[RELEASE] Tuya Zigbee Metering Plug (w/ healthStatus)
kkossev had posted that he would not be available for several months due to a private project. Although he may chime in.
I have limited knowledge of his drivers but have had some success in adding fingerprints to some of his drivers so I will try to help.
Open the drivers code for this driver add goto around line 181 and insert the fingerprint below and save the code.
Switch your device to this driver and press the configure/initialize button and see if it works.
I don't see the incluster 'ED00' used in any other fingerprint/device so that may present a problem as his driver may not support any data that is reported in that cluster.
fingerprint profileId:'0104', endpointId:'01', inClusters:'0000,0004,0005,EF00,0000,ED00', outClusters:'0019,000A', model:'TS0601', manufacturer:'_TZE284_dikb3dp6', deviceJoinName: 'Zemismart Real-time Smart Energy Monitor'  // SPM02
