[RELEASE] Tuya Zigbee Metering Plug (w/ healthStatus)
So I have one of the Tuya 20A smart plugs that don't connect to the hub.
  • endpointId: 01
  • application: A0
  • manufacturer: _TZ3000_okaz9tjs
  • model: TS011F
Not sure if this will help, but I've been tinkering with it and can get a connection and turn it on/off. But it's only when I connect it to Hubitat first, then reset it but not deleting the device. When it's scanning for new zigbee devices, during that 60 seconds, I am able to turn it off and on and also pull usage data from it. But once the scan is done, it stops communicating to the hub.
I'm including the debug log and the Hub log so you can see when the zigbee scan starts and stops.
Debug + Trace Log in Summary
Summary
sys:1 2023-01-20 08:55:37.626 PMinfoZigbee Discovery Stopped
dev:1752 2023-01-20 08:55:37.018 PMinfoTest Received bind response, data=[53, 00] (Sequence Number:53, Status: Success)
dev:1752 2023-01-20 08:55:37.016 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 5DC7 00 00 0000 00 00 5300, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5DC7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[53, 00]]
dev:1752 2023-01-20 08:55:37.012 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 5DC7 00 00 0000 00 00 5300
dev:1752 2023-01-20 08:55:36.783 PMinfoTest Received Configure Reporting Response for cluster:0006 , data=[00] (Status: Success)
dev:1752 2023-01-20 08:55:36.780 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 5DC7 00 00 0000 07 01 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5DC7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:1752 2023-01-20 08:55:36.777 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 5DC7 00 00 0000 07 01 00
dev:1752 2023-01-20 08:55:36.527 PMinfoTest Received bind response, data=[51, 00] (Sequence Number:51, Status: Success)
dev:1752 2023-01-20 08:55:36.525 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 5DC7 00 00 0000 00 00 5100, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5DC7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[51, 00]]
dev:1752 2023-01-20 08:55:36.522 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 5DC7 00 00 0000 00 00 5100
dev:1752 2023-01-20 08:55:36.447 PMinfoTest Received Write Attribute Response for cluster:0000 , data=[86, DE, FF] (Status: Failure)
dev:1752 2023-01-20 08:55:36.445 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 5DC7 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5DC7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:1752 2023-01-20 08:55:36.441 PMdebugTest parse: description is catchall: 0104 0000 01 01 0040 00 5DC7 00 00 0000 04 01 86DEFF
dev:1752 2023-01-20 08:55:36.350 PMdebugTest skipping Tuya parse of cluster 0 attrId 4
dev:1752 2023-01-20 08:55:36.346 PMdebugTest parse: description is read attr - raw: 5DC701000064040042105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86, dni: 5DC7, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86
dev:1752 2023-01-20 08:55:36.256 PMinfoTest Received device announcement, data=[1D, C7, 5D, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E] (Sequence Number:1D, Device network ID: 5DC7, Capability Information: 8E)
dev:1752 2023-01-20 08:55:36.253 PMdebugTest parse: Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 5DC7 00 00 0000 00 00 1DC75D7E9A01602BD5B3708E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5DC7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[1D, C7, 5D, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E]]
dev:1752 2023-01-20 08:55:36.249 PMdebugTest parse: description is catchall: 0000 0013 00 00 0040 00 5DC7 00 00 0000 00 00 1DC75D7E9A01602BD5B3708E
sys:1 2023-01-20 08:55:36.213 PMinfoFound previously joined Zigbee device Test
dev:1752 2023-01-20 08:55:36.209 PMwarnTest WARNING! This TS011F plug manufacturer _TZ3000_okaz9tjs is known to be problematic with HE!
dev:1752 2023-01-20 08:55:36.198 PMtraceTest sendZigbeeCommands : [he raw 0x5DC7 1 0xFF 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x5DC7 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 5DC7 01 0x01 0x0006 {70B3D52B60019A7E} {}, delay 250, he cr 0x5DC7 01 6 0 16 0 900 {}, delay 250, zdo bind 0x5DC7 0x01 0x01 0x0702 {70B3D52B60019A7E} {}, delay 2000, he cr 0x5DC7 0x01 1794 0 37 15 60 {010000000000} {}, delay 2000, he raw 0x5DC7 1 0x01 0x0702 {10 00 08 00 0000}, delay 250, zdo bind 0x5DC7 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x5DC7 0x01 2820 1291 41 15 60 {0100} {}, delay 2000, he raw 0x5DC7 1 0x01 0x0B04 {10 00 08 00 0B05}, delay 250, zdo bind 0x5DC7 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x5DC7 0x01 2820 1285 33 15 60 {0100} {}, delay 2000, he raw 0x5DC7 1 0x01 0x0B04 {10 00 08 00 0505}, delay 250, zdo bind 0x5DC7 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x5DC7 0x01 2820 1288 33 15 60 {1900} {}, delay 2000, he raw 0x5DC7 1 0x01 0x0B04 {10 00 08 00 0805}, delay 250]
dev:1752 2023-01-20 08:55:36.194 PMtraceTest configureReporting operation=Write, measurement=Amperage minTime=15, maxTime=60, delta=25 )
dev:1752 2023-01-20 08:55:36.190 PMtraceTest configureReporting operation=Write, measurement=Voltage minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:36.186 PMtraceTest configureReporting operation=Write, measurement=Power minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:36.182 PMtraceTest configureReporting operation=Write, measurement=Energy minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:36.180 PMdebugTest skipping onOff standard configuration for an odd Tuya device...
