[RELEASE] Tuya Zigbee Multi-Sensor 4 In 1 (PIR motion sensors) w/ healthStatus
Make sure you pair the sensor close to the hub.
I don't have this sensor, but yes - the motion should be reported always, regardless of the illuminance threshold.
Similar sensors report illuminance only when motion is detected, a few hundred milliseconds before the motion event is sent. But @user3874 wrote here that the illuminance is reported even without a motion detected!
Perfect pairing while I get everyting in place and pairing light stops on the device. Works as lux sensor, but does not detect any motion. Maybe nobody is trying to use motion while I’m first to report that.
This is possible ...
Please send some debug logs when there is a motion in front of the sensor.
(You can use the forum editor cog wheel tool to hide the logs in a summary section)
Summary
dev:6522023-02-05 16:28:15.521warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 910000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 910000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[91, 00, 00]]
dev:6522023-02-05 16:28:06.228warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 900000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 900000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[90, 00, 00]]
dev:6522023-02-05 16:27:56.945warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8F0000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8F0000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[8F, 00, 00]]
app:6332023-02-05 16:27:52.142debugHome Connect Integration processData: Home Connect CoffeeMaker - [event:KEEP-ALIVE, data:, id:BOSCH-CTL636EB6-68A40E4F6807]
app:6332023-02-05 16:27:52.139debugHome Connect Integration mapping: [event:KEEP-ALIVE, data:, id:BOSCH-CTL636EB6-68A40E4F6807]
app:6332023-02-05 16:27:52.136debugHome Connect Integration Received event: KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
app:6332023-02-05 16:27:52.133debugHome Connect Integration message: KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
app:6332023-02-05 16:27:52.130debugHome Connect Integration type: event
app:6332023-02-05 16:27:52.127debugHome Connect Integration processMessage from Home Connect CoffeeMaker message: event:KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
dev:6522023-02-05 16:27:47.649warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8E0000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8E0000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[8E, 00, 00]]
dev:7212023-02-05 16:27:45.716infoHome Connect Dryer Event: KEEP-ALIVE
dev:7202023-02-05 16:27:45.713infoHome Connect Washer Event: KEEP-ALIVE
app:6332023-02-05 16:27:45.710debugHome Connect Integration processData: Home Connect Washer - [event:KEEP-ALIVE, data:, id:BOSCH-WAYH2899SN-68A40E27EE5A]
app:6332023-02-05 16:27:45.707debugHome Connect Integration processData: Home Connect Dryer - [event:KEEP-ALIVE, data:, id:BOSCH-WTYH8789SN-68A40E26B505]
app:6332023-02-05 16:27:45.704debugHome Connect Integration mapping: [event:KEEP-ALIVE, data:, id:BOSCH-WAYH2899SN-68A40E27EE5A]
app:6332023-02-05 16:27:45.701debugHome Connect Integration mapping: [event:KEEP-ALIVE, data:, id:BOSCH-WTYH8789SN-68A40E26B505]
app:6332023-02-05 16:27:45.698debugHome Connect Integration Received event: KEEP-ALIVE data: id:BOSCH-WTYH8789SN-68A40E26B505
app:6332023-02-05 16:27:45.694debugHome Connect Integration Received event: KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
app:6332023-02-05 16:27:45.691debugHome Connect Integration message: KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
app:6332023-02-05 16:27:45.688debugHome Connect Integration message: KEEP-ALIVE data: id:BOSCH-WTYH8789SN-68A40E26B505
app:6332023-02-05 16:27:45.685debugHome Connect Integration type: event
app:6332023-02-05 16:27:45.682debugHome Connect Integration type: event
app:6332023-02-05 16:27:45.679debugHome Connect Integration processMessage from Home Connect Dryer message: event:KEEP-ALIVE data: id:BOSCH-WTYH8789SN-68A40E26B505
app:6332023-02-05 16:27:45.675debugHome Connect Integration processMessage from Home Connect Washer message: event:KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
dev:7212023-02-05 16:27:45.669debugHome Connect Dryer Received eventstream message: event:KEEP-ALIVE data: id:BOSCH-WTYH8789SN-68A40E26B505
dev:7202023-02-05 16:27:45.666debugHome Connect Washer Received eventstream message: event:KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
dev:292023-02-05 16:27:39.859infoLiikettä eteisessä: Detected motion
dev:292023-02-05 16:27:39.772infoLiikettä eteisessä: Illuminance is 6 lux
dev:6522023-02-05 16:27:38.353warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8D0000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8D0000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[8D, 00, 00]]
dev:8212023-02-05 16:27:34.513infoCar charger power is 2.100000000000000088817841970012523233890533447265625 W
dev:8202023-02-05 16:27:34.509infoCar charger power is 2.100000000000000088817841970012523233890533447265625 W
dev:8202023-02-05 16:27:34.506debugCar charger status [code:cur_power, t:1675607252, 19:21, value:21]
dev:8202023-02-05 16:27:34.503debugCar charger status [code:cur_current, t:1675607252, 18:16, value:16]
dev:8202023-02-05 16:27:34.500debugCar charger workMode
dev:8202023-02-05 16:27:34.497debugGroups: [Car charger:[[code:cur_current, t:1675607252, 18:16, value:16], [code:cur_power, t:1675607252, 19:21, value:21]]]
dev:8212023-02-05 16:27:29.473infoCar charger power is 0 W
dev:8202023-02-05 16:27:29.470debugCar charger status [code:cur_voltage, t:1675607247, value:2277, 20:2277]
dev:8202023-02-05 16:27:29.467infoCar charger power is 0 W
dev:8202023-02-05 16:27:29.464debugCar charger status [code:cur_power, t:1675607247, 19:0, value:0]
dev:8202023-02-05 16:27:29.462debugCar charger status [code:cur_current, t:1675607247, 18:0, value:0]
dev:8202023-02-05 16:27:29.459debugCar charger workMode
dev:8202023-02-05 16:27:29.456debugGroups: [Car charger:[[code:cur_current, t:1675607247, 18:0, value:0], [code:cur_power, t:1675607247, 19:0, value:0], [code:cur_voltage, t:1675607247, value:2277, 20:2277]]]
dev:6522023-02-05 16:27:29.060warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8C0000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8C0000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[8C, 00, 00]]
dev:8212023-02-05 16:27:28.465infoCar charger power is 2.100000000000000088817841970012523233890533447265625 W
dev:8202023-02-05 16:27:28.462debugCar charger status [code:cur_voltage, t:1675607246, value:2276, 20:2276]
dev:8202023-02-05 16:27:28.458infoCar charger power is 2.100000000000000088817841970012523233890533447265625 W
dev:8202023-02-05 16:27:28.455debugCar charger status [code:cur_power, t:1675607246, 19:21, value:21]
dev:8202023-02-05 16:27:28.453debugCar charger status [code:cur_current, t:1675607246, 18:16, value:16]
dev:8202023-02-05 16:27:28.450debugCar charger workMode
dev:8202023-02-05 16:27:28.446debugGroups: [Car charger:[[code:cur_current, t:1675607246, 18:16, value:16], [code:cur_power, t:1675607246, 19:21, value:21], [code:cur_voltage, t:1675607246, value:2276, 20:2276]]]
dev:8212023-02-05 16:27:23.456infoCar charger power is 0 W
dev:8202023-02-05 16:27:23.453debugCar charger status [code:cur_voltage, t:1675607241, value:2278, 20:2278]
dev:8202023-02-05 16:27:23.450infoCar charger power is 0 W
dev:8202023-02-05 16:27:23.447debugCar charger status [code:cur_power, t:1675607241, 19:0, value:0]
dev:8202023-02-05 16:27:23.444debugCar charger status [code:cur_current, t:1675607241, 18:0, value:0]
dev:8202023-02-05 16:27:23.442debugCar charger workMode
dev:8202023-02-05 16:27:23.438debugGroups: [Car charger:[[code:cur_current, t:1675607241, 18:0, value:0], [code:cur_power, t:1675607241, 19:0, value:0], [code:cur_voltage, t:1675607241, value:2278, 20:2278]]]
dev:8212023-02-05 16:27:22.453infoCar charger power is 2 W
dev:8202023-02-05 16:27:22.449debugCar charger status [code:cur_voltage, t:1675607240, value:2277, 20:2277]
dev:8202023-02-05 16:27:22.446infoCar charger power is 2 W
dev:8202023-02-05 16:27:22.443debugCar charger status [code:cur_power, t:1675607240, 19:20, value:20]
dev:8202023-02-05 16:27:22.440debugCar charger status [code:cur_current, t:1675607240, 18:17, value:17]
dev:8202023-02-05 16:27:22.438debugCar charger workMode
dev:8202023-02-05 16:27:22.434debugGroups: [Car charger:[[code:cur_current, t:1675607240, 18:17, value:17], [code:cur_power, t:1675607240, 19:20, value:20], [code:cur_voltage, t:1675607240, value:2277, 20:2277]]]
dev:6522023-02-05 16:27:19.768warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8B0000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8B0000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[8B, 00, 00]]
dev:6522023-02-05 16:27:10.481warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8A0000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 8A0000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[8A, 00, 00]]
dev:292023-02-05 16:27:08.236infoLiikettä eteisessä: Reset to motion inactive after 61 seconds
