Same plug with everything the same as the log above, but now with debug log, see summary below
Summary
dev:662022-06-04 10:18:44.998 infoQuooker energy is 61.86 kWh
dev:662022-06-04 10:18:37.433 infoQuooker configure()..
dev:662022-06-04 10:18:37.430 infoQuooker configuring the switch and energy reporting..
dev:662022-06-04 10:18:37.428 infoQuooker Auto polling is disabled
dev:662022-06-04 10:18:37.411 infoQuooker Debug logging is false Description text logging is true
dev:662022-06-04 10:18:37.408 infoQuooker Updating Quooker (Energy plug 1) model TS011F presence: present AlwaysOn is false
dev:662022-06-04 10:18:31.721 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:31.718 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:31.713 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:31.519 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:31.516 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:31.512 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:31.314 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:31.311 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:31.307 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:31.113 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:31.111 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:31.106 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:30.922 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:30.920 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:30.915 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:30.711 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:30.709 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:30.704 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:30.515 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:30.513 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:30.508 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:30.310 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:30.307 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:30.302 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:30.108 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:30.106 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:30.102 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:29.907 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:29.904 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:29.900 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:29.706 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:29.704 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:29.699 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:29.510 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:29.508 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:29.503 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:29.309 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:29.307 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:29.303 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:29.105 debugQuooker energy is 61.85 kWh (no change)
dev:662022-06-04 10:18:29.102 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:29.097 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:28.903 infoQuooker energy is 61.85 kWh
dev:662022-06-04 10:18:28.901 debugQuooker Desc Map: [raw:51CB01070212000025291800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001829, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:28.896 debugQuooker description is read attr - raw: 51CB01070212000025291800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 291800000000
dev:662022-06-04 10:18:14.612 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:14.610 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:14.605 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:14.412 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:14.410 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:14.405 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:14.212 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:14.209 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:14.204 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:14.011 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:14.008 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:14.004 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:13.811 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:13.809 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:13.804 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:13.610 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:13.607 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:13.603 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:13.409 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:13.407 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:13.402 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:13.208 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:13.205 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:13.201 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:13.076 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:13.073 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:13.000 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:12.806 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:12.804 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:12.799 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:12.605 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:12.602 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:12.598 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:12.404 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:12.402 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:12.397 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:12.204 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:12.202 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:12.197 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:12.003 debugQuooker energy is 61.84 kWh (no change)
dev:662022-06-04 10:18:12.001 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:11.996 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:18:11.802 infoQuooker energy is 61.84 kWh
dev:662022-06-04 10:18:11.800 debugQuooker Desc Map: [raw:51CB01070212000025281800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001828, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:18:11.795 debugQuooker description is read attr - raw: 51CB01070212000025281800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 281800000000
dev:662022-06-04 10:17:57.517 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:57.514 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:57.509 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:57.311 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:57.309 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:57.304 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:57.111 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:57.108 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:57.104 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:56.915 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:56.913 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:56.908 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:56.709 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:56.706 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:56.702 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:56.308 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:56.306 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:56.301 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:56.108 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:56.105 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:56.101 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:55.910 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:55.908 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:55.903 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:55.706 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:55.703 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:55.699 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:55.506 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:55.503 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:55.499 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:55.305 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:55.303 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:55.298 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:55.115 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:55.113 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:55.108 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:54.909 debugQuooker energy is 61.83 kWh (no change)
dev:662022-06-04 10:17:54.906 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:54.901 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:54.708 infoQuooker energy is 61.83 kWh
dev:662022-06-04 10:17:54.706 debugQuooker Desc Map: [raw:51CB01070212000025271800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001827, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:54.701 debugQuooker description is read attr - raw: 51CB01070212000025271800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 271800000000
dev:662022-06-04 10:17:23.307 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:23.305 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:23.302 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:23.087 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:23.084 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:23.082 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:22.700 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:22.697 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:22.695 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:22.485 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:22.482 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:22.480 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:21.884 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:21.882 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:21.879 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:21.683 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:21.681 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:21.678 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:21.483 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:21.480 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:21.478 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:21.282 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:21.279 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:21.277 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:21.082 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:21.079 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:21.077 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:20.881 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:20.878 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:20.876 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:20.680 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:20.678 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:20.676 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:20.480 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:20.477 debugQuooker other Tuya oddities - don't know how to handle it, skipping it for now...