dev:1752 2023-01-20 08:55:36.179 PMwarnfixing other Tuya oddities ...
dev:1752 2023-01-20 08:55:36.178 PMdebugTest ep=01 isF2=false
dev:1752 2023-01-20 08:55:36.139 PMinfoTest configure()..
dev:1752 2023-01-20 08:55:34.336 PMtraceTest off() sending [he cmd 0xA809 0x01 0x0006 0 {}, delay 200]
dev:1752 2023-01-20 08:55:34.294 PMdebugTest Switching Test Off
dev:1752 2023-01-20 08:55:33.817 PMtraceTest on() sending [he cmd 0xA809 0x01 0x0006 1 {}, delay 200]
dev:1752 2023-01-20 08:55:33.773 PMdebugTest Switching Test On
dev:1752 2023-01-20 08:55:33.195 PMtraceTest off() sending [he cmd 0xA809 0x01 0x0006 0 {}, delay 200]
dev:1752 2023-01-20 08:55:33.174 PMdebugTest Switching Test Off
dev:1752 2023-01-20 08:55:32.720 PMdebugTest pollPower()..
dev:1752 2023-01-20 08:55:30.287 PMdebugTest ignored amperage 0 A (change from 0.0 is less than 25 mA)
dev:1752 2023-01-20 08:55:30.257 PMinfoTest voltage is 121 V
dev:1752 2023-01-20 08:55:30.252 PMdebugTest ignored power 0 W (change from 0.0 is less than 1 W)
dev:1752 2023-01-20 08:55:30.245 PMdebugTest parse: Desc Map: [raw:A809010B04240B05210000050500217900080500210000, dni:A809, endpoint:01, cluster:0B04, size:24, attrId:050B, encoding:21, command:01, value:0000, clusterInt:2820, attrInt:1291, additionalAttrs:[[value:0079, encoding:21, attrId:0505, consumedBytes:5, attrInt:1285], [value:0000, encoding:21, attrId:0508, consumedBytes:5, attrInt:1288]]]
dev:1752 2023-01-20 08:55:30.201 PMdebugTest parse: description is read attr - raw: A809010B04240B05210000050500217900080500210000, dni: A809, endpoint: 01, cluster: 0B04, size: 24, attrId: 050B, encoding: 21, command: 01, value: 0000050500217900080500210000
dev:1752 2023-01-20 08:55:30.126 PMtraceTest sendZigbeeCommands : [he raw 0xA809 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:1752 2023-01-20 08:55:30.102 PMdebugTest polling all 0x0B04 attributes
dev:1752 2023-01-20 08:55:30.100 PMdebugTest polling.. refreshAll is false
dev:1752 2023-01-20 08:55:30.095 PMdebugTest autoPoll()
dev:1752 2023-01-20 08:55:27.309 PMinfoTest Not Found (0x8b) Read Reporting Configuration Response for cluster:0B04 attribite:0508, data=[8C, 00, 08, 05] (Status: Failure)
dev:1752 2023-01-20 08:55:27.307 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 09 01 8C000805, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:09, direction:01, data:[8C, 00, 08, 05]]
dev:1752 2023-01-20 08:55:27.303 PMdebugTest parse: description is catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 09 01 8C000805
dev:1752 2023-01-20 08:55:26.756 PMinfoTest Test Test was turned on [digital]
dev:1752 2023-01-20 08:55:26.702 PMdebugTest Switch state changed from off to on
dev:1752 2023-01-20 08:55:26.700 PMdebugTest Event enter: [name:switch, value:on]
dev:1752 2023-01-20 08:55:26.697 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 A809 00 00 0000 0B 01 0100
dev:1752 2023-01-20 08:55:26.618 PMtraceTest on() sending [he cmd 0xA809 0x01 0x0006 1 {}, delay 200]
dev:1752 2023-01-20 08:55:26.589 PMdebugTest Switching Test On
dev:1752 2023-01-20 08:55:25.989 PMinfoTest Test Test was turned off [digital]
dev:1752 2023-01-20 08:55:25.933 PMdebugTest Switch state changed from on to off
dev:1752 2023-01-20 08:55:25.931 PMdebugTest Event enter: [name:switch, value:off]
dev:1752 2023-01-20 08:55:25.896 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 A809 00 00 0000 0B 01 0000
dev:1752 2023-01-20 08:55:25.682 PMtraceTest off() sending [he cmd 0xA809 0x01 0x0006 0 {}, delay 200]
dev:1752 2023-01-20 08:55:25.642 PMdebugTest Switching Test Off
dev:1752 2023-01-20 08:55:25.301 PMinfoTest Received Configure Reporting Response for cluster:0B04 , data=[8C, 00, 08, 05] (Status: Failure)
dev:1752 2023-01-20 08:55:25.298 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 07 01 8C000805, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[8C, 00, 08, 05]]
dev:1752 2023-01-20 08:55:25.295 PMdebugTest parse: description is catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 07 01 8C000805
dev:1752 2023-01-20 08:55:25.121 PMinfoTest Test Test was turned on [digital]
dev:1752 2023-01-20 08:55:24.998 PMdebugTest Switch state changed from off to on
dev:1752 2023-01-20 08:55:24.997 PMdebugTest Event enter: [name:switch, value:on]
dev:1752 2023-01-20 08:55:24.994 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 A809 00 00 0000 0B 01 0100
dev:1752 2023-01-20 08:55:24.917 PMtraceTest on() sending [he cmd 0xA809 0x01 0x0006 1 {}, delay 200]
dev:1752 2023-01-20 08:55:24.879 PMdebugTest Switching Test On
dev:1752 2023-01-20 08:55:24.125 PMdebugTest Event enter: [name:switch, value:off]