dev:8062023-02-05 16:27:06.784infoSähkönhintavalot : Switch 02 : On
dev:8062023-02-05 16:27:06.780infoSähkönhintavalot : Switch 03 : Off
dev:8062023-02-05 16:27:06.753infoSähkönhintavalot : Switch 01 : Off
dev:8062023-02-05 16:27:06.690infoSähkönhintavalot : Local Switch 01 : Off
dev:8062023-02-05 16:27:06.687infoSähkönhintavalot : Refreshing
dev:7202023-02-05 16:27:04.774infoHome Connect Washer Event: KEEP-ALIVE
app:6332023-02-05 16:27:04.770debugHome Connect Integration processData: Home Connect Washer - [event:KEEP-ALIVE, data:, id:BOSCH-WAYH2899SN-68A40E27EE5A]
app:6332023-02-05 16:27:04.767debugHome Connect Integration mapping: [event:KEEP-ALIVE, data:, id:BOSCH-WAYH2899SN-68A40E27EE5A]
app:6332023-02-05 16:27:04.764debugHome Connect Integration Received event: KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
app:6332023-02-05 16:27:04.761debugHome Connect Integration message: KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
app:6332023-02-05 16:27:04.758debugHome Connect Integration type: event
app:6332023-02-05 16:27:04.755debugHome Connect Integration processMessage from Home Connect Washer message: event:KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
dev:7202023-02-05 16:27:04.747debugHome Connect Washer Received eventstream message: event:KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
dev:6522023-02-05 16:27:01.185warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 890000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 890000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[89, 00, 00]]
app:6332023-02-05 16:26:57.139debugHome Connect Integration processData: Home Connect CoffeeMaker - [event:KEEP-ALIVE, data:, id:BOSCH-CTL636EB6-68A40E4F6807]
app:6332023-02-05 16:26:57.136debugHome Connect Integration mapping: [event:KEEP-ALIVE, data:, id:BOSCH-CTL636EB6-68A40E4F6807]
app:6332023-02-05 16:26:57.133debugHome Connect Integration Received event: KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
app:6332023-02-05 16:26:57.130debugHome Connect Integration message: KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
app:6332023-02-05 16:26:57.127debugHome Connect Integration type: event
app:6332023-02-05 16:26:57.124debugHome Connect Integration processMessage from Home Connect CoffeeMaker message: event:KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
dev:6522023-02-05 16:26:51.894warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 880000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 880000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[88, 00, 00]]
app:6332023-02-05 16:26:51.315debugHome Connect Integration processData: Home Connect CoffeeMaker - [event:KEEP-ALIVE, data:, id:BOSCH-CTL636EB6-68A40E4F6807]
app:6332023-02-05 16:26:51.312debugHome Connect Integration mapping: [event:KEEP-ALIVE, data:, id:BOSCH-CTL636EB6-68A40E4F6807]
app:6332023-02-05 16:26:51.309debugHome Connect Integration Received event: KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
app:6332023-02-05 16:26:51.306debugHome Connect Integration message: KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
app:6332023-02-05 16:26:51.303debugHome Connect Integration type: event
app:6332023-02-05 16:26:51.300debugHome Connect Integration processMessage from Home Connect CoffeeMaker message: event:KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
dev:7202023-02-05 16:26:50.738infoHome Connect Washer Event: KEEP-ALIVE
dev:7212023-02-05 16:26:50.735infoHome Connect Dryer Event: KEEP-ALIVE
app:6332023-02-05 16:26:50.731debugHome Connect Integration processData: Home Connect Washer - [event:KEEP-ALIVE, data:, id:BOSCH-WAYH2899SN-68A40E27EE5A]
app:6332023-02-05 16:26:50.728debugHome Connect Integration processData: Home Connect Dryer - [event:KEEP-ALIVE, data:, id:BOSCH-WTYH8789SN-68A40E26B505]
app:6332023-02-05 16:26:50.725debugHome Connect Integration mapping: [event:KEEP-ALIVE, data:, id:BOSCH-WAYH2899SN-68A40E27EE5A]
app:6332023-02-05 16:26:50.721debugHome Connect Integration mapping: [event:KEEP-ALIVE, data:, id:BOSCH-WTYH8789SN-68A40E26B505]
app:6332023-02-05 16:26:50.718debugHome Connect Integration Received event: KEEP-ALIVE data: id:BOSCH-WTYH8789SN-68A40E26B505
app:6332023-02-05 16:26:50.715debugHome Connect Integration Received event: KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
app:6332023-02-05 16:26:50.711debugHome Connect Integration message: KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
app:6332023-02-05 16:26:50.708debugHome Connect Integration message: KEEP-ALIVE data: id:BOSCH-WTYH8789SN-68A40E26B505
app:6332023-02-05 16:26:50.706debugHome Connect Integration type: event
app:6332023-02-05 16:26:50.683debugHome Connect Integration type: event
app:6332023-02-05 16:26:50.679debugHome Connect Integration processMessage from Home Connect Washer message: event:KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
app:6332023-02-05 16:26:50.676debugHome Connect Integration processMessage from Home Connect Dryer message: event:KEEP-ALIVE data: id:BOSCH-WTYH8789SN-68A40E26B505
dev:7212023-02-05 16:26:50.669debugHome Connect Dryer Received eventstream message: event:KEEP-ALIVE data: id:BOSCH-WTYH8789SN-68A40E26B505
dev:7202023-02-05 16:26:50.666debugHome Connect Washer Received eventstream message: event:KEEP-ALIVE data: id:BOSCH-WAYH2899SN-68A40E27EE5A
dev:8212023-02-05 16:26:46.413infoCar charger power is 0 W
dev:8202023-02-05 16:26:46.410debugCar charger status [code:cur_voltage, t:1675607204, value:2279, 20:2279]
dev:8202023-02-05 16:26:46.407infoCar charger power is 0 W
dev:8202023-02-05 16:26:46.404debugCar charger status [code:cur_power, t:1675607204, 19:0, value:0]
dev:8202023-02-05 16:26:46.401debugCar charger status [code:cur_current, t:1675607204, 18:0, value:0]
dev:8202023-02-05 16:26:46.398debugCar charger workMode
dev:8202023-02-05 16:26:46.395debugGroups: [Car charger:[[code:cur_current, t:1675607204, 18:0, value:0], [code:cur_power, t:1675607204, 19:0, value:0], [code:cur_voltage, t:1675607204, value:2279, 20:2279]]]
dev:6522023-02-05 16:26:42.603warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 870000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 870000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[87, 00, 00]]
dev:8212023-02-05 16:26:40.414infoCar charger power is 2 W
dev:8202023-02-05 16:26:40.411debugCar charger status [code:cur_voltage, t:1675607198, value:2284, 20:2284]
dev:8202023-02-05 16:26:40.408infoCar charger power is 2 W
dev:8202023-02-05 16:26:40.405debugCar charger status [code:cur_power, t:1675607198, 19:20, value:20]
dev:8202023-02-05 16:26:40.402debugCar charger status [code:cur_current, t:1675607198, 18:17, value:17]
dev:8202023-02-05 16:26:40.399debugCar charger workMode
dev:8202023-02-05 16:26:40.396debugGroups: [Car charger:[[code:cur_current, t:1675607198, 18:17, value:17], [code:cur_power, t:1675607198, 19:20, value:20], [code:cur_voltage, t:1675607198, value:2284, 20:2284]]]
dev:3622023-02-05 16:26:37.015infoPihavalot XBMINI is off [physical]
dev:8212023-02-05 16:26:35.398infoCar charger power is 0 W
dev:8202023-02-05 16:26:35.395debugCar charger status [code:cur_voltage, t:1675607193, value:2283, 20:2283]
dev:8202023-02-05 16:26:35.392infoCar charger power is 0 W
dev:8202023-02-05 16:26:35.389debugCar charger status [code:cur_power, t:1675607193, 19:0, value:0]
dev:8202023-02-05 16:26:35.386debugCar charger status [code:cur_current, t:1675607193, 18:0, value:0]
dev:8202023-02-05 16:26:35.383debugCar charger workMode
dev:8202023-02-05 16:26:35.380debugGroups: [Car charger:[[code:cur_current, t:1675607193, 18:0, value:0], [code:cur_power, t:1675607193, 19:0, value:0], [code:cur_voltage, t:1675607193, value:2283, 20:2283]]]
dev:6522023-02-05 16:26:33.308warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 860000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 860000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[86, 00, 00]]
dev:6522023-02-05 16:26:24.062warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 850000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 850000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[85, 00, 00]]
dev:6522023-02-05 16:26:14.721warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 840000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 840000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[84, 00, 00]]
dev:292023-02-05 16:26:07.264infoLiikettä eteisessä: Detected motion
dev:292023-02-05 16:26:07.196infoLiikettä eteisessä: Illuminance is 6 lux
dev:292023-02-05 16:26:06.101infoLiikettä eteisessä: Reset to motion inactive after 61 seconds
dev:6522023-02-05 16:26:05.431warnUnhandled Event - description:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 830000 | msgMap:[raw:catchall: 0000 0005 00 00 0040 00 E3A7 00 00 0000 00 00 830000, profileId:0000, clusterId:0005, clusterInt:5, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E3A7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[83, 00, 00]]
dev:8212023-02-05 16:26:05.369infoCar charger power is 2.29999999999999982236431605997495353221893310546875 W
