Pairing again without erasing the instrument with the driver assigned will result in the same result.
The status of the plug is well reflected in HE, but the plug cannot be controlled in HE.
Summary
dev:51502022-09-08 01:00:16.493 am info여과기모터용P 20A was turned on [digital]
dev:51502022-09-08 01:00:16.186 am info여과기모터용P 20A energy is 1.75 kWh
dev:51502022-09-08 01:00:10.799 am info여과기모터용P 20A InitializeVars()... fullInit = false
dev:51502022-09-08 01:00:10.798 am debugupdating the settings from the current driver version null to the new version 1.4.2 2022/02/30 11:16 PM
dev:51502022-09-08 01:00:10.766 am errororg.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'null' with class 'null' to class 'int'. Try 'java.lang.Integer' instead on line 628 (method configure)
dev:51502022-09-08 12:56:42.797 am warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: 218F01E0015E10D0300030D0300000D0200101D01B0000000002D023F7FF290003D0237F00000004D023A02A000005D0231B050000, dni: 218F, endpoint: 01, cluster: E001, size: 5E, attrId: D010, encoding: 30, command: 0A, value: 0030D0300000D0200101D01B0000000002D023F7FF290003D0237F00000004D023A02A000005D0231B050000 | msgMap:[raw:218F01E0015E10D0300030D0300000D0200101D01B0000000002D023F7FF290003D0237F00000004D023A02A000005D0231B050000, dni:218F, endpoint:01, cluster:E001, size:5E, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, additionalAttrs:[[value:00, encoding:30, attrId:D030, consumedBytes:4, attrInt:53296], [value:01, encoding:20, attrId:D000, consumedBytes:4, attrInt:53248], [value:00000000, encoding:1B, attrId:D001, consumedBytes:7, attrInt:53249], [value:0029FFF7, encoding:23, attrId:D002, consumedBytes:7, attrInt:53250], [value:0000007F, encoding:23, attrId:D003, consumedBytes:7, attrInt:53251], [value:00002AA0, encoding:23, attrId:D004, consumedBytes:7, attrInt:53252], [value:0000051B, encoding:23, attrId:D005, consumedBytes:7, attrInt:53253]], valueParsed:0]
dev:51502022-09-08 12:56:42.790 am infomsgMap: [raw:218F01E0015E10D0300030D0300000D0200101D01B0000000002D023F7FF290003D0237F00000004D023A02A000005D0231B050000, dni:218F, endpoint:01, cluster:E001, size:5E, attrId:D010, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53264, additionalAttrs:[[value:00, encoding:30, attrId:D030, consumedBytes:4, attrInt:53296], [value:01, encoding:20, attrId:D000, consumedBytes:4, attrInt:53248], [value:00000000, encoding:1B, attrId:D001, consumedBytes:7, attrInt:53249], [value:0029FFF7, encoding:23, attrId:D002, consumedBytes:7, attrInt:53250], [value:0000007F, encoding:23, attrId:D003, consumedBytes:7, attrInt:53251], [value:00002AA0, encoding:23, attrId:D004, consumedBytes:7, attrInt:53252], [value:0000051B, encoding:23, attrId:D005, consumedBytes:7, attrInt:53253]], valueParsed:0]
dev:51502022-09-08 12:56:42.679 am warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: 218F0100063C000010010140210000024021000001803001028030000050300100801000, dni: 218F, endpoint: 01, cluster: 0006, size: 3C, attrId: 0000, encoding: 10, command: 0A, value: 010140210000024021000001803001028030000050300100801000 | msgMap:[raw:218F0100063C000010010140210000024021000001803001028030000050300100801000, dni:218F, endpoint:01, cluster:0006, size:3C, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:01, encoding:30, attrId:8001, consumedBytes:4, attrInt:32769], [value:00, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770], [value:01, encoding:30, attrId:5000, consumedBytes:4, attrInt:20480], [value:00, encoding:10, attrId:8000, consumedBytes:4, attrInt:32768]], valueParsed:true]
dev:51502022-09-08 12:56:42.673 am infomsgMap: [raw:218F0100063C000010010140210000024021000001803001028030000050300100801000, dni:218F, endpoint:01, cluster:0006, size:3C, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:01, encoding:30, attrId:8001, consumedBytes:4, attrInt:32769], [value:00, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770], [value:01, encoding:30, attrId:5000, consumedBytes:4, attrInt:20480], [value:00, encoding:10, attrId:8000, consumedBytes:4, attrInt:32768]], valueParsed:true]
dev:51502022-09-08 12:56:42.592 am errorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 233 (method parse)
dev:51502022-09-08 12:56:42.557 am errorjava.lang.StringIndexOutOfBoundsException: String index out of range: -2 on line 233 (method parse)
dev:51502022-09-08 12:56:42.445 am warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: 218F01070212000025AF0000000000, dni: 218F, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: AF0000000000 | msgMap:[raw:218F01070212000025AF0000000000, dni:218F, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:0000000000AF, clusterInt:1794, attrInt:0, valueParsed:175]
dev:51502022-09-08 12:56:42.443 am infomsgMap: [raw:218F01070212000025AF0000000000, dni:218F, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:0000000000AF, clusterInt:1794, attrInt:0, valueParsed:175]
dev:51502022-09-08 12:56:23.551 am infomsgMap: [raw:catchall: 0000 8021 00 00 0040 00 218F 00 00 0000 00 00 2382, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:218F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[23, 82]]
dev:51502022-09-08 12:56:23.400 am infoNo VALID lastCheckin event available! This should be resolved by itself within 1 or 2 hours and is perfectly NORMAL as long as the same device don't get this multiple times per day...
dev:51502022-09-08 12:56:23.396 am infomsgMap: [raw:catchall: 0000 8021 00 00 0040 00 218F 00 00 0000 00 00 2100, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:218F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[21, 00]]
dev:51502022-09-08 12:56:23.364 am infoNo VALID lastCheckin event available! This should be resolved by itself within 1 or 2 hours and is perfectly NORMAL as long as the same device don't get this multiple times per day...
dev:51502022-09-08 12:56:23.318 am infoRecovery feature ENABLED
dev:51502022-09-08 12:56:23.234 am infogetDriverVersion() = v1.0.1.1123
dev:51502022-09-08 12:56:23.215 am infoinstalled()
dev:51502022-09-08 01:04:58.140 am info여과기모터용P 20A was turned on [physical]
dev:51502022-09-08 01:04:56.948 am info여과기모터용P 20A was turned off [physical]
dev:51502022-09-08 01:04:10.382 am info여과기모터용P 20A was turned on [physical]
dev:51502022-09-08 01:04:09.481 am info여과기모터용P 20A was turned off [physical]