dev:1752 2023-01-20 08:55:24.121 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 A809 00 00 0000 0B 01 0000
dev:1752 2023-01-20 08:55:24.046 PMtraceTest off() sending [he cmd 0xA809 0x01 0x0006 0 {}, delay 200]
dev:1752 2023-01-20 08:55:24.014 PMdebugTest Switching Test Off
dev:1752 2023-01-20 08:55:23.592 PMinfoTest Test Test was turned off [digital]
dev:1752 2023-01-20 08:55:23.534 PMdebugTest Switch state changed from on to off
dev:1752 2023-01-20 08:55:23.532 PMdebugTest Event enter: [name:switch, value:off]
dev:1752 2023-01-20 08:55:23.529 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 A809 00 00 0000 0B 01 0000
dev:1752 2023-01-20 08:55:23.435 PMtraceTest off() sending [he cmd 0xA809 0x01 0x0006 0 {}, delay 200]
dev:1752 2023-01-20 08:55:23.399 PMdebugTest Switching Test Off
dev:1752 2023-01-20 08:55:23.346 PMinfoTest Received bind response, data=[40, 00] (Sequence Number:40, Status: Success)
dev:1752 2023-01-20 08:55:23.344 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 A809 00 00 0000 00 00 4000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[40, 00]]
dev:1752 2023-01-20 08:55:23.338 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 A809 00 00 0000 00 00 4000
dev:1752 2023-01-20 08:55:23.106 PMinfoTest Not Found (0x8b) Read Reporting Configuration Response for cluster:0B04 attribite:0505, data=[8C, 00, 05, 05] (Status: Failure)
dev:1752 2023-01-20 08:55:23.065 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 09 01 8C000505, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:09, direction:01, data:[8C, 00, 05, 05]]
dev:1752 2023-01-20 08:55:23.061 PMdebugTest parse: description is catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 09 01 8C000505
dev:1752 2023-01-20 08:55:22.982 PMinfoTest Test Test was turned on [digital]
dev:1752 2023-01-20 08:55:22.932 PMdebugTest Switch state changed from off to on
dev:1752 2023-01-20 08:55:22.931 PMdebugTest Event enter: [name:switch, value:on]
dev:1752 2023-01-20 08:55:22.927 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 A809 00 00 0000 0B 01 0100
dev:1752 2023-01-20 08:55:22.867 PMtraceTest on() sending [he cmd 0xA809 0x01 0x0006 1 {}, delay 200]
dev:1752 2023-01-20 08:55:22.839 PMdebugTest Switching Test On
dev:1752 2023-01-20 08:55:22.460 PMinfoTest Test Test was turned off [digital]
dev:1752 2023-01-20 08:55:22.409 PMdebugTest Switch state changed from unknown to off
dev:1752 2023-01-20 08:55:22.408 PMdebugTest Event enter: [name:switch, value:off]
dev:1752 2023-01-20 08:55:22.402 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 A809 00 00 0000 0B 01 0000
dev:1752 2023-01-20 08:55:22.331 PMtraceTest off() sending [he cmd 0xA809 0x01 0x0006 0 {}, delay 200]
dev:1752 2023-01-20 08:55:22.308 PMdebugTest Switching Test Off
dev:1752 2023-01-20 08:55:21.022 PMinfoTest Received Configure Reporting Response for cluster:0B04 , data=[8C, 00, 05, 05] (Status: Failure)
dev:1752 2023-01-20 08:55:21.019 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 07 01 8C000505, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[8C, 00, 05, 05]]
dev:1752 2023-01-20 08:55:21.016 PMdebugTest parse: description is catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 07 01 8C000505
dev:1752 2023-01-20 08:55:19.058 PMinfoTest Received bind response, data=[35, 00] (Sequence Number:35, Status: Success)
dev:1752 2023-01-20 08:55:19.056 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 A809 00 00 0000 00 00 3500, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[35, 00]]
dev:1752 2023-01-20 08:55:19.053 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 A809 00 00 0000 00 00 3500
dev:1752 2023-01-20 08:55:18.771 PMinfoTest Not Found (0x8b) Read Reporting Configuration Response for cluster:0B04 attribite:050B, data=[8C, 00, 0B, 05] (Status: Failure)
dev:1752 2023-01-20 08:55:18.768 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 09 01 8C000B05, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:09, direction:01, data:[8C, 00, 0B, 05]]
dev:1752 2023-01-20 08:55:18.764 PMdebugTest parse: description is catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 09 01 8C000B05
dev:1752 2023-01-20 08:55:16.776 PMinfoTest Received Configure Reporting Response for cluster:0B04 , data=[8C, 00, 0B, 05] (Status: Failure)
dev:1752 2023-01-20 08:55:16.774 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 07 01 8C000B05, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[8C, 00, 0B, 05]]
dev:1752 2023-01-20 08:55:16.770 PMdebugTest parse: description is catchall: 0104 0B04 01 01 0040 00 A809 00 00 0000 07 01 8C000B05
