:17832023-04-01 03:04:38.752 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL parse (_TZE200_3towulqd, 1.3.0 2023/03/22 2:45 PM) descMap = [raw:E0E501000068040042105F545A453230305F33746F77756C71640000002003010000204305000042065453303630310700003003FEFF003000, dni:E0E5, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_3towulqd, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:43, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:17832023-04-01 03:04:38.746 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL is present
dev:17832023-04-01 03:04:38.701 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL preferencies updates are sent to the device...
dev:17832023-04-01 03:04:38.696 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL sendZigbeeCommands (cmd=[he cmd 0xE0E5 0x01 0xEF00 0x00 {00010904000102}, delay 2000, he cmd 0xE0E5 0x01 0xEF00 0x00 {00020A04000100}, delay 2000])
dev:17832023-04-01 03:04:38.693 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL sending the changed AdvancedOptions
dev:17832023-04-01 03:04:38.691 PMwarnTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL changing TS0601 Keep Time to : 0
dev:17832023-04-01 03:04:38.688 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL sendTuyaCommand = [he cmd 0xE0E5 0x01 0xEF00 0x00 {00020A04000100}, delay 2000]
dev:17832023-04-01 03:04:38.684 PMwarnTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL changing TS0601 sensitivity to : 2
dev:17832023-04-01 03:04:38.682 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL sendTuyaCommand = [he cmd 0xE0E5 0x01 0xEF00 0x00 {00010904000102}, delay 2000]
dev:17832023-04-01 03:04:38.676 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL state.deviceProfile=TS0601_2IN1, settings.forcedProfile=Tuya 2in1 (Motion and Illuminance) sensor, getProfileKey()=TS0601_2IN1
dev:17832023-04-01 03:04:38.651 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Debug logging is will be turned off after 24 hours
dev:17832023-04-01 03:04:38.617 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Debug logging is true; Description text logging is true
dev:17832023-04-01 03:04:38.614 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL Updating null (Tuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL) model TS0601 manufacturer _TZE200_3towulqd deviceProfile=TS0601_2IN1
dev:17832023-04-01 03:04:38.611 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL updated()...
dev:17832023-04-01 03:04:37.796 PMdebugTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL sendZigbeeCommands (cmd=[he raw 0xE0E5 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xE0E5 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, he wattr 0xE0E5 0x01 0x0500 0x0010 0xF0 {1F378516006F0D00}, delay 2000, he raw 0xE0E5 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0xE0E5 1 0x01 0x0500 {10 00 00 00 00}, delay 2000])
dev:17832023-04-01 03:04:37.793 PMdebugEnrolling IAS device: [he raw 0xE0E5 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xE0E5 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, he wattr 0xE0E5 0x01 0x0500 0x0010 0xF0 {1F378516006F0D00}, delay 2000, he raw 0xE0E5 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0xE0E5 1 0x01 0x0500 {10 00 00 00 00}, delay 2000]
dev:17832023-04-01 03:04:37.704 PMinfoTuya 2 in 1 Zigbee Mini PIR Motion Detector + Bright Lux ZG-204ZL configure()..
dev:17832023-04-01 03:04:37.352 PMinfoTuya Multi Sensor 4 In 1 Initialize( fullInit = true )...
dev:17832023-04-01 03:04:37.350 PMinfoTuya Multi Sensor 4 In 1 installed()...