dev:8202023-02-05 16:26:05.366debugCar charger status [code:cur_voltage, t:1675607163, value:2287, 20:2287]
dev:8202023-02-05 16:26:05.363infoCar charger power is 2.29999999999999982236431605997495353221893310546875 W
dev:8202023-02-05 16:26:05.360debugCar charger status [code:cur_power, t:1675607163, 19:23, value:23]
dev:8202023-02-05 16:26:05.358debugCar charger status [code:cur_current, t:1675607163, 18:17, value:17]
dev:8202023-02-05 16:26:05.355debugCar charger workMode
dev:8202023-02-05 16:26:05.352debugGroups: [Car charger:[[code:cur_current, t:1675607163, 18:17, value:17], [code:cur_power, t:1675607163, 19:23, value:23], [code:cur_voltage, t:1675607163, value:2287, 20:2287]]]
app:6332023-02-05 16:26:02.139debugHome Connect Integration processData: Home Connect CoffeeMaker - [event:KEEP-ALIVE, data:, id:BOSCH-CTL636EB6-68A40E4F6807]
app:6332023-02-05 16:26:02.135debugHome Connect Integration mapping: [event:KEEP-ALIVE, data:, id:BOSCH-CTL636EB6-68A40E4F6807]
app:6332023-02-05 16:26:02.132debugHome Connect Integration Received event: KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
app:6332023-02-05 16:26:02.129debugHome Connect Integration message: KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
app:6332023-02-05 16:26:02.126debugHome Connect Integration type: event
app:6332023-02-05 16:26:02.123debugHome Connect Integration processMessage from Home Connect CoffeeMaker message: event:KEEP-ALIVE data: id:BOSCH-CTL636EB6-68A40E4F6807
dev:8212023-02-05 16:26:00.370infoCar charger power is 0 W
dev:8202023-02-05 16:26:00.367debugCar charger status [code:cur_voltage, t:1675607158, value:2290, 20:2290]
dev:8202023-02-05 16:26:00.364infoCar charger power is 0 W
dev:8202023-02-05 16:26:00.361debugCar charger status [code:cur_power, t:1675607158, 19:0, value:0]
dev:8202023-02-05 16:26:00.358debugCar charger status [code:cur_current, t:1675607158, 18:0, value:0]
dev:8202023-02-05 16:26:00.355debugCar charger workMode
dev:8202023-02-05 16:26:00.352debugGroups: [Car charger:[[code:cur_current, t:1675607158, 18:0, value:0], [code:cur_power, t:1675607158, 19:0, value:0], [code:cur_voltage, t:1675607158, value:2290, 20:2290]]]
There nothing new on the log when there is movement. This is all there is
Summary
dev:8252023-02-05 16:39:39.764infoTuya multi sensor 2 in 1 Illuminance is 0 Lux
dev:8252023-02-05 16:39:39.750debugTuya multi sensor 2 in 1 dp_id=2 dp=12 fncmd=0
dev:8252023-02-05 16:39:39.712debugTuya multi sensor 2 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8F7E 01 00 0000 02 01 00560C02000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8F7E, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 56, 0C, 02, 00, 04, 00, 00, 00, 00]]
dev:8252023-02-05 16:09:48.148infoTuya multi sensor 2 in 1 Tuya check-in (application version is 43)
dev:8252023-02-05 16:09:48.141debugTuya multi sensor 2 in 1 parse(_TZE200_3towulqd) descMap = [raw:8F7E0100001801002043E2FF2022E4FF2000, dni:8F7E, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1, additionalAttrs:[[value:22, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:8252023-02-05 16:09:41.303infoTuya multi sensor 2 in 1 Illuminance is 2 Lux
dev:8252023-02-05 16:09:41.289debugTuya multi sensor 2 in 1 dp_id=2 dp=12 fncmd=2
dev:8252023-02-05 16:09:41.258debugTuya multi sensor 2 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8F7E 01 00 0000 02 01 00550C02000400000002, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8F7E, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 55, 0C, 02, 00, 04, 00, 00, 00, 02]]
dev:8252023-02-05 15:57:27.082infoTuya multi sensor 2 in 1 battery is 100%
dev:8252023-02-05 15:57:27.078debugTuya multi sensor 2 in 1 Battery Percentage rawValue = 200 -> 100%
dev:8252023-02-05 15:57:27.068debugTuya multi sensor 2 in 1 Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:8252023-02-05 15:57:27.063debugTuya multi sensor 2 in 1 dp_id=2 dp=4 fncmd=100
dev:8252023-02-05 15:57:27.035debugTuya multi sensor 2 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8F7E 01 00 0000 02 01 00540402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8F7E, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 54, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:8252023-02-05 14:09:47.053infoTuya multi sensor 2 in 1 Illuminance is 11 Lux
dev:8252023-02-05 14:09:47.041debugTuya multi sensor 2 in 1 dp_id=2 dp=12 fncmd=11
dev:8252023-02-05 14:09:47.036debugTuya multi sensor 2 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8F7E 01 00 0000 02 01 00530C0200040000000B, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8F7E, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 53, 0C, 02, 00, 04, 00, 00, 00, 0B]]
dev:8252023-02-05 14:09:36.162infoTuya multi sensor 2 in 1 Tuya check-in (application version is 43)
dev:8252023-02-05 14:09:36.156debugTuya multi sensor 2 in 1 parse(_TZE200_3towulqd) descMap = [raw:8F7E0100001801002043E2FF2022E4FF2000, dni:8F7E, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1, additionalAttrs:[[value:22, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:8252023-02-05 14:07:32.313infoTuya multi sensor 2 in 1 battery is 100%
dev:8252023-02-05 14:07:32.309debugTuya multi sensor 2 in 1 Battery Percentage rawValue = 200 -> 100%
dev:8252023-02-05 14:07:32.301debugTuya multi sensor 2 in 1 Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:8252023-02-05 14:07:32.295debugTuya multi sensor 2 in 1 dp_id=2 dp=4 fncmd=100
dev:8252023-02-05 14:07:32.262debugTuya multi sensor 2 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8F7E 01 00 0000 02 01 00520402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8F7E, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 52, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:8252023-02-05 13:53:37.049debugTuya multi sensor 2 in 1 deviceHealthCheck - online (notPresentCounter=1)
You can filter the logs for the particular device, so it will be easier to see the information,
Search "dev:2920" (6 hits in 1 file of 1 searched)
  new 34 (6 hits)
	Line  53: dev:292023-02-05 16:27:39.859infoLiikettä eteisessä: Detected motion
	Line  55: dev:292023-02-05 16:27:39.772infoLiikettä eteisessä: Illuminance is 6 lux
	Line 133: dev:292023-02-05 16:27:08.236infoLiikettä eteisessä: Reset to motion inactive after 61 seconds
	Line 273: dev:292023-02-05 16:26:07.264infoLiikettä eteisessä: Detected motion
	Line 275: dev:292023-02-05 16:26:07.196infoLiikettä eteisessä: Illuminance is 6 lux
	Line 277: dev:292023-02-05 16:26:06.101infoLiikettä eteisessä: Reset to motion inactive after 61 seconds
These logs show that the sensor "Liikettä eteisessä" detects motion OK?
Ok, this is the device .. I remember it now, as it was reporting the motion-detected event inverted!
Debug logs from (apparently) the same device were posted here :
However, there are no motion-detected events in the raw logs that you submitted.
When you paired this 2-in-1 sensor for the first time, was the "Tuya Zigbee Multi-Sensor 4 in 1" selected automatically?
If not - please remove the device from HE first, then pair it again close to the hub, This driver must be selected automatically during the Zigbee pairing process, otherwise it may not work if assigned manually afterward.
Fresh pairing and no motion events. Maybe different unit though same manufacturer. Does this reveal anything. Some failures.
Summary
dev:8302023-02-06 17:38:05.885infoTuya Multi Sensor 1 in 1 battery is 50%
dev:8302023-02-06 17:38:05.882debugTuya Multi Sensor 1 in 1 Battery Percentage rawValue = 100 -> 50%
dev:8302023-02-06 17:38:05.881debugTuya Multi Sensor 1 in 1 Tuya battery status report dp_id=2 dp=4 fncmd=50
dev:8302023-02-06 17:38:05.879debugTuya Multi Sensor 1 in 1 dp_id=2 dp=4 fncmd=50
dev:8302023-02-06 17:38:05.874debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 02 01 00570402000400000032, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 57, 04, 02, 00, 04, 00, 00, 00, 32]]
dev:8302023-02-06 17:37:58.706infoTuya Multi Sensor 1 in 1 Keep Time is 30 (0)
dev:8302023-02-06 17:37:58.704debugTuya Multi Sensor 1 in 1 dp_id=4 dp=10 fncmd=0
dev:8302023-02-06 17:37:58.700debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 01 01 00020A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 02, 0A, 04, 00, 01, 00]]
dev:8302023-02-06 17:37:58.686debugTuya Multi Sensor 1 in 1 device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:8302023-02-06 17:37:58.682debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:8302023-02-06 17:37:56.316infoTuya Multi Sensor 1 in 1 received sensitivity : high (2)
dev:8302023-02-06 17:37:56.315debugTuya Multi Sensor 1 in 1 dp_id=4 dp=9 fncmd=2
dev:8302023-02-06 17:37:56.310debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 01 01 00010904000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 01, 09, 04, 00, 01, 02]]
dev:8302023-02-06 17:37:56.296debugTuya Multi Sensor 1 in 1 device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:8302023-02-06 17:37:56.291debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:8302023-02-06 17:37:56.066infoTuya Multi Sensor 1 in 1 preferencies updates are sent to the device...