dev:1752 2023-01-20 08:55:14.777 PMinfoTest Received bind response, data=[2A, 00] (Sequence Number:2A, Status: Success)
dev:1752 2023-01-20 08:55:14.774 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 A809 00 00 0000 00 00 2A00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2A, 00]]
dev:1752 2023-01-20 08:55:14.771 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 A809 00 00 0000 00 00 2A00
dev:1752 2023-01-20 08:55:10.558 PMinfoTest Received bind response, data=[1D, 00] (Sequence Number:1D, Status: Success)
dev:1752 2023-01-20 08:55:10.556 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 A809 00 00 0000 00 00 1D00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[1D, 00]]
dev:1752 2023-01-20 08:55:10.552 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 A809 00 00 0000 00 00 1D00
dev:1752 2023-01-20 08:55:10.362 PMinfoTest Received Configure Reporting Response for cluster:0006 , data=[00] (Status: Success)
dev:1752 2023-01-20 08:55:10.359 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 A809 00 00 0000 07 01 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:1752 2023-01-20 08:55:10.356 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 A809 00 00 0000 07 01 00
dev:1752 2023-01-20 08:55:10.101 PMdebugTest skipping Tuya parse of cluster 0 attrId 4
dev:1752 2023-01-20 08:55:10.098 PMdebugTest parse: description is read attr - raw: A80901000064040042105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86, dni: A809, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86
dev:1752 2023-01-20 08:55:09.771 PMinfoTest Received device announcement, data=[1A, 09, A8, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E] (Sequence Number:1A, Device network ID: A809, Capability Information: 8E)
dev:1752 2023-01-20 08:55:09.768 PMdebugTest parse: Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 A809 00 00 0000 00 00 1A09A87E9A01602BD5B3708E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:A809, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[1A, 09, A8, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E]]
dev:1752 2023-01-20 08:55:09.765 PMdebugTest parse: description is catchall: 0000 0013 00 00 0040 00 A809 00 00 0000 00 00 1A09A87E9A01602BD5B3708E
sys:1 2023-01-20 08:55:09.743 PMinfoFound previously joined Zigbee device Test
dev:1752 2023-01-20 08:55:09.740 PMwarnTest WARNING! This TS011F plug manufacturer _TZ3000_okaz9tjs is known to be problematic with HE!
dev:1752 2023-01-20 08:55:09.728 PMtraceTest sendZigbeeCommands : [he raw 0xA809 1 0xFF 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0xA809 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind A809 01 0x01 0x0006 {70B3D52B60019A7E} {}, delay 250, he cr 0xA809 01 6 0 16 0 900 {}, delay 250, zdo bind 0xA809 0x01 0x01 0x0702 {70B3D52B60019A7E} {}, delay 2000, he cr 0xA809 0x01 1794 0 37 15 60 {010000000000} {}, delay 2000, he raw 0xA809 1 0x01 0x0702 {10 00 08 00 0000}, delay 250, zdo bind 0xA809 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xA809 0x01 2820 1291 41 15 60 {0100} {}, delay 2000, he raw 0xA809 1 0x01 0x0B04 {10 00 08 00 0B05}, delay 250, zdo bind 0xA809 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xA809 0x01 2820 1285 33 15 60 {0100} {}, delay 2000, he raw 0xA809 1 0x01 0x0B04 {10 00 08 00 0505}, delay 250, zdo bind 0xA809 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xA809 0x01 2820 1288 33 15 60 {1900} {}, delay 2000, he raw 0xA809 1 0x01 0x0B04 {10 00 08 00 0805}, delay 250]
dev:1752 2023-01-20 08:55:09.725 PMtraceTest configureReporting operation=Write, measurement=Amperage minTime=15, maxTime=60, delta=25 )
dev:1752 2023-01-20 08:55:09.722 PMtraceTest configureReporting operation=Write, measurement=Voltage minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:09.719 PMtraceTest configureReporting operation=Write, measurement=Power minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:09.715 PMtraceTest configureReporting operation=Write, measurement=Energy minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:09.713 PMdebugTest skipping onOff standard configuration for an odd Tuya device...
dev:1752 2023-01-20 08:55:09.712 PMwarnfixing other Tuya oddities ...
dev:1752 2023-01-20 08:55:09.711 PMdebugTest ep=01 isF2=false
dev:1752 2023-01-20 08:55:09.674 PMinfoTest configure()..
sys:1 2023-01-20 08:55:07.550 PMinfoFound previously joined Zigbee device Test
dev:1752 2023-01-20 08:55:07.547 PMwarnTest WARNING! This TS011F plug manufacturer _TZ3000_okaz9tjs is known to be problematic with HE!
