The device drops off the network after a few hours. Repairing brings it back.
Battery is reported, and sometimes motion. It however also features a button and seemingly illuminance
logging
dev:442023-02-12 18:49:13.060debugTS0202 Zone status: zone status 0x0004 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:49:13.059debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:47:56.626debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:47:56.624debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:34:18.339debugTS0202 Zone status: zone status 0x0004 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:34:18.338debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:31:08.560debugTS0202 Battery Percentage rawValue = 200 -> 100%
dev:442023-02-12 18:31:08.556debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:CE0301000110210020C82000201E, dni:CE03, endpoint:01, cluster:0001, size:10, attrId:0021, encoding:20, command:0A, value:C8, clusterInt:1, attrInt:33, additionalAttrs:[[value:1E, encoding:20, attrId:0020, consumedBytes:4, attrInt:32]]]
dev:442023-02-12 18:29:48.157debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:29:48.156debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:29:36.800debugTS0202 Zone status: zone status 0x0004 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:29:36.799debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:28:02.097debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:28:02.096debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:28:01.978debugTS0202 Battery Percentage rawValue = 150 -> 75%
dev:442023-02-12 18:28:01.976debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:28:01.975debugTS0202 dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:28:01.970debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00256601000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 25, 66, 01, 00, 01, 01]]
dev:442023-02-12 18:27:44.466debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:27:44.465debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:27:44.365debugTS0202 Battery Percentage rawValue = 200 -> 100%
dev:442023-02-12 18:27:44.362debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:27:44.360debugTS0202 dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:27:44.349debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00246601000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 24, 66, 01, 00, 01, 00]]
dev:442023-02-12 18:27:44.233infoTS0202 Tuya check-in
dev:442023-02-12 18:27:44.227debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:CE030100003ADFFF421934000000128A00000012C0000000127E1B0000128A01000012, dni:CE03, endpoint:01, cluster:0000, size:3A, attrId:FFDF, encoding:42, command:0A, value:4À~e, clusterInt:0, attrInt:65503]
dev:442023-02-12 18:27:30.073debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:27:30.072debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:27:29.951debugTS0202 Battery Percentage rawValue = 150 -> 75%
dev:442023-02-12 18:27:29.949debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:27:29.948debugTS0202 dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:27:29.943debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00236601000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 23, 66, 01, 00, 01, 01]]
dev:442023-02-12 18:27:28.508debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:27:28.507debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:27:28.385debugTS0202 Battery Percentage rawValue = 200 -> 100%
dev:442023-02-12 18:27:28.384debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:27:28.382debugTS0202 dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:27:28.378debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00226601000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 22, 66, 01, 00, 01, 00]]
dev:442023-02-12 18:27:17.676debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:27:17.674debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:27:17.568debugTS0202 Battery Percentage rawValue = 150 -> 75%
dev:442023-02-12 18:27:17.567debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:27:17.565debugTS0202 dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:27:17.561debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00216601000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 21, 66, 01, 00, 01, 01]]
dev:442023-02-12 18:27:17.428debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:27:17.427debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:27:17.313debugTS0202 Battery Percentage rawValue = 200 -> 100%
dev:442023-02-12 18:27:17.312debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:27:17.310debugTS0202 dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:27:17.306debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00206601000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 20, 66, 01, 00, 01, 00]]
dev:442023-02-12 18:27:13.793debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:27:13.791debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:27:13.668debugTS0202 Battery Percentage rawValue = 150 -> 75%
dev:442023-02-12 18:27:13.667debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:27:13.665debugTS0202 dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:27:13.661debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 001F6601000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 1F, 66, 01, 00, 01, 01]]
dev:442023-02-12 18:27:13.536debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:27:13.535debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:27:13.420debugTS0202 Battery Percentage rawValue = 200 -> 100%