dev:8302023-02-06 17:37:56.061debugTuya Multi Sensor 1 in 1 sendZigbeeCommands (cmd=[he cmd 0x1070 0x01 0xEF00 0x00 {00010904000102}, delay 2000, he cmd 0x1070 0x01 0xEF00 0x00 {00020A04000100}, delay 2000])
dev:8302023-02-06 17:37:56.060debugTuya Multi Sensor 1 in 1 sending the changed AdvancedOptions
dev:8302023-02-06 17:37:56.058warnTuya Multi Sensor 1 in 1 changing TS0601 Keep Time to : 0
dev:8302023-02-06 17:37:56.056debugTuya Multi Sensor 1 in 1 sendTuyaCommand = [he cmd 0x1070 0x01 0xEF00 0x00 {00020A04000100}, delay 2000]
dev:8302023-02-06 17:37:56.052warnTuya Multi Sensor 1 in 1 changing TS0601 sensitivity to : 2
dev:8302023-02-06 17:37:56.051debugTuya Multi Sensor 1 in 1 sendTuyaCommand = [he cmd 0x1070 0x01 0xEF00 0x00 {00010904000102}, delay 2000]
dev:8302023-02-06 17:37:56.024infoTuya Multi Sensor 1 in 1 Debug logging is will be turned off after 24 hours
dev:8302023-02-06 17:37:55.989infoTuya Multi Sensor 1 in 1 Debug logging is true; Description text logging is true
dev:8302023-02-06 17:37:55.987infoTuya Multi Sensor 1 in 1 Updating Tuya Multi Sensor 1 in 1 (Tuya Multi Sensor 4 In 1) model TS0601 manufacturer _TZE200_3towulqd
dev:8302023-02-06 17:37:55.872infoTuya Multi Sensor 1 in 1 battery is 50%
dev:8302023-02-06 17:37:55.869debugTuya Multi Sensor 1 in 1 Battery Percentage rawValue = 100 -> 50%
dev:8302023-02-06 17:37:55.868debugTuya Multi Sensor 1 in 1 Tuya battery status report dp_id=2 dp=4 fncmd=50
dev:8302023-02-06 17:37:55.866debugTuya Multi Sensor 1 in 1 dp_id=2 dp=4 fncmd=50
dev:8302023-02-06 17:37:55.861debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 02 01 00540402000400000032, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 54, 04, 02, 00, 04, 00, 00, 00, 32]]
dev:8302023-02-06 17:37:46.961infoTuya Multi Sensor 1 in 1 battery is 50%
dev:8302023-02-06 17:37:46.958debugTuya Multi Sensor 1 in 1 Battery Percentage rawValue = 100 -> 50%
dev:8302023-02-06 17:37:46.956debugTuya Multi Sensor 1 in 1 Tuya battery status report dp_id=2 dp=4 fncmd=50
dev:8302023-02-06 17:37:46.955debugTuya Multi Sensor 1 in 1 dp_id=2 dp=4 fncmd=50
dev:8302023-02-06 17:37:46.950debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 02 01 00530402000400000032, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 53, 04, 02, 00, 04, 00, 00, 00, 32]]
dev:8302023-02-06 17:37:46.733infoTuya Multi Sensor 1 in 1 Keep Time is 30 (0)
dev:8302023-02-06 17:37:46.731debugTuya Multi Sensor 1 in 1 dp_id=4 dp=10 fncmd=0
dev:8302023-02-06 17:37:46.726debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 02 01 00520A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 52, 0A, 04, 00, 01, 00]]
dev:8302023-02-06 17:37:46.513infoTuya Multi Sensor 1 in 1 received sensitivity : high (2)
dev:8302023-02-06 17:37:46.511debugTuya Multi Sensor 1 in 1 dp_id=4 dp=9 fncmd=2
dev:8302023-02-06 17:37:46.504debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 02 01 00510904000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 51, 09, 04, 00, 01, 02]]
dev:8302023-02-06 17:37:46.294infoTuya Multi Sensor 1 in 1 battery is 50%
dev:8302023-02-06 17:37:46.291debugTuya Multi Sensor 1 in 1 Battery Percentage rawValue = 100 -> 50%
dev:8302023-02-06 17:37:46.289debugTuya Multi Sensor 1 in 1 Tuya battery status report dp_id=2 dp=4 fncmd=50
dev:8302023-02-06 17:37:46.288debugTuya Multi Sensor 1 in 1 dp_id=2 dp=4 fncmd=50
dev:8302023-02-06 17:37:46.283debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 02 01 00500402000400000032, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 50, 04, 02, 00, 04, 00, 00, 00, 32]]
dev:8302023-02-06 17:37:46.070infoTuya Multi Sensor 1 in 1 Illuminance is 59 Lux
dev:8302023-02-06 17:37:46.066debugTuya Multi Sensor 1 in 1 dp_id=2 dp=12 fncmd=59
dev:8302023-02-06 17:37:46.061debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 02 01 004F0C0200040000003B, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 4F, 0C, 02, 00, 04, 00, 00, 00, 3B]]
dev:8302023-02-06 17:37:45.848infoTuya Multi Sensor 1 in 1 Motion reset to inactive after 19s
dev:8302023-02-06 17:37:45.845debugTuya Multi Sensor 1 in 1 (DP=0x01) motion event fncmd = 1
dev:8302023-02-06 17:37:45.844debugTuya Multi Sensor 1 in 1 dp_id=4 dp=1 fncmd=1
dev:8302023-02-06 17:37:45.839debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 02 01 004E0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 4E, 01, 04, 00, 01, 01]]
dev:8302023-02-06 17:37:35.818infoTuya Multi Sensor 1 in 1 battery is 50%
dev:8302023-02-06 17:37:35.815debugTuya Multi Sensor 1 in 1 Battery Percentage rawValue = 100 -> 50%
dev:8302023-02-06 17:37:35.813debugTuya Multi Sensor 1 in 1 Tuya battery status report dp_id=2 dp=4 fncmd=50
dev:8302023-02-06 17:37:35.811debugTuya Multi Sensor 1 in 1 dp_id=2 dp=4 fncmd=50
dev:8302023-02-06 17:37:35.806debugTuya Multi Sensor 1 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 02 01 004D0402000400000032, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 4D, 04, 02, 00, 04, 00, 00, 00, 32]]
dev:8302023-02-06 17:37:32.393infoTuya Multi Sensor 4 In 1 zdo command: cluster: 8005 (endpoint response) endpointCount = 01 endpointList = 01
dev:8302023-02-06 17:37:32.389debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0000 8005 00 00 0040 00 1070 00 00 0000 00 00 AB0070100101, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:1070, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[AB, 00, 70, 10, 01, 01]]
dev:8302023-02-06 17:37:32.136infoTuya Multi Sensor 4 In 1 Tuya check-in
dev:8302023-02-06 17:37:32.132debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:10700100001CDFFF420AC4DA732B122FDB732B12, dni:1070, endpoint:01, cluster:0000, size:1C, attrId:FFDF, encoding:42, command:0A, value:ÄÚs+/Ûs+, clusterInt:0, attrInt:65503]
dev:8302023-02-06 17:37:30.808infoTuya Multi Sensor 4 In 1 Tuya check-in (application version is 43)
dev:8302023-02-06 17:37:30.801debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:10700100001801002043E2FF2022E4FF2000, dni:1070, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1, additionalAttrs:[[value:22, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:8302023-02-06 17:37:28.850infoTuya Multi Sensor 4 In 1 Illuminance is 58 Lux
dev:8302023-02-06 17:37:28.848debugTuya Multi Sensor 4 In 1 dp_id=2 dp=12 fncmd=58
dev:8302023-02-06 17:37:28.842debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1070 01 00 0000 02 01 004C0C0200040000003A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 4C, 0C, 02, 00, 04, 00, 00, 00, 3A]]
dev:8302023-02-06 17:37:28.590infoTuya Multi Sensor 4 In 1 Received bind response, data=[B8, 82] (Sequence Number:B8, Status: Failure)
dev:8302023-02-06 17:37:28.586debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0000 8021 00 00 0040 00 1070 00 00 0000 00 00 B882, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:1070, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[B8, 82]]
dev:8302023-02-06 17:37:28.510infoTuya Multi Sensor 4 In 1 Received bind response, data=[B7, 82] (Sequence Number:B7, Status: Failure)
dev:8302023-02-06 17:37:28.506debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0000 8021 00 00 0040 00 1070 00 00 0000 00 00 B782, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:1070, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[B7, 82]]
dev:8302023-02-06 17:37:28.493infoTuya Multi Sensor 4 In 1 Received bind response, data=[B4, 82] (Sequence Number:B4, Status: Failure)
dev:8302023-02-06 17:37:28.489debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0000 8021 00 00 0040 00 1070 00 00 0000 00 00 B482, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:1070, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[B4, 82]]
dev:8302023-02-06 17:37:28.475debugTuya Multi Sensor 4 In 1 write attribute response is success
dev:8302023-02-06 17:37:28.470debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 0000 01 01 0040 00 1070 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1070, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:8302023-02-06 17:37:27.075infoTuya Multi Sensor 4 In 1 installed()
I see the problem now. The manufacturer has fixed the previous problem with the inverted motion active/inactive signal …. by inverting it again! Obviously your sensor is a newer version than the previous tested.. I will have to find a solution how to support both the older and the older versions, will send an update later tonight.
@petteri.joutseno please update the driver again, the version is 1.2.0 time stamp 2023/02/06 9:35 PM and let me know if the motion detection works.
Errors are gone, but still no movement. If I click initialise, Power source gets ? As value. Other values seem right. One change from previous version is that Movement is Active by default while earlier it was Inactive.
Summary
dev:8322023-02-07 06:38:59.021infoTuya Multi Sensor 2 in 1 Initialization finished
version=1.2.0 (Timestamp: 2023/02/06 9:35 PM)
dev:8322023-02-07 06:38:59.020infoTuya Multi Sensor 2 in 1 manufacturer = _TZE200_3towulqd
dev:8322023-02-07 06:38:57.325infoTuya Multi Sensor 2 in 1 preferencies updates are sent to the device...
dev:8322023-02-07 06:38:57.292debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he cmd 0x8D1B 0x01 0xEF00 0x00 {00010904000101}, delay 2000, he cmd 0x8D1B 0x01 0xEF00 0x00 {00020A04000100}, delay 2000])
dev:8322023-02-07 06:38:57.291debugTuya Multi Sensor 2 in 1 sending the changed AdvancedOptions
dev:8322023-02-07 06:38:57.289warnTuya Multi Sensor 2 in 1 changing TS0601 Keep Time to : 0
dev:8322023-02-07 06:38:57.287debugTuya Multi Sensor 2 in 1 sendTuyaCommand = [he cmd 0x8D1B 0x01 0xEF00 0x00 {00020A04000100}, delay 2000]
dev:8322023-02-07 06:38:57.270warnTuya Multi Sensor 2 in 1 changing TS0601 sensitivity to : 1
dev:8322023-02-07 06:38:57.268debugTuya Multi Sensor 2 in 1 sendTuyaCommand = [he cmd 0x8D1B 0x01 0xEF00 0x00 {00010904000101}, delay 2000]
dev:8322023-02-07 06:38:57.215infoTuya Multi Sensor 2 in 1 Debug logging is will be turned off after 24 hours
dev:8322023-02-07 06:38:57.102errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_kkossev_Tuya_Multi_Sensor_4_In_1_1298.ping() is applicable for argument types: () values: []
Possible solutions: find(), print(java.lang.Object), find(groovy.lang.Closure), print(java.io.PrintWriter), print(java.lang.Object), run() (method ping)
dev:8322023-02-07 06:38:57.091infoTuya Multi Sensor 2 in 1 Debug logging is true; Description text logging is true
dev:8322023-02-07 06:38:57.080infoTuya Multi Sensor 2 in 1 Updating Tuya Multi Sensor 2 in 1 (Tuya Multi Sensor 4 In 1) model TS0601 manufacturer _TZE200_3towulqd
dev:8322023-02-07 06:38:56.706errororg.codehaus.groovy.runtime.metaclass.MissingMethodExceptionNoStack: No signature of method: user_driver_kkossev_Tuya_Multi_Sensor_4_In_1_1298.ping() is applicable for argument types: () values: []
dev:8322023-02-07 06:38:55.902debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:55.822infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:55.802infoTuya Multi Sensor 2 in 1 installed()
dev:8322023-02-07 06:38:55.514infoTuya Multi Sensor 2 in 1 InitializeVars( fullInit = true )...