dev:1752 2023-01-20 08:55:07.535 PMtraceTest sendZigbeeCommands : [he raw 0x253C 1 0xFF 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x253C 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 253C 01 0x01 0x0006 {70B3D52B60019A7E} {}, delay 250, he cr 0x253C 01 6 0 16 0 900 {}, delay 250, zdo bind 0x253C 0x01 0x01 0x0702 {70B3D52B60019A7E} {}, delay 2000, he cr 0x253C 0x01 1794 0 37 15 60 {010000000000} {}, delay 2000, he raw 0x253C 1 0x01 0x0702 {10 00 08 00 0000}, delay 250, zdo bind 0x253C 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x253C 0x01 2820 1291 41 15 60 {0100} {}, delay 2000, he raw 0x253C 1 0x01 0x0B04 {10 00 08 00 0B05}, delay 250, zdo bind 0x253C 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x253C 0x01 2820 1285 33 15 60 {0100} {}, delay 2000, he raw 0x253C 1 0x01 0x0B04 {10 00 08 00 0505}, delay 250, zdo bind 0x253C 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x253C 0x01 2820 1288 33 15 60 {1900} {}, delay 2000, he raw 0x253C 1 0x01 0x0B04 {10 00 08 00 0805}, delay 250]
dev:1752 2023-01-20 08:55:07.532 PMtraceTest configureReporting operation=Write, measurement=Amperage minTime=15, maxTime=60, delta=25 )
dev:1752 2023-01-20 08:55:07.529 PMtraceTest configureReporting operation=Write, measurement=Voltage minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:07.525 PMtraceTest configureReporting operation=Write, measurement=Power minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:07.522 PMtraceTest configureReporting operation=Write, measurement=Energy minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:07.520 PMdebugTest skipping onOff standard configuration for an odd Tuya device...
dev:1752 2023-01-20 08:55:07.519 PMwarnfixing other Tuya oddities ...
dev:1752 2023-01-20 08:55:07.518 PMdebugTest ep=01 isF2=false
dev:1752 2023-01-20 08:55:07.482 PMinfoTest configure()..
sys:1 2023-01-20 08:55:07.089 PMinfoFound previously joined Zigbee device Test
dev:1752 2023-01-20 08:55:07.085 PMwarnTest WARNING! This TS011F plug manufacturer _TZ3000_okaz9tjs is known to be problematic with HE!
dev:1752 2023-01-20 08:55:07.074 PMtraceTest sendZigbeeCommands : [he raw 0x89DF 1 0xFF 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x89DF 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 89DF 01 0x01 0x0006 {70B3D52B60019A7E} {}, delay 250, he cr 0x89DF 01 6 0 16 0 900 {}, delay 250, zdo bind 0x89DF 0x01 0x01 0x0702 {70B3D52B60019A7E} {}, delay 2000, he cr 0x89DF 0x01 1794 0 37 15 60 {010000000000} {}, delay 2000, he raw 0x89DF 1 0x01 0x0702 {10 00 08 00 0000}, delay 250, zdo bind 0x89DF 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x89DF 0x01 2820 1291 41 15 60 {0100} {}, delay 2000, he raw 0x89DF 1 0x01 0x0B04 {10 00 08 00 0B05}, delay 250, zdo bind 0x89DF 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x89DF 0x01 2820 1285 33 15 60 {0100} {}, delay 2000, he raw 0x89DF 1 0x01 0x0B04 {10 00 08 00 0505}, delay 250, zdo bind 0x89DF 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x89DF 0x01 2820 1288 33 15 60 {1900} {}, delay 2000, he raw 0x89DF 1 0x01 0x0B04 {10 00 08 00 0805}, delay 250]
dev:1752 2023-01-20 08:55:07.071 PMtraceTest configureReporting operation=Write, measurement=Amperage minTime=15, maxTime=60, delta=25 )
dev:1752 2023-01-20 08:55:07.067 PMtraceTest configureReporting operation=Write, measurement=Voltage minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:07.063 PMtraceTest configureReporting operation=Write, measurement=Power minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:07.059 PMtraceTest configureReporting operation=Write, measurement=Energy minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:07.057 PMdebugTest skipping onOff standard configuration for an odd Tuya device...
dev:1752 2023-01-20 08:55:07.056 PMwarnfixing other Tuya oddities ...
dev:1752 2023-01-20 08:55:07.055 PMdebugTest ep=01 isF2=false
dev:1752 2023-01-20 08:55:07.001 PMinfoTest configure()..
dev:1752 2023-01-20 08:55:01.764 PMinfoTest Received bind response, data=[FE, 00] (Sequence Number:FE, Status: Success)
dev:1752 2023-01-20 08:55:01.701 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 83F0 00 00 0000 00 00 FE00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:83F0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[FE, 00]]
dev:1752 2023-01-20 08:55:01.698 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 83F0 00 00 0000 00 00 FE00
dev:1752 2023-01-20 08:55:01.460 PMinfoTest Received bind response, data=[F9, 00] (Sequence Number:F9, Status: Success)
dev:1752 2023-01-20 08:55:01.444 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 83F0 00 00 0000 00 00 F900, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:83F0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[F9, 00]]
dev:1752 2023-01-20 08:55:01.436 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 83F0 00 00 0000 00 00 F900
dev:1752 2023-01-20 08:55:01.220 PMdebugTest skipping Tuya parse of cluster 0 attrId 4
dev:1752 2023-01-20 08:55:01.205 PMdebugTest parse: description is read attr - raw: 83F001000064040042105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86, dni: 83F0, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86
dev:1752 2023-01-20 08:55:01.178 PMinfoTest Received Write Attribute Response for cluster:0000 , data=[86, DE, FF] (Status: Failure)
dev:1752 2023-01-20 08:55:01.176 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 83F0 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:83F0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:1752 2023-01-20 08:55:01.156 PMdebugTest parse: description is catchall: 0104 0000 01 01 0040 00 83F0 00 00 0000 04 01 86DEFF
dev:1752 2023-01-20 08:55:00.897 PMinfoTest Received device announcement, data=[16, F0, 83, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E] (Sequence Number:16, Device network ID: 83F0, Capability Information: 8E)
dev:1752 2023-01-20 08:55:00.894 PMdebugTest parse: Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 83F0 00 00 0000 00 00 16F0837E9A01602BD5B3708E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:83F0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[16, F0, 83, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E]]
dev:1752 2023-01-20 08:55:00.882 PMdebugTest parse: description is catchall: 0000 0013 00 00 0040 00 83F0 00 00 0000 00 00 16F0837E9A01602BD5B3708E
sys:1 2023-01-20 08:55:00.852 PMinfoFound previously joined Zigbee device Test
dev:1752 2023-01-20 08:55:00.849 PMwarnTest WARNING! This TS011F plug manufacturer _TZ3000_okaz9tjs is known to be problematic with HE!