dev:442023-02-12 18:27:13.418debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:27:13.417debugTS0202 dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:27:13.412debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 001E6601000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 1E, 66, 01, 00, 01, 00]]
dev:442023-02-12 18:27:10.993debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:27:10.992debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:27:10.873debugTS0202 Battery Percentage rawValue = 150 -> 75%
dev:442023-02-12 18:27:10.871debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:27:10.870debugTS0202 dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:27:10.865debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 001D6601000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 1D, 66, 01, 00, 01, 01]]
dev:442023-02-12 18:27:09.250debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:27:09.249debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:27:09.137debugTS0202 Battery Percentage rawValue = 200 -> 100%
dev:442023-02-12 18:27:09.136debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:27:09.134debugTS0202 dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:27:09.130debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 001C6601000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 1C, 66, 01, 00, 01, 00]]
dev:442023-02-12 18:26:55.128debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:26:55.126debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:26:54.008debugTS0202 Battery Percentage rawValue = 150 -> 75%
dev:442023-02-12 18:26:54.007debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:26:54.005debugTS0202 dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:26:54.000debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 001B6601000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 1B, 66, 01, 00, 01, 01]]
dev:442023-02-12 18:26:53.851debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:26:53.850debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:26:53.729debugTS0202 Battery Percentage rawValue = 200 -> 100%
dev:442023-02-12 18:26:53.727debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:26:53.726debugTS0202 dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:26:53.720debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 001A6601000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 1A, 66, 01, 00, 01, 00]]
dev:442023-02-12 18:26:51.390debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:26:51.389debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:26:51.276debugTS0202 Battery Percentage rawValue = 150 -> 75%
dev:442023-02-12 18:26:51.274debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:26:51.273debugTS0202 dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:26:51.267debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00196601000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 19, 66, 01, 00, 01, 01]]
dev:442023-02-12 18:26:51.137debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:26:51.136debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:26:51.019debugTS0202 Battery Percentage rawValue = 200 -> 100%
dev:442023-02-12 18:26:51.018debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:26:51.017debugTS0202 dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:26:51.012debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00186601000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 18, 66, 01, 00, 01, 00]]
dev:442023-02-12 18:26:48.685warnsetPar: parameter par value null must be within 0.5 and 500.0
dev:442023-02-12 18:26:48.683warnsetPark fadingTime null
dev:442023-02-12 18:26:46.495debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:26:46.494debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:26:46.375debugTS0202 Battery Percentage rawValue = 150 -> 75%
dev:442023-02-12 18:26:46.374debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:26:46.372debugTS0202 dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:26:46.368debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00176601000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 17, 66, 01, 00, 01, 01]]
dev:442023-02-12 18:26:46.243debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:26:46.242debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:26:46.131debugTS0202 Battery Percentage rawValue = 200 -> 100%
dev:442023-02-12 18:26:46.129debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:26:46.128debugTS0202 dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:26:46.123debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00166601000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 16, 66, 01, 00, 01, 00]]
dev:442023-02-12 18:26:41.897warnTS0202 please select motion action)
dev:442023-02-12 18:26:41.599debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:26:41.598debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:26:41.482debugTS0202 Battery Percentage rawValue = 150 -> 75%
dev:442023-02-12 18:26:41.481debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:26:41.479debugTS0202 dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:26:41.475debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00156601000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 15, 66, 01, 00, 01, 01]]
dev:442023-02-12 18:26:41.351debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:26:41.350debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:26:41.234debugTS0202 Battery Percentage rawValue = 200 -> 100%
dev:442023-02-12 18:26:41.233debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:26:41.231debugTS0202 dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:26:41.227debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00146601000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 14, 66, 01, 00, 01, 00]]