dev:8322023-02-07 06:38:55.424infoTuya Multi Sensor 2 in 1 Initialize( fullInit = true )...
dev:8322023-02-07 06:38:55.305debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:55.160infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:54.910debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:54.810infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:54.722infoTuya Multi Sensor 2 in 1 installed()
dev:8322023-02-07 06:38:54.587infoTuya Multi Sensor 2 in 1 InitializeVars( fullInit = true )...
dev:8322023-02-07 06:38:54.527infoTuya Multi Sensor 2 in 1 Initialize( fullInit = true )...
dev:8322023-02-07 06:38:54.510debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:54.323infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:54.095debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:54.006infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:53.994infoTuya Multi Sensor 2 in 1 installed()
dev:8322023-02-07 06:38:53.720infoTuya Multi Sensor 2 in 1 InitializeVars( fullInit = true )...
dev:8322023-02-07 06:38:53.599infoTuya Multi Sensor 2 in 1 Initialize( fullInit = true )...
dev:8322023-02-07 06:38:53.441debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:53.260infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:53.088debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:53.031infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:53.013infoTuya Multi Sensor 2 in 1 installed()
dev:8322023-02-07 06:38:52.794infoTuya Multi Sensor 2 in 1 InitializeVars( fullInit = true )...
dev:8322023-02-07 06:38:52.647infoTuya Multi Sensor 2 in 1 Initialize( fullInit = true )...
dev:8322023-02-07 06:38:52.379debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:52.229infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:52.159debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:52.031infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:51.836debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:51.786infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:51.545debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:51.495infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:51.340debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:51.289infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:50.204debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:50.152infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:48.302debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 07 00 FE FF}, delay 200])
dev:8322023-02-07 06:38:48.300debugTuya Multi Sensor 2 in 1 refresh()...
dev:8322023-02-07 06:38:44.603infoTuya Multi Sensor 2 in 1 preferencies updates are sent to the device...
dev:8322023-02-07 06:38:44.599debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he cmd 0x8D1B 0x01 0xEF00 0x00 {00070904000102}, delay 2000, he cmd 0x8D1B 0x01 0xEF00 0x00 {00080A04000100}, delay 2000])
dev:8322023-02-07 06:38:44.598debugTuya Multi Sensor 2 in 1 sending the changed AdvancedOptions
dev:8322023-02-07 06:38:44.596warnTuya Multi Sensor 2 in 1 changing TS0601 Keep Time to : 0
dev:8322023-02-07 06:38:44.595debugTuya Multi Sensor 2 in 1 sendTuyaCommand = [he cmd 0x8D1B 0x01 0xEF00 0x00 {00080A04000100}, delay 2000]
dev:8322023-02-07 06:38:44.590warnTuya Multi Sensor 2 in 1 changing TS0601 sensitivity to : 2
dev:8322023-02-07 06:38:44.589debugTuya Multi Sensor 2 in 1 sendTuyaCommand = [he cmd 0x8D1B 0x01 0xEF00 0x00 {00070904000102}, delay 2000]
dev:8322023-02-07 06:38:44.572infoTuya Multi Sensor 2 in 1 Debug logging is will be turned off after 24 hours
dev:8322023-02-07 06:38:44.531infoTuya Multi Sensor 2 in 1 Debug logging is true; Description text logging is true
dev:8322023-02-07 06:38:44.529infoTuya Multi Sensor 2 in 1 Updating Tuya Multi Sensor 2 in 1 (Tuya Multi Sensor 4 In 1) model TS0601 manufacturer _TZE200_3towulqd
dev:8322023-02-07 06:38:31.803infoTuya Multi Sensor 2 in 1 preferencies updates are sent to the device...
dev:8322023-02-07 06:38:31.798debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he cmd 0x8D1B 0x01 0xEF00 0x00 {00050904000102}, delay 2000, he cmd 0x8D1B 0x01 0xEF00 0x00 {00060A04000100}, delay 2000])
dev:8322023-02-07 06:38:31.796debugTuya Multi Sensor 2 in 1 sending the changed AdvancedOptions
dev:8322023-02-07 06:38:31.795warnTuya Multi Sensor 2 in 1 changing TS0601 Keep Time to : 0
dev:8322023-02-07 06:38:31.793debugTuya Multi Sensor 2 in 1 sendTuyaCommand = [he cmd 0x8D1B 0x01 0xEF00 0x00 {00060A04000100}, delay 2000]
dev:8322023-02-07 06:38:31.789warnTuya Multi Sensor 2 in 1 changing TS0601 sensitivity to : 2
dev:8322023-02-07 06:38:31.787debugTuya Multi Sensor 2 in 1 sendTuyaCommand = [he cmd 0x8D1B 0x01 0xEF00 0x00 {00050904000102}, delay 2000]
dev:8322023-02-07 06:38:31.767infoTuya Multi Sensor 2 in 1 Debug logging is will be turned off after 24 hours
dev:8322023-02-07 06:38:31.709infoTuya Multi Sensor 2 in 1 Debug logging is true; Description text logging is true
dev:8322023-02-07 06:38:31.707infoTuya Multi Sensor 2 in 1 Updating Tuya Multi Sensor 2 in 1 (Tuya Multi Sensor 4 In 1) model TS0601 manufacturer _TZE200_3towulqd
dev:8322023-02-07 06:38:19.016infoTuya Multi Sensor 2 in 1 preferencies updates are sent to the device...
dev:8322023-02-07 06:38:19.011debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he cmd 0x8D1B 0x01 0xEF00 0x00 {00030904000101}, delay 2000, he cmd 0x8D1B 0x01 0xEF00 0x00 {00040A04000100}, delay 2000])
dev:8322023-02-07 06:38:19.010debugTuya Multi Sensor 2 in 1 sending the changed AdvancedOptions
dev:8322023-02-07 06:38:19.008warnTuya Multi Sensor 2 in 1 changing TS0601 Keep Time to : 0
dev:8322023-02-07 06:38:19.006debugTuya Multi Sensor 2 in 1 sendTuyaCommand = [he cmd 0x8D1B 0x01 0xEF00 0x00 {00040A04000100}, delay 2000]
dev:8322023-02-07 06:38:19.002warnTuya Multi Sensor 2 in 1 changing TS0601 sensitivity to : 1
dev:8322023-02-07 06:38:19.000debugTuya Multi Sensor 2 in 1 sendTuyaCommand = [he cmd 0x8D1B 0x01 0xEF00 0x00 {00030904000101}, delay 2000]
dev:8322023-02-07 06:38:18.981infoTuya Multi Sensor 2 in 1 Debug logging is will be turned off after 24 hours
dev:8322023-02-07 06:38:18.941infoTuya Multi Sensor 2 in 1 Debug logging is true; Description text logging is true
dev:8322023-02-07 06:38:18.939infoTuya Multi Sensor 2 in 1 Updating Tuya Multi Sensor 2 in 1 (Tuya Multi Sensor 4 In 1) model TS0601 manufacturer _TZE200_3towulqd
dev:8322023-02-07 06:38:13.770infoTuya Multi Sensor 2 in 1 Initialization finished
dev:8322023-02-07 06:38:13.768infoTuya Multi Sensor 2 in 1 manufacturer = _TZE200_3towulqd
dev:8322023-02-07 06:38:13.206debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:13.144infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:12.343debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:12.286infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:11.824infoTuya Multi Sensor 2 in 1 preferencies updates are sent to the device...
dev:8322023-02-07 06:38:11.817debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he cmd 0x8D1B 0x01 0xEF00 0x00 {00010904000101}, delay 2000, he cmd 0x8D1B 0x01 0xEF00 0x00 {00020A04000100}, delay 2000])
dev:8322023-02-07 06:38:11.815debugTuya Multi Sensor 2 in 1 sending the changed AdvancedOptions
dev:8322023-02-07 06:38:11.813warnTuya Multi Sensor 2 in 1 changing TS0601 Keep Time to : 0
dev:8322023-02-07 06:38:11.811debugTuya Multi Sensor 2 in 1 sendTuyaCommand = [he cmd 0x8D1B 0x01 0xEF00 0x00 {00020A04000100}, delay 2000]
dev:8322023-02-07 06:38:11.802warnTuya Multi Sensor 2 in 1 changing TS0601 sensitivity to : 1
dev:8322023-02-07 06:38:11.800debugTuya Multi Sensor 2 in 1 sendTuyaCommand = [he cmd 0x8D1B 0x01 0xEF00 0x00 {00010904000101}, delay 2000]
dev:8322023-02-07 06:38:11.767infoTuya Multi Sensor 2 in 1 Debug logging is will be turned off after 24 hours
dev:8322023-02-07 06:38:11.721infoTuya Multi Sensor 2 in 1 Debug logging is true; Description text logging is true
dev:8322023-02-07 06:38:11.717infoTuya Multi Sensor 2 in 1 Updating Tuya Multi Sensor 2 in 1 (Tuya Multi Sensor 4 In 1) model TS0601 manufacturer _TZE200_3towulqd
dev:8322023-02-07 06:38:10.678debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:38:10.611infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:38:10.577infoTuya Multi Sensor 2 in 1 installed()
dev:8322023-02-07 06:38:10.459infoTuya Multi Sensor 2 in 1 InitializeVars( fullInit = true )...
dev:8322023-02-07 06:38:10.430infoTuya Multi Sensor 2 in 1 Initialize( fullInit = true )...
dev:8322023-02-07 06:37:52.612errorjava.lang.NullPointerException: null on line 1463 (method setMotion)
dev:8322023-02-07 06:37:52.556infoTuya Multi Sensor 2 in 1 Motion reset to inactive after 127s
dev:8322023-02-07 06:35:45.892debugTuya Multi Sensor 2 in 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:35:45.837infoTuya Multi Sensor 2 in 1 configure()..