dev:1752 2023-01-20 08:55:00.838 PMtraceTest sendZigbeeCommands : [he raw 0x83F0 1 0xFF 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x83F0 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 83F0 01 0x01 0x0006 {70B3D52B60019A7E} {}, delay 250, he cr 0x83F0 01 6 0 16 0 900 {}, delay 250, zdo bind 0x83F0 0x01 0x01 0x0702 {70B3D52B60019A7E} {}, delay 2000, he cr 0x83F0 0x01 1794 0 37 15 60 {010000000000} {}, delay 2000, he raw 0x83F0 1 0x01 0x0702 {10 00 08 00 0000}, delay 250, zdo bind 0x83F0 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x83F0 0x01 2820 1291 41 15 60 {0100} {}, delay 2000, he raw 0x83F0 1 0x01 0x0B04 {10 00 08 00 0B05}, delay 250, zdo bind 0x83F0 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x83F0 0x01 2820 1285 33 15 60 {0100} {}, delay 2000, he raw 0x83F0 1 0x01 0x0B04 {10 00 08 00 0505}, delay 250, zdo bind 0x83F0 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x83F0 0x01 2820 1288 33 15 60 {1900} {}, delay 2000, he raw 0x83F0 1 0x01 0x0B04 {10 00 08 00 0805}, delay 250]
dev:1752 2023-01-20 08:55:00.829 PMtraceTest configureReporting operation=Write, measurement=Amperage minTime=15, maxTime=60, delta=25 )
dev:1752 2023-01-20 08:55:00.802 PMtraceTest configureReporting operation=Write, measurement=Voltage minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:00.795 PMtraceTest configureReporting operation=Write, measurement=Power minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:00.787 PMtraceTest configureReporting operation=Write, measurement=Energy minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:55:00.782 PMdebugTest skipping onOff standard configuration for an odd Tuya device...
dev:1752 2023-01-20 08:55:00.778 PMwarnfixing other Tuya oddities ...
dev:1752 2023-01-20 08:55:00.774 PMdebugTest ep=01 isF2=false
dev:1752 2023-01-20 08:55:00.574 PMinfoTest configure()..
dev:1752 2023-01-20 08:55:00.285 PMtraceTest sendZigbeeCommands : [he raw 0xC268 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:1752 2023-01-20 08:55:00.236 PMdebugTest polling all 0x0B04 attributes
dev:1752 2023-01-20 08:55:00.230 PMdebugTest polling.. refreshAll is false
dev:1752 2023-01-20 08:55:00.225 PMdebugTest autoPoll()
dev:1752 2023-01-20 08:54:55.060 PMinfoTest Received bind response, data=[EC, 00] (Sequence Number:EC, Status: Success)
dev:1752 2023-01-20 08:54:55.057 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 C268 00 00 0000 00 00 EC00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C268, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[EC, 00]]
dev:1752 2023-01-20 08:54:55.054 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 C268 00 00 0000 00 00 EC00
dev:1752 2023-01-20 08:54:54.727 PMinfoTest Received Configure Reporting Response for cluster:0006 , data=[00] (Status: Success)
dev:1752 2023-01-20 08:54:54.725 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 C268 00 00 0000 07 01 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:C268, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:1752 2023-01-20 08:54:54.721 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 C268 00 00 0000 07 01 00
dev:1752 2023-01-20 08:54:54.478 PMinfoTest Received bind response, data=[E8, 00] (Sequence Number:E8, Status: Success)
dev:1752 2023-01-20 08:54:54.476 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 C268 00 00 0000 00 00 E800, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C268, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[E8, 00]]
dev:1752 2023-01-20 08:54:54.472 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 C268 00 00 0000 00 00 E800
dev:1752 2023-01-20 08:54:54.423 PMinfoTest Received Write Attribute Response for cluster:0000 , data=[86, DE, FF] (Status: Failure)
dev:1752 2023-01-20 08:54:54.420 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 C268 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:C268, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:1752 2023-01-20 08:54:54.417 PMdebugTest parse: description is catchall: 0104 0000 01 01 0040 00 C268 00 00 0000 04 01 86DEFF
dev:1752 2023-01-20 08:54:54.340 PMdebugTest skipping Tuya parse of cluster 0 attrId 4
dev:1752 2023-01-20 08:54:54.336 PMdebugTest parse: description is read attr - raw: C26801000064040042105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86, dni: C268, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86
dev:1752 2023-01-20 08:54:54.228 PMinfoTest Received device announcement, data=[13, 68, C2, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E] (Sequence Number:13, Device network ID: C268, Capability Information: 8E)
dev:1752 2023-01-20 08:54:54.225 PMdebugTest parse: Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 C268 00 00 0000 00 00 1368C27E9A01602BD5B3708E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C268, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[13, 68, C2, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E]]
dev:1752 2023-01-20 08:54:54.221 PMdebugTest parse: description is catchall: 0000 0013 00 00 0040 00 C268 00 00 0000 00 00 1368C27E9A01602BD5B3708E
sys:1 2023-01-20 08:54:54.208 PMinfoFound previously joined Zigbee device Test
dev:1752 2023-01-20 08:54:54.204 PMwarnTest WARNING! This TS011F plug manufacturer _TZ3000_okaz9tjs is known to be problematic with HE!
