Ooops, just noticed your device model is a different one than mine!
Please turn the Debug logging option on, then cut off the power to the breaker, then power it back on, wait a few minutes and send me the logs in a PM (Private message) to me. Seems like this is a new model and as usual, new manufacturers have prepared new surprises ..
Thank you for the logs. This device uses the standard Zigbee clusters for reporting the power, voltage and the amperage, but the returned values are simply zeroes for the power and the current:
Can you check and confirm, that the Live and the Neutral wires are wired to the top terminals ( marked as In, and the load is connected to the bottom terminals (Out)?
Can you post the Manufacturer and the Model from the device Data section for theseAjax / Zignato plugs? In the same section there the Application version ( firmware version) should be visible as well.
Ajax / Zagnito is Tuya products white label. These plugs use standard ZIgbee clusters, that's why they can be directly controlled from Alexa Zigbee hub as well.
It's actually shown as 'application' in HE.
I will add these plugs fingerprints in the driver next update.
I felt sure something on the Ajaxonline website had indicated to me that Zignito was a specifically different protocol that couldn't work with normal Zigbee radio - but then I suppose they had not heard of Kkossev who is working miracles around here
Works quite well, however sometimes the relay turns itself off without any obious reason... waiting for my Tuya hub to arrive, I'm going to check if they behave the same way with their official hub.
Thanks for the fingerprint, will include it in the next update.
I am a bit worried about the relay turning off without reason... Recently I read similar complaints in Home Assistant forums, the reason for this is still a mystery. There are speculations this may happen if there are high voltage spikes or electromagnetic interferences, or the unexpected turn off happens only with some new models that have new chipsets and so on. Others say that this happens only when there is no load on the plus, etc.. And unfortunately some say that the same problem happens when the plugs are paired to Tuya hub...but there are no definite answers to these questions or speculations.
I have 5 different models of Tuya plugs but have never observed such erratic behavior. Two of the plugs are supplying the mains power to two different PCs that are always on (or in sleep mode when not in use), so they always have some minimum load.
Hmmm... these switches of mine are in testing phase right now, so there's no load connected to them, but it's quite stange anyhow...
The electric network here is quite stable, I have many zigbee devices connected to it without any issues, the solar inverter monitors the network, and no issues are shown, so it must be a bug in the switch itself... hopefully just a sw bug that can (and will) be fixed in a soon-to-be-released firmware upgrade, but I'm pretty sure I won't deploy them to control my hot water system as long as they're this unreliable...
Just bought 4 ZigBee 16A power plugs and when using the Generic ZigBee outlet the power reporting was off by one digit short (200W reported as 20W).
Found this thread and installed the driver and it reports as it should now. Thank you!!!