dev:8322023-02-07 06:35:39.335warnTuya Multi Sensor 2 in 1 ignoring BatteryPercentageResult(400)
dev:8322023-02-07 06:35:39.334debugTuya Multi Sensor 2 in 1 Battery Percentage rawValue = 400 -> 200%
dev:8322023-02-07 06:35:39.332debugTuya Multi Sensor 2 in 1 Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:8322023-02-07 06:35:39.330debugTuya Multi Sensor 2 in 1 dp_id=2 dp=4 fncmd=100
dev:8322023-02-07 06:35:39.325debugTuya Multi Sensor 2 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8D1B 01 00 0000 02 01 00870402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8D1B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 87, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:8322023-02-07 06:35:29.334warnTuya Multi Sensor 2 in 1 ignoring BatteryPercentageResult(400)
dev:8322023-02-07 06:35:29.332debugTuya Multi Sensor 2 in 1 Battery Percentage rawValue = 400 -> 200%
dev:8322023-02-07 06:35:29.330debugTuya Multi Sensor 2 in 1 Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:8322023-02-07 06:35:29.328debugTuya Multi Sensor 2 in 1 dp_id=2 dp=4 fncmd=100
dev:8322023-02-07 06:35:29.322debugTuya Multi Sensor 2 in 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8D1B 01 00 0000 02 01 00860402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8D1B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 86, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:8322023-02-07 06:35:20.419warnTuya Multi Sensor 4 In 1 ignoring BatteryPercentageResult(400)
dev:8322023-02-07 06:35:20.418debugTuya Multi Sensor 4 In 1 Battery Percentage rawValue = 400 -> 200%
dev:8322023-02-07 06:35:20.416debugTuya Multi Sensor 4 In 1 Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:8322023-02-07 06:35:20.415debugTuya Multi Sensor 4 In 1 dp_id=2 dp=4 fncmd=100
dev:8322023-02-07 06:35:20.409debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8D1B 01 00 0000 02 01 00850402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8D1B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 85, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:8322023-02-07 06:35:20.198infoTuya Multi Sensor 4 In 1 Keep Time is 30 (0)
dev:8322023-02-07 06:35:20.192debugTuya Multi Sensor 4 In 1 dp_id=4 dp=10 fncmd=0
dev:8322023-02-07 06:35:20.187debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8D1B 01 00 0000 02 01 00840A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8D1B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 84, 0A, 04, 00, 01, 00]]
dev:8322023-02-07 06:35:19.982infoTuya Multi Sensor 4 In 1 received sensitivity : high (2)
dev:8322023-02-07 06:35:19.972debugTuya Multi Sensor 4 In 1 dp_id=4 dp=9 fncmd=2
dev:8322023-02-07 06:35:19.967debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8D1B 01 00 0000 02 01 00830904000102, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8D1B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 83, 09, 04, 00, 01, 02]]
dev:8322023-02-07 06:35:19.755warnTuya Multi Sensor 4 In 1 ignoring BatteryPercentageResult(400)
dev:8322023-02-07 06:35:19.754debugTuya Multi Sensor 4 In 1 Battery Percentage rawValue = 400 -> 200%
dev:8322023-02-07 06:35:19.752debugTuya Multi Sensor 4 In 1 Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:8322023-02-07 06:35:19.750debugTuya Multi Sensor 4 In 1 dp_id=2 dp=4 fncmd=100
dev:8322023-02-07 06:35:19.745debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8D1B 01 00 0000 02 01 00820402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8D1B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 82, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:8322023-02-07 06:35:19.541infoTuya Multi Sensor 4 In 1 Illuminance is 68 Lux
dev:8322023-02-07 06:35:19.528debugTuya Multi Sensor 4 In 1 dp_id=2 dp=12 fncmd=68
dev:8322023-02-07 06:35:19.523debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8D1B 01 00 0000 02 01 00810C02000400000044, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8D1B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 81, 0C, 02, 00, 04, 00, 00, 00, 44]]
dev:8322023-02-07 06:35:19.318infoTuya Multi Sensor 4 In 1 Detected motion
dev:8322023-02-07 06:35:19.311debugTuya Multi Sensor 4 In 1 (DP=0x01) motion event fncmd = 1
dev:8322023-02-07 06:35:19.309debugTuya Multi Sensor 4 In 1 dp_id=4 dp=1 fncmd=1
dev:8322023-02-07 06:35:19.302debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8D1B 01 00 0000 02 01 00800104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8D1B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 80, 01, 04, 00, 01, 01]]
dev:8322023-02-07 06:35:09.352warnTuya Multi Sensor 4 In 1 ignoring BatteryPercentageResult(400)
dev:8322023-02-07 06:35:09.351debugTuya Multi Sensor 4 In 1 Battery Percentage rawValue = 400 -> 200%
dev:8322023-02-07 06:35:09.340debugTuya Multi Sensor 4 In 1 Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:8322023-02-07 06:35:09.335debugTuya Multi Sensor 4 In 1 dp_id=2 dp=4 fncmd=100
dev:8322023-02-07 06:35:09.270debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8D1B 01 00 0000 02 01 007F0402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8D1B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 7F, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:8322023-02-07 06:35:05.912debugTuya Multi Sensor 4 In 1 write attribute response is success
dev:8322023-02-07 06:35:05.908debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 0000 01 01 0040 00 8D1B 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8D1B, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:8322023-02-07 06:35:05.828infoTuya Multi Sensor 4 In 1 zdo command: cluster: 8005 (endpoint response) endpointCount = 01 endpointList = 01
dev:8322023-02-07 06:35:05.823debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0000 8005 00 00 0040 00 8D1B 00 00 0000 00 00 56001B8D0101, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:8D1B, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[56, 00, 1B, 8D, 01, 01]]
dev:8322023-02-07 06:35:05.762infoTuya Multi Sensor 4 In 1 Tuya device manufacturer is _TZE200_3towulqd
dev:8322023-02-07 06:35:05.753debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:8D1B01000068040042105F545A453230305F33746F77756C71640000002003010000204305000042065453303630310700003003FEFF003000, dni:8D1B, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_3towulqd, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:43, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:8322023-02-07 06:35:04.696debugTuya Multi Sensor 4 In 1 sendZigbeeCommands (cmd=[he raw 0x8D1B 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x8D1B 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200])
dev:8322023-02-07 06:35:04.624infoTuya Multi Sensor 4 In 1 configure()..
dev:8322023-02-07 06:35:04.588infoTuya Multi Sensor 4 In 1 installed()
dev:8322023-02-07 06:35:04.577infoTuya Multi Sensor 4 In 1 Illuminance is 66 Lux
dev:8322023-02-07 06:35:04.569debugTuya Multi Sensor 4 In 1 dp_id=2 dp=12 fncmd=66
dev:8322023-02-07 06:35:04.541debugTuya Multi Sensor 4 In 1 parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 8D1B 01 00 0000 02 01 007E0C02000400000042, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:8D1B, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 7E, 0C, 02, 00, 04, 00, 00, 00, 42]]
I see at least 2 other minor issues (battery reporting and ping not implemented) to be corrected in the next version, but let's fix first the motion.
This sensor reports only when the motion starts, so you will need to turn on the option "Reset Motion to Inactive" :
If this works, I will set this option switched on by default for your model in the next udpate.
Didn't do anything, but set motion to Inactive. No help on getting motion detected. So no events or anything on the logs.
@kkossev,
I have the same device.
It was working fine until I updated the driver last night...
Unfortunately, it was now stuck at motion activated, can I roll back to the previous version without the _TZE200_3towulqd (2in1) new firmware versions fix for motion and battery % or if you can provide a fix for the older version ?
Summary
Summary
@iEnam if you roll back the driver to the stable version from HPM you should be fine.
The “new” driver was work in progress and not a mainstream release i think, reading back the discussion between kkossev and petteri.
For reference, i think you are using the development branch now. If you dont use HPM, please use this link;
https://raw.githubusercontent.com/kkossev/Hubitat/main/Drivers/Tuya%20Multi%20Sensor%204%20In%201/Tuya%20Multi%20Sensor%204%20In%201.groovy
I maybe mistaken, but it looks like both the development and normal drivers are the same?
Sorry, yesterday I did not respect my own rules and practices, and I updated both the release and the developments versions... I must slow down a bit! :frowning:
I will publish an archive of older versions after an hour probably..
Meanwhile, can you send some logs with the Debug option turned on - I need to see what your sensor (application version 43) is sensing at the time when the motion is activated and at the time when deactivated? Obviously, my assumption that this sensor sends only 'motion detected' event has been wrong.
No problem, you have too many projects!