dev:1752 2023-01-20 08:54:54.195 PMtraceTest sendZigbeeCommands : [he raw 0xC268 1 0xFF 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0xC268 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind C268 01 0x01 0x0006 {70B3D52B60019A7E} {}, delay 250, he cr 0xC268 01 6 0 16 0 900 {}, delay 250, zdo bind 0xC268 0x01 0x01 0x0702 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC268 0x01 1794 0 37 15 60 {010000000000} {}, delay 2000, he raw 0xC268 1 0x01 0x0702 {10 00 08 00 0000}, delay 250, zdo bind 0xC268 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC268 0x01 2820 1291 41 15 60 {0100} {}, delay 2000, he raw 0xC268 1 0x01 0x0B04 {10 00 08 00 0B05}, delay 250, zdo bind 0xC268 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC268 0x01 2820 1285 33 15 60 {0100} {}, delay 2000, he raw 0xC268 1 0x01 0x0B04 {10 00 08 00 0505}, delay 250, zdo bind 0xC268 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC268 0x01 2820 1288 33 15 60 {1900} {}, delay 2000, he raw 0xC268 1 0x01 0x0B04 {10 00 08 00 0805}, delay 250]
dev:1752 2023-01-20 08:54:54.192 PMtraceTest configureReporting operation=Write, measurement=Amperage minTime=15, maxTime=60, delta=25 )
dev:1752 2023-01-20 08:54:54.189 PMtraceTest configureReporting operation=Write, measurement=Voltage minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:54:54.185 PMtraceTest configureReporting operation=Write, measurement=Power minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:54:54.181 PMtraceTest configureReporting operation=Write, measurement=Energy minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:54:54.179 PMdebugTest skipping onOff standard configuration for an odd Tuya device...
dev:1752 2023-01-20 08:54:54.178 PMwarnfixing other Tuya oddities ...
dev:1752 2023-01-20 08:54:54.177 PMdebugTest ep=01 isF2=false
dev:1752 2023-01-20 08:54:54.141 PMinfoTest configure()..
dev:1752 2023-01-20 08:54:48.554 PMinfoTest Received Configure Reporting Response for cluster:0006 , data=[00] (Status: Success)
dev:1752 2023-01-20 08:54:48.551 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 7019 00 00 0000 07 01 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7019, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:1752 2023-01-20 08:54:48.548 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 7019 00 00 0000 07 01 00
dev:1752 2023-01-20 08:54:48.242 PMinfoTest Received bind response, data=[DC, 00] (Sequence Number:DC, Status: Success)
dev:1752 2023-01-20 08:54:48.240 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 7019 00 00 0000 00 00 DC00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7019, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[DC, 00]]
dev:1752 2023-01-20 08:54:48.236 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 7019 00 00 0000 00 00 DC00
dev:1752 2023-01-20 08:54:48.172 PMinfoTest Received Write Attribute Response for cluster:0000 , data=[86, DE, FF] (Status: Failure)
dev:1752 2023-01-20 08:54:48.169 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 7019 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7019, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:1752 2023-01-20 08:54:48.166 PMdebugTest parse: description is catchall: 0104 0000 01 01 0040 00 7019 00 00 0000 04 01 86DEFF
dev:1752 2023-01-20 08:54:48.145 PMdebugTest skipping Tuya parse of cluster 0 attrId 4
dev:1752 2023-01-20 08:54:48.142 PMdebugTest parse: description is read attr - raw: 701901000064040042105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86, dni: 7019, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86
dev:1752 2023-01-20 08:54:47.929 PMinfoTest Received device announcement, data=[10, 19, 70, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E] (Sequence Number:10, Device network ID: 7019, Capability Information: 8E)
dev:1752 2023-01-20 08:54:47.927 PMdebugTest parse: Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 7019 00 00 0000 00 00 1019707E9A01602BD5B3708E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7019, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[10, 19, 70, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E]]
dev:1752 2023-01-20 08:54:47.923 PMdebugTest parse: description is catchall: 0000 0013 00 00 0040 00 7019 00 00 0000 00 00 1019707E9A01602BD5B3708E
sys:1 2023-01-20 08:54:47.909 PMinfoFound previously joined Zigbee device Test
dev:1752 2023-01-20 08:54:47.905 PMwarnTest WARNING! This TS011F plug manufacturer _TZ3000_okaz9tjs is known to be problematic with HE!