dev:662022-06-04 10:17:20.474 debugQuooker description is read attr - raw: 51CB0100001801002044E2FF2030E4FF2000, dni: 51CB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF2030E4FF2000
dev:662022-06-04 10:17:15.285 debugQuooker energy is 61.82 kWh (no change)
dev:662022-06-04 10:17:15.282 debugQuooker Desc Map: [raw:51CB01070212000025261800000000, dni:51CB, endpoint:01, cluster:0702, size:12, attrId:0000, encoding:25, command:0A, value:000000001826, clusterInt:1794, attrInt:0]
dev:662022-06-04 10:17:15.278 debugQuooker description is read attr - raw: 51CB01070212000025261800000000, dni: 51CB, endpoint: 01, cluster: 0702, size: 12, attrId: 0000, encoding: 25, command: 0A, value: 261800000000
dev:662022-06-04 10:17:14.881 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:14.873 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:14.727 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:14.718 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:14.490 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:14.481 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:14.294 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:14.285 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:14.108 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:14.100 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:13.883 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:13.874 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:13.677 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:13.669 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:13.477 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:13.468 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:13.276 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:13.268 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:13.076 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:13.067 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:12.876 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:12.867 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:12.675 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:12.666 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:12.474 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:12.465 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:12.273 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:12.264 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:17:12.073 debugQuooker Desc Map: [raw:51CB010B041E050521EC0008052109000B05290000, dni:51CB, endpoint:01, cluster:0B04, size:1E, attrId:0505, encoding:21, command:0A, value:00EC, clusterInt:2820, attrInt:1285, additionalAttrs:[[value:0009, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288], [value:0000, encoding:29, attrId:050B, consumedBytes:5, attrInt:1291]]]
dev:662022-06-04 10:17:12.064 debugQuooker description is read attr - raw: 51CB010B041E050521EC0008052109000B05290000, dni: 51CB, endpoint: 01, cluster: 0B04, size: 1E, attrId: 0505, encoding: 21, command: 0A, value: EC0008052109000B05290000
dev:662022-06-04 10:15:02.752 traceQuooker sendZigbeeCommands received : [he raw 0x51CB 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he rattr 0x51CB 0x01 6 0 {}, delay 2000, he raw 0x51CB 1 0x01 0x0702 {10 00 00 00 00}, delay 2000, zdo bind 0x51CB 0x01 0x01 6 {A4C1388E199D4F77} {}, delay 2000, he cr 0x51CB 0x01 6 0 16 0 600 {}, delay 2000, zdo bind 0x51CB 0x01 0x01 0x0702 {A4C1388E199D4F77} {}, delay 2000, he cr 0x51CB 0x01 1794 0 37 60 3600 {640000000000} {}, delay 2000]
dev:662022-06-04 10:15:02.730 traceQuooker polling.. refreshAll is true
dev:662022-06-04 10:15:02.727 debugQuooker refresh()...
dev:662022-06-04 10:15:02.721 infoQuooker configure()..
dev:662022-06-04 10:15:02.719 infoQuooker configuring the switch and energy reporting..
dev:662022-06-04 10:15:02.717 infoQuooker Auto polling is disabled
dev:662022-06-04 10:15:02.709 infoQuooker Debug logging will be automatically switched off after 24 hours
dev:662022-06-04 10:15:02.693 infoQuooker Debug logging is true Description text logging is true
dev:662022-06-04 10:15:02.691 infoQuooker Updating Quooker (Energy plug 1) model TS011F presence: present AlwaysOn is false
My apologies for all the logs, I am not sure if these are helping, but I hope they do as it is the only thing I can do to try to help developing this driver. I will keep an eye on all the 24 plugs which now are in use whats happening with normal logging (all only have kWh).