Please see below some logs from my 2nd Tuya sensor:
Summary
dev:16472023-02-07 03:50:14.216 PMinfoLiving room sensor (Tuya) Motion is active 31626s
dev:16472023-02-07 03:50:14.213 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 03:50:14.212 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 03:50:14.207 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00760104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 76, 01, 04, 00, 01, 00]]
dev:16472023-02-07 03:50:14.046 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:50:14.040 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00750C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 75, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:48:48.336 PMinfoLiving room sensor (Tuya) Motion is active 31540s
dev:16472023-02-07 03:48:48.334 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 03:48:48.332 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 03:48:48.327 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00740104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 74, 01, 04, 00, 01, 01]]
dev:16472023-02-07 03:48:48.111 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:48:48.106 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00730C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 73, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:48:26.502 PMinfoLiving room sensor (Tuya) Motion is active 31518s
dev:16472023-02-07 03:48:26.500 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 03:48:26.498 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 03:48:26.493 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00720104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 72, 01, 04, 00, 01, 00]]
dev:16472023-02-07 03:48:26.284 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:48:26.279 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00710C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 71, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:48:05.325 PMwarnLiving room sensor (Tuya) ignoring BatteryPercentageResult(400)
dev:16472023-02-07 03:48:05.323 PMdebugLiving room sensor (Tuya) Battery Percentage rawValue = 400 -> 200%
dev:16472023-02-07 03:48:05.321 PMdebugLiving room sensor (Tuya) Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:16472023-02-07 03:48:05.319 PMdebugLiving room sensor (Tuya) dp_id=2 dp=4 fncmd=100
dev:16472023-02-07 03:48:05.314 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00700402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 70, 04, 02, 00, 04, 00, 00, 00, 64]]
dev:16472023-02-07 03:47:27.160 PMinfoLiving room sensor (Tuya) Motion is active 31459s
dev:16472023-02-07 03:47:27.157 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 03:47:27.156 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 03:47:27.151 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 006F0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6F, 01, 04, 00, 01, 01]]
dev:16472023-02-07 03:47:26.933 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:47:26.928 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 006E0C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6E, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:47:15.112 PMinfoLiving room sensor (Tuya) Motion is active 31447s
dev:16472023-02-07 03:47:15.109 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 03:47:15.108 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 03:47:15.103 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 006D0104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6D, 01, 04, 00, 01, 00]]
dev:16472023-02-07 03:47:14.942 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:47:14.936 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 006C0C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6C, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:46:45.554 PMinfoLiving room sensor (Tuya) Motion is active 31417s
dev:16472023-02-07 03:46:45.551 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 03:46:45.550 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 03:46:45.545 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 006B0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6B, 01, 04, 00, 01, 01]]
dev:16472023-02-07 03:46:45.329 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:46:45.323 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 006A0C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 6A, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:46:33.509 PMinfoLiving room sensor (Tuya) Motion is active 31405s
dev:16472023-02-07 03:46:33.506 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 03:46:33.505 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 03:46:33.500 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00690104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 69, 01, 04, 00, 01, 00]]
dev:16472023-02-07 03:46:33.286 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:46:33.281 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00680C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 68, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:45:36.164 PMinfoLiving room sensor (Tuya) Motion is active 31348s
dev:16472023-02-07 03:45:36.162 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 03:45:36.160 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 03:45:36.155 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00670104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 67, 01, 04, 00, 01, 01]]
dev:16472023-02-07 03:45:35.943 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:45:35.937 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00660C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 66, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:45:15.088 PMinfoLiving room sensor (Tuya) Motion is active 31327s
dev:16472023-02-07 03:45:15.085 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 03:45:15.084 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 03:45:15.078 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00650104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 65, 01, 04, 00, 01, 00]]
dev:16472023-02-07 03:45:14.917 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:45:14.911 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00640C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 64, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:34:26.331 PMinfoLiving room sensor (Tuya) Motion is active 30678s
dev:16472023-02-07 03:34:26.329 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 03:34:26.327 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 03:34:26.322 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00630104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 63, 01, 04, 00, 01, 01]]
dev:16472023-02-07 03:34:26.099 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:34:26.094 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00620C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 62, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:34:08.207 PMinfoLiving room sensor (Tuya) Motion is active 30660s
dev:16472023-02-07 03:34:08.204 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 03:34:08.203 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 03:34:08.198 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00610104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 61, 01, 04, 00, 01, 00]]
dev:16472023-02-07 03:34:07.983 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:34:07.977 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00600C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 60, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:34:00.093 PMinfoLiving room sensor (Tuya) Motion is active 30652s
dev:16472023-02-07 03:34:00.090 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 03:34:00.089 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 03:34:00.083 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 005F0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5F, 01, 04, 00, 01, 01]]
dev:16472023-02-07 03:33:59.839 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:33:59.834 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 005E0C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5E, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:33:41.510 PMinfoLiving room sensor (Tuya) Motion is active 30633s
dev:16472023-02-07 03:33:41.507 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 03:33:41.506 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 03:33:41.501 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 005D0104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5D, 01, 04, 00, 01, 00]]
dev:16472023-02-07 03:33:41.285 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:33:41.280 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 005C0C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5C, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:33:15.868 PMinfoLiving room sensor (Tuya) Motion is active 30607s
dev:16472023-02-07 03:33:15.865 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 03:33:15.864 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 03:33:15.859 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 005B0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5B, 01, 04, 00, 01, 01]]
dev:16472023-02-07 03:33:15.692 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:33:15.687 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 005A0C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 5A, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:32:13.512 PMinfoLiving room sensor (Tuya) Motion is active 30545s
dev:16472023-02-07 03:32:13.509 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 03:32:13.507 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 03:32:13.503 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00590104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 59, 01, 04, 00, 01, 00]]
dev:16472023-02-07 03:32:13.339 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=1000
dev:16472023-02-07 03:32:13.334 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00580C020004000003E8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 58, 0C, 02, 00, 04, 00, 00, 03, E8]]
dev:16472023-02-07 03:03:21.625 PMinfoLiving room sensor (Tuya) Tuya check-in (application version is 43)
dev:16472023-02-07 03:03:21.618 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:19220100001801002043E2FF2022E4FF2000, dni:1922, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1, additionalAttrs:[[value:22, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:16472023-02-07 01:58:12.162 PMwarnLiving room sensor (Tuya) ignoring BatteryPercentageResult(400)
dev:16472023-02-07 01:58:12.159 PMdebugLiving room sensor (Tuya) Battery Percentage rawValue = 400 -> 200%
dev:16472023-02-07 01:58:12.157 PMdebugLiving room sensor (Tuya) Tuya battery status report dp_id=2 dp=4 fncmd=100
dev:16472023-02-07 01:58:12.156 PMdebugLiving room sensor (Tuya) dp_id=2 dp=4 fncmd=100
dev:16472023-02-07 01:58:12.150 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 1922 01 00 0000 02 01 00570402000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:1922, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 57, 04, 02, 00, 04, 00, 00, 00, 64]]
I have uploaded some older versions to a shared Google Driver folder:
https://drive.google.com/drive/folders/12zpEDg7phCT9wCnBhLMaPoIKu3jOO6Nm?usp=share_link
Please download and install first the version just prior the latest code changes - Tuya Multi Sensor 4 In 1 v.1.2.0 2023-01-31.groovy
It will be installed as a new driver with the same long name ... Let me know if it works with your _TZE200_3towulqd 2-in-1 sensor. In case it is still not working - you can install even older versions/
Thanks for the quick reply.
It's working again.
Summary
Logs
dev:16472023-02-07 06:02:59.741 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 06:02:59.739 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 06:02:59.737 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 06:02:59.733 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00240104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 24, 01, 04, 00, 01, 00]]
dev:16472023-02-07 06:02:59.523 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=72
dev:16472023-02-07 06:02:59.518 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00230C02000400000048, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 23, 0C, 02, 00, 04, 00, 00, 00, 48]]
dev:16472023-02-07 06:02:51.036 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 44s
dev:16472023-02-07 06:02:51.033 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 06:02:51.032 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 06:02:51.028 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00220104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 22, 01, 04, 00, 01, 01]]
dev:16472023-02-07 06:02:50.852 PMinfoLiving room sensor (Tuya) Illuminance is 72 Lux
dev:16472023-02-07 06:02:50.849 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=72
dev:16472023-02-07 06:02:50.844 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00210C02000400000048, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 21, 0C, 02, 00, 04, 00, 00, 00, 48]]
dev:16472023-02-07 06:02:07.233 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 06:02:07.230 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 06:02:07.229 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 06:02:07.225 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00200104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 20, 01, 04, 00, 01, 00]]
dev:16472023-02-07 06:02:07.017 PMinfoLiving room sensor (Tuya) Illuminance is 87 Lux
dev:16472023-02-07 06:02:07.014 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=87
dev:16472023-02-07 06:02:07.009 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 001F0C02000400000057, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1F, 0C, 02, 00, 04, 00, 00, 00, 57]]
dev:16472023-02-07 06:01:47.260 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 38s
dev:16472023-02-07 06:01:47.258 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 06:01:47.257 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 06:01:47.252 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 001E0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1E, 01, 04, 00, 01, 01]]
dev:16472023-02-07 06:01:47.039 PMinfoLiving room sensor (Tuya) Illuminance is 84 Lux
dev:16472023-02-07 06:01:47.036 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=84
dev:16472023-02-07 06:01:47.031 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 001D0C02000400000054, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1D, 0C, 02, 00, 04, 00, 00, 00, 54]]
dev:16472023-02-07 06:01:09.106 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 06:01:09.104 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 06:01:09.103 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 06:01:09.099 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 001C0104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1C, 01, 04, 00, 01, 00]]
dev:16472023-02-07 06:01:08.883 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=88
dev:16472023-02-07 06:01:08.879 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 001B0C02000400000058, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1B, 0C, 02, 00, 04, 00, 00, 00, 58]]
dev:16472023-02-07 06:01:08.702 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 12s
dev:16472023-02-07 06:01:08.700 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 06:01:08.698 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 06:01:08.694 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 001A0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 1A, 01, 04, 00, 01, 01]]