dev:442023-02-12 18:26:39.707debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:26:39.706debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:26:39.590debugTS0202 Battery Percentage rawValue = 150 -> 75%
dev:442023-02-12 18:26:39.589debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:26:39.587debugTS0202 dp_id=1 dp=102 fncmd=1
dev:442023-02-12 18:26:39.583debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00136601000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 13, 66, 01, 00, 01, 01]]
dev:442023-02-12 18:26:39.457debugTS0202 Zone status: zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
dev:442023-02-12 18:26:39.456debugTS0202 parse(_TZ3210_cwamkvua) descMap = [:]
dev:442023-02-12 18:26:39.342debugTS0202 Battery Percentage rawValue = 200 -> 100%
dev:442023-02-12 18:26:39.341debugTS0202 Tuya battery status report dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:26:39.339debugTS0202 dp_id=1 dp=102 fncmd=0
dev:442023-02-12 18:26:39.334debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 00126601000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 12, 66, 01, 00, 01, 00]]
dev:442023-02-12 18:26:37.025debugTS0202 IAS enroll write attribute response is FAILURE
dev:442023-02-12 18:26:37.022debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 0500 01 01 0040 00 CE03 00 00 0000 04 01 8601F0, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, 01, F0]]
dev:442023-02-12 18:26:36.804debugTS0202 IAS enroll write attribute response is FAILURE
dev:442023-02-12 18:26:36.800debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 0500 01 01 0040 00 CE03 00 00 0000 04 01 861300, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, 13, 00]]
dev:442023-02-12 18:26:36.680debugTS0202 sendZigbeeCommands (cmd=[he wattr 0xCE03 0x01 0x0500 0x0013 0x20 {01} {}, delay 200, he wattr 0xCE03 0x01 0x0500 0xF001 0x20 {00} {}, delay 200])
dev:442023-02-12 18:26:36.678debugTS0202 sending the changed AdvancedOptions
dev:442023-02-12 18:26:36.676debugTS0202 changing IAS Keep Time to : 30
dev:442023-02-12 18:26:36.675debugTS0202 sending IAS sensitivity : 30 (0)
dev:442023-02-12 18:26:36.668debugTS0202 changing IAS sensitivity to : medium
dev:442023-02-12 18:26:36.666debugTS0202 sending IAS sensitivity : medium (1)
dev:442023-02-12 18:26:35.689infoTS0202 Motion is active 27s
dev:442023-02-12 18:26:35.566infoTS0202 battery is 75%
dev:442023-02-12 18:26:35.434infoTS0202 Motion is active 26s
dev:442023-02-12 18:26:35.307infoTS0202 battery is 100%
dev:442023-02-12 18:26:35.181infoTS0202 battery is 100%
dev:442023-02-12 18:26:26.719infoTS0202 Motion is active 18s
dev:442023-02-12 18:26:26.597infoTS0202 battery is 75%
dev:442023-02-12 18:26:26.466infoTS0202 Motion is active 17s
dev:442023-02-12 18:26:26.350infoTS0202 battery is 100%
dev:442023-02-12 18:26:14.800infoTS0202 battery is 100%
dev:442023-02-12 18:26:10.425infoTS0202 Motion is active 1s
dev:442023-02-12 18:26:09.277infoTS0202 Motion is active 0s
dev:442023-02-12 18:26:09.153infoTS0202 battery is 75%
dev:442023-02-12 18:26:09.004infoTS0202 Detected motion
dev:442023-02-12 18:26:08.863infoTS0202 battery is 100%
dev:442023-02-12 18:26:07.327infoTS0202 battery is 100%
dev:442023-02-12 18:26:05.805infoTS0202 is present
dev:442023-02-12 18:26:04.552infoTS0202 configure()..
dev:442023-02-10 17:17:08.988infoTS0202 debug logging disabled...
dev:442023-02-10 04:21:18.027debugTS0202 deviceHealthCheck - online (notPresentCounter=4)
dev:442023-02-10 01:21:18.053debugTS0202 deviceHealthCheck - online (notPresentCounter=3)
dev:442023-02-09 22:21:18.029debugTS0202 deviceHealthCheck - online (notPresentCounter=2)
dev:442023-02-09 19:21:18.031debugTS0202 deviceHealthCheck - online (notPresentCounter=1)
dev:442023-02-09 17:17:10.953infoTS0202 Initialization finished
version=1.2.0 (Timestamp: 2023/01/31 6:25 PM)
dev:442023-02-09 17:17:10.952infoTS0202 manufacturer = _TZ3210_cwamkvua
dev:442023-02-09 17:17:09.008infoTS0202 preferencies updates are sent to the device...
dev:442023-02-09 17:17:09.005debugTS0202 sendZigbeeCommands (cmd=[he wattr 0xF03E 0x01 0x0500 0x0013 0x20 {01} {}, delay 200, he wattr 0xF03E 0x01 0x0500 0xF001 0x20 {00} {}, delay 200])
dev:442023-02-09 17:17:09.004debugTS0202 sending the changed AdvancedOptions
dev:442023-02-09 17:17:09.002debugTS0202 changing IAS Keep Time to : 30
dev:442023-02-09 17:17:09.001debugTS0202 sending IAS sensitivity : 30 (0)
dev:442023-02-09 17:17:08.994debugTS0202 changing IAS sensitivity to : medium
dev:442023-02-09 17:17:08.993debugTS0202 sending IAS sensitivity : medium (1)
dev:442023-02-09 17:17:08.968infoTS0202 Debug logging is will be turned off after 24 hours
dev:442023-02-09 17:17:08.933infoTS0202 Debug logging is true; Description text logging is true
dev:442023-02-09 17:17:08.932infoTS0202 Updating TS0202 (_TZ3210_cwamkvua) model TS0202 manufacturer _TZ3210_cwamkvua
dev:442023-02-09 17:17:07.898debugTS0202 sendZigbeeCommands (cmd=[he raw 0xF03E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xF03E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, he wattr 0xF03E 0x01 0x0500 0x0010 0xF0 {6A198516006F0D00}, delay 2000, he raw 0xF03E 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0xF03E 1 0x01 0x0500 {10 00 00 00 00}, delay 2000])
dev:442023-02-09 17:17:07.896debugTS0202 IAS device: [he raw 0xF03E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xF03E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, he wattr 0xF03E 0x01 0x0500 0x0010 0xF0 {6A198516006F0D00}, delay 2000, he raw 0xF03E 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0xF03E 1 0x01 0x0500 {10 00 00 00 00}, delay 2000]
dev:442023-02-09 17:17:07.863infoTS0202 configure()..