dev:16472023-02-07 06:01:08.513 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=88
dev:16472023-02-07 06:01:08.508 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00190C02000400000058, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 19, 0C, 02, 00, 04, 00, 00, 00, 58]]
dev:16472023-02-07 06:00:56.693 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 06:00:56.691 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 06:00:56.690 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 06:00:56.685 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00180104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 18, 01, 04, 00, 01, 00]]
dev:16472023-02-07 06:00:56.474 PMinfoLiving room sensor (Tuya) Illuminance is 88 Lux
dev:16472023-02-07 06:00:56.471 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=88
dev:16472023-02-07 06:00:56.466 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00170C02000400000058, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 17, 0C, 02, 00, 04, 00, 00, 00, 58]]
dev:16472023-02-07 06:00:47.718 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 12s
dev:16472023-02-07 06:00:47.703 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 06:00:47.702 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 06:00:47.696 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00160104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 16, 01, 04, 00, 01, 01]]
dev:16472023-02-07 06:00:47.490 PMinfoLiving room sensor (Tuya) Illuminance is 86 Lux
dev:16472023-02-07 06:00:47.485 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=86
dev:16472023-02-07 06:00:47.480 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00150C02000400000056, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 15, 0C, 02, 00, 04, 00, 00, 00, 56]]
dev:16472023-02-07 06:00:35.665 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 06:00:35.663 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 06:00:35.662 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 06:00:35.657 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00140104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 14, 01, 04, 00, 01, 00]]
dev:16472023-02-07 06:00:35.442 PMinfoLiving room sensor (Tuya) Illuminance is 85 Lux
dev:16472023-02-07 06:00:35.438 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=85
dev:16472023-02-07 06:00:35.433 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00130C02000400000055, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 13, 0C, 02, 00, 04, 00, 00, 00, 55]]
dev:16472023-02-07 06:00:32.938 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 30s
dev:16472023-02-07 06:00:32.936 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 06:00:32.935 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 06:00:32.930 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00120104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 12, 01, 04, 00, 01, 01]]
dev:16472023-02-07 06:00:32.765 PMinfoLiving room sensor (Tuya) Illuminance is 79 Lux
dev:16472023-02-07 06:00:32.762 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=79
dev:16472023-02-07 06:00:32.757 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00110C0200040000004F, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 11, 0C, 02, 00, 04, 00, 00, 00, 4F]]
dev:16472023-02-07 06:00:03.030 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 06:00:03.027 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 06:00:03.022 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 06:00:03.011 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00100104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 10, 01, 04, 00, 01, 00]]
dev:16472023-02-07 06:00:02.865 PMinfoLiving room sensor (Tuya) Illuminance is 83 Lux
dev:16472023-02-07 06:00:02.836 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=83
dev:16472023-02-07 06:00:02.814 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 000F0C02000400000053, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0F, 0C, 02, 00, 04, 00, 00, 00, 53]]
dev:16472023-02-07 06:00:01.939 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 34s
dev:16472023-02-07 06:00:01.936 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 06:00:01.935 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 06:00:01.930 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 000E0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0E, 01, 04, 00, 01, 01]]
dev:16472023-02-07 06:00:01.753 PMinfoLiving room sensor (Tuya) Illuminance is 85 Lux
dev:16472023-02-07 06:00:01.731 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=85
dev:16472023-02-07 06:00:01.695 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 000D0C02000400000055, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0D, 0C, 02, 00, 04, 00, 00, 00, 55]]
dev:16472023-02-07 05:59:27.843 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 05:59:27.841 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 05:59:27.840 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 05:59:27.835 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 000C0104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0C, 01, 04, 00, 01, 00]]
dev:16472023-02-07 05:59:27.622 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=84
dev:16472023-02-07 05:59:27.617 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 000B0C02000400000054, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0B, 0C, 02, 00, 04, 00, 00, 00, 54]]
dev:16472023-02-07 05:59:17.177 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 55s
dev:16472023-02-07 05:59:17.174 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 05:59:17.173 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 05:59:17.168 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 000A0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 0A, 01, 04, 00, 01, 01]]
dev:16472023-02-07 05:59:16.803 PMinfoLiving room sensor (Tuya) Illuminance is 84 Lux
dev:16472023-02-07 05:59:16.800 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=84
dev:16472023-02-07 05:59:16.795 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00090C02000400000054, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 09, 0C, 02, 00, 04, 00, 00, 00, 54]]
dev:16472023-02-07 05:58:21.903 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 05:58:21.901 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 05:58:21.900 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 05:58:21.895 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00080104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 08, 01, 04, 00, 01, 00]]
dev:16472023-02-07 05:58:21.416 PMinfoLiving room sensor (Tuya) Illuminance is 87 Lux
dev:16472023-02-07 05:58:21.413 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=87
dev:16472023-02-07 05:58:21.408 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00070C02000400000057, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 07, 0C, 02, 00, 04, 00, 00, 00, 57]]
dev:16472023-02-07 05:58:19.221 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 51s
dev:16472023-02-07 05:58:19.219 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 05:58:19.218 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 05:58:19.213 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00060104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 06, 01, 04, 00, 01, 01]]
dev:16472023-02-07 05:58:18.747 PMinfoLiving room sensor (Tuya) Illuminance is 84 Lux
dev:16472023-02-07 05:58:18.744 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=84
dev:16472023-02-07 05:58:18.739 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00050C02000400000054, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 05, 0C, 02, 00, 04, 00, 00, 00, 54]]
dev:16472023-02-07 05:57:28.132 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 05:57:28.130 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 05:57:28.129 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 05:57:28.124 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00040104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 04, 01, 04, 00, 01, 00]]
dev:16472023-02-07 05:57:27.915 PMinfoLiving room sensor (Tuya) Illuminance is 87 Lux
dev:16472023-02-07 05:57:27.912 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=87
dev:16472023-02-07 05:57:27.907 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00030C02000400000057, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 03, 0C, 02, 00, 04, 00, 00, 00, 57]]
dev:16472023-02-07 05:57:10.795 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 12s
dev:16472023-02-07 05:57:10.792 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 05:57:10.791 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 05:57:10.786 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00020104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 02, 01, 04, 00, 01, 01]]
dev:16472023-02-07 05:57:10.572 PMinfoLiving room sensor (Tuya) Illuminance is 88 Lux
dev:16472023-02-07 05:57:10.569 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=88
dev:16472023-02-07 05:57:10.564 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00010C02000400000058, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 01, 0C, 02, 00, 04, 00, 00, 00, 58]]
dev:16472023-02-07 05:56:58.749 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 05:56:58.747 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 05:56:58.746 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 05:56:58.741 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00FE0104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, FE, 01, 04, 00, 01, 00]]
dev:16472023-02-07 05:56:58.576 PMinfoLiving room sensor (Tuya) Illuminance is 84 Lux
dev:16472023-02-07 05:56:58.573 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=84
dev:16472023-02-07 05:56:58.567 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00FD0C02000400000054, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, FD, 0C, 02, 00, 04, 00, 00, 00, 54]]
dev:16472023-02-07 05:55:58.233 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 12s
dev:16472023-02-07 05:55:58.230 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 05:55:58.229 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 05:55:58.224 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00FC0104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, FC, 01, 04, 00, 01, 01]]
dev:16472023-02-07 05:55:58.021 PMinfoLiving room sensor (Tuya) Illuminance is 82 Lux
dev:16472023-02-07 05:55:58.015 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=82
dev:16472023-02-07 05:55:58.008 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00FB0C02000400000052, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, FB, 0C, 02, 00, 04, 00, 00, 00, 52]]
dev:16472023-02-07 05:55:46.185 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 05:55:46.183 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 05:55:46.181 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 05:55:46.177 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00FA0104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, FA, 01, 04, 00, 01, 00]]
dev:16472023-02-07 05:55:45.966 PMinfoLiving room sensor (Tuya) Illuminance is 84 Lux
dev:16472023-02-07 05:55:45.963 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=84
dev:16472023-02-07 05:55:45.957 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00F90C02000400000054, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, F9, 0C, 02, 00, 04, 00, 00, 00, 54]]
dev:16472023-02-07 05:55:31.089 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 12s
dev:16472023-02-07 05:55:31.087 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 05:55:31.086 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 05:55:31.081 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00F80104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, F8, 01, 04, 00, 01, 01]]
dev:16472023-02-07 05:55:30.869 PMinfoLiving room sensor (Tuya) Illuminance is 78 Lux
dev:16472023-02-07 05:55:30.866 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=78
dev:16472023-02-07 05:55:30.860 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00F70C0200040000004E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, F7, 0C, 02, 00, 04, 00, 00, 00, 4E]]
dev:16472023-02-07 05:55:19.041 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 05:55:19.039 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 05:55:19.037 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 05:55:19.032 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00F60104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, F6, 01, 04, 00, 01, 00]]
dev:16472023-02-07 05:55:18.824 PMinfoLiving room sensor (Tuya) Illuminance is 83 Lux
dev:16472023-02-07 05:55:18.820 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=83
dev:16472023-02-07 05:55:18.815 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00F50C02000400000053, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, F5, 0C, 02, 00, 04, 00, 00, 00, 53]]
dev:16472023-02-07 05:54:36.048 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 12s
dev:16472023-02-07 05:54:36.045 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 05:54:36.044 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 05:54:36.039 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00F40104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, F4, 01, 04, 00, 01, 01]]
dev:16472023-02-07 05:54:35.875 PMinfoLiving room sensor (Tuya) Illuminance is 85 Lux
dev:16472023-02-07 05:54:35.872 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=85
dev:16472023-02-07 05:54:35.866 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00F30C02000400000055, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, F3, 0C, 02, 00, 04, 00, 00, 00, 55]]
dev:16472023-02-07 05:54:23.995 PMinfoLiving room sensor (Tuya) Detected motion
dev:16472023-02-07 05:54:23.993 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 0
dev:16472023-02-07 05:54:23.992 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=0
dev:16472023-02-07 05:54:23.987 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00F20104000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, F2, 01, 04, 00, 01, 00]]
dev:16472023-02-07 05:54:23.781 PMinfoLiving room sensor (Tuya) Illuminance is 79 Lux
dev:16472023-02-07 05:54:23.777 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=79
dev:16472023-02-07 05:54:23.772 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00F10C0200040000004F, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, F1, 0C, 02, 00, 04, 00, 00, 00, 4F]]
dev:16472023-02-07 05:53:17.466 PMinfoLiving room sensor (Tuya) Motion reset to inactive after 12s
dev:16472023-02-07 05:53:17.464 PMdebugLiving room sensor (Tuya) (DP=0x01) motion event fncmd = 1
dev:16472023-02-07 05:53:17.463 PMdebugLiving room sensor (Tuya) dp_id=4 dp=1 fncmd=1
dev:16472023-02-07 05:53:17.458 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00F00104000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, F0, 01, 04, 00, 01, 01]]
dev:16472023-02-07 05:53:17.246 PMinfoLiving room sensor (Tuya) Illuminance is 83 Lux
dev:16472023-02-07 05:53:17.242 PMdebugLiving room sensor (Tuya) dp_id=2 dp=12 fncmd=83
dev:16472023-02-07 05:53:17.237 PMdebugLiving room sensor (Tuya) parse(_TZE200_3towulqd) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 AE48 01 00 0000 02 01 00EF0C02000400000053, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:AE48, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, EF, 0C, 02, 00, 04, 00, 00, 00, 53]]