dev:442023-02-09 17:17:07.856infoTS0202 installed()
dev:442023-02-09 17:17:07.739infoTS0202 InitializeVars( fullInit = true )...
dev:442023-02-09 17:17:07.717infoTS0202 Initialize( fullInit = true )...
dev:442023-02-09 17:17:02.745debugTS0202 sendZigbeeCommands (cmd=[he raw 0xF03E 1 0x01 0x0000 {10 00 00 07 00 FE FF}, delay 200, he raw 0xF03E 1 0x01 0x0500 {10 00 00 13 00}, delay 200, he raw 0xF03E 1 0x01 0x0500 {10 00 00 01 F0}, delay 200])
dev:442023-02-09 17:17:02.744debugTS0202 refresh()...
dev:442023-02-09 17:16:55.882debugTS0202 sendZigbeeCommands (cmd=[he raw 0xF03E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xF03E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, he wattr 0xF03E 0x01 0x0500 0x0010 0xF0 {6A198516006F0D00}, delay 2000, he raw 0xF03E 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0xF03E 1 0x01 0x0500 {10 00 00 00 00}, delay 2000])
dev:442023-02-09 17:16:55.876debugTS0202 IAS device: [he raw 0xF03E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xF03E 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, he wattr 0xF03E 0x01 0x0500 0x0010 0xF0 {6A198516006F0D00}, delay 2000, he raw 0xF03E 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0xF03E 1 0x01 0x0500 {10 00 00 00 00}, delay 2000]
dev:442023-02-09 17:16:55.788infoTS0202 configure()..
dev:442023-02-09 08:26:21.299infoTS0202 preferencies updates are sent to the device...
dev:442023-02-09 08:26:21.286debugTS0202 sendZigbeeCommands (cmd=[he wattr 0xF03E 0x01 0x0500 0x0013 0x20 {02} {}, delay 200, null])
after switching drivers
[dev:44](http://192.168.11.89/logs?tab=past&deviceId=44#)2023-02-12 19:11:01.484[debug](http://192.168.11.89/logs?tab=past&deviceId=44#)TS0202 motion event 0x65 fncmd = 1
dev:442023-02-12 19:11:01.482debugTS0202 dp_id=4 dp=101 fncmd=1
dev:442023-02-12 19:11:01.478debugTS0202 parse(_TZ3210_cwamkvua) descMap = [raw:catchall: 0104 EF00 01 01 0040 00 CE03 01 00 0000 06 01 002D6504000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:06, direction:01, data:[00, 2D, 65, 04, 00, 01, 01]]
dev:442023-02-12 19:11:00.264debugTS0202 NOT PARSED : descMap = [raw:catchall: 0104 0500 01 01 0040 00 CE03 00 00 0000 01 01 01F086, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CE03, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[01, F0, 86]]
dev:442023-02-12 19:16:26.098infofingerprint profileId:"0104", endpointId:"01", inClusters:"0001,0500,EF00,0000", outClusters:"0019,000A", model:"TS0202", manufacturer:"_TZ3210_cwamkvua"
dev:442023-02-12 19:16:25.958traceZCL version:03
dev:442023-02-12 19:16:25.952traceSoftware Build Id:unknown
dev:442023-02-12 19:16:25.950traceModel:TS0202
dev:442023-02-12 19:16:25.948traceManufacturer:_TZ3210_cwamkvua
dev:442023-02-12 19:16:25.941infoZigbee description:zone status 0x0005 -- extended status 0x00 - sourceEndpoint:01, zoneId:00, delay:0000