dev:1752 2023-01-20 08:54:47.896 PMtraceTest sendZigbeeCommands : [he raw 0x7019 1 0xFF 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x7019 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 7019 01 0x01 0x0006 {70B3D52B60019A7E} {}, delay 250, he cr 0x7019 01 6 0 16 0 900 {}, delay 250, zdo bind 0x7019 0x01 0x01 0x0702 {70B3D52B60019A7E} {}, delay 2000, he cr 0x7019 0x01 1794 0 37 15 60 {010000000000} {}, delay 2000, he raw 0x7019 1 0x01 0x0702 {10 00 08 00 0000}, delay 250, zdo bind 0x7019 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x7019 0x01 2820 1291 41 15 60 {0100} {}, delay 2000, he raw 0x7019 1 0x01 0x0B04 {10 00 08 00 0B05}, delay 250, zdo bind 0x7019 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x7019 0x01 2820 1285 33 15 60 {0100} {}, delay 2000, he raw 0x7019 1 0x01 0x0B04 {10 00 08 00 0505}, delay 250, zdo bind 0x7019 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x7019 0x01 2820 1288 33 15 60 {1900} {}, delay 2000, he raw 0x7019 1 0x01 0x0B04 {10 00 08 00 0805}, delay 250]
dev:1752 2023-01-20 08:54:47.893 PMtraceTest configureReporting operation=Write, measurement=Amperage minTime=15, maxTime=60, delta=25 )
dev:1752 2023-01-20 08:54:47.889 PMtraceTest configureReporting operation=Write, measurement=Voltage minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:54:47.885 PMtraceTest configureReporting operation=Write, measurement=Power minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:54:47.881 PMtraceTest configureReporting operation=Write, measurement=Energy minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:54:47.879 PMdebugTest skipping onOff standard configuration for an odd Tuya device...
dev:1752 2023-01-20 08:54:47.878 PMwarnfixing other Tuya oddities ...
dev:1752 2023-01-20 08:54:47.877 PMdebugTest ep=01 isF2=false
dev:1752 2023-01-20 08:54:47.839 PMinfoTest configure()..
dev:1752 2023-01-20 08:54:42.432 PMinfoTest Received bind response, data=[D6, 00] (Sequence Number:D6, Status: Success)
dev:1752 2023-01-20 08:54:42.429 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 4EA3 00 00 0000 00 00 D600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:4EA3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D6, 00]]
dev:1752 2023-01-20 08:54:42.426 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 4EA3 00 00 0000 00 00 D600
dev:1752 2023-01-20 08:54:42.166 PMinfoTest Received Configure Reporting Response for cluster:0006 , data=[00] (Status: Success)
dev:1752 2023-01-20 08:54:42.163 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 4EA3 00 00 0000 07 01 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4EA3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:1752 2023-01-20 08:54:42.160 PMdebugTest parse: description is catchall: 0104 0006 01 01 0040 00 4EA3 00 00 0000 07 01 00
dev:1752 2023-01-20 08:54:41.948 PMinfoTest Received bind response, data=[D4, 00] (Sequence Number:D4, Status: Success)
dev:1752 2023-01-20 08:54:41.945 PMdebugTest parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 4EA3 00 00 0000 00 00 D400, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:4EA3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D4, 00]]
dev:1752 2023-01-20 08:54:41.941 PMdebugTest parse: description is catchall: 0000 8021 00 00 0040 00 4EA3 00 00 0000 00 00 D400
dev:1752 2023-01-20 08:54:41.882 PMinfoTest Received Write Attribute Response for cluster:0000 , data=[86, DE, FF] (Status: Failure)
dev:1752 2023-01-20 08:54:41.879 PMdebugTest parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 4EA3 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:4EA3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:1752 2023-01-20 08:54:41.875 PMdebugTest parse: description is catchall: 0104 0000 01 01 0040 00 4EA3 00 00 0000 04 01 86DEFF
dev:1752 2023-01-20 08:54:41.855 PMdebugTest skipping Tuya parse of cluster 0 attrId 4
dev:1752 2023-01-20 08:54:41.852 PMdebugTest parse: description is read attr - raw: 4EA301000064040042105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86, dni: 4EA3, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86
dev:1752 2023-01-20 08:54:41.687 PMinfoTest Received device announcement, data=[0D, A3, 4E, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E] (Sequence Number:0D, Device network ID: 4EA3, Capability Information: 8E)
dev:1752 2023-01-20 08:54:41.684 PMdebugTest parse: Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 4EA3 00 00 0000 00 00 0DA34E7E9A01602BD5B3708E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:4EA3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[0D, A3, 4E, 7E, 9A, 01, 60, 2B, D5, B3, 70, 8E]]
dev:1752 2023-01-20 08:54:41.629 PMdebugTest parse: description is catchall: 0000 0013 00 00 0040 00 4EA3 00 00 0000 00 00 0DA34E7E9A01602BD5B3708E
sys:1 2023-01-20 08:54:41.610 PMinfoFound previously joined Zigbee device Test
dev:1752 2023-01-20 08:54:41.605 PMwarnTest WARNING! This TS011F plug manufacturer _TZ3000_okaz9tjs is known to be problematic with HE!
dev:1752 2023-01-20 08:54:41.560 PMtraceTest sendZigbeeCommands : [he raw 0x4EA3 1 0xFF 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x4EA3 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 4EA3 01 0x01 0x0006 {70B3D52B60019A7E} {}, delay 250, he cr 0x4EA3 01 6 0 16 0 900 {}, delay 250, zdo bind 0x4EA3 0x01 0x01 0x0702 {70B3D52B60019A7E} {}, delay 2000, he cr 0x4EA3 0x01 1794 0 37 15 60 {010000000000} {}, delay 2000, he raw 0x4EA3 1 0x01 0x0702 {10 00 08 00 0000}, delay 250, zdo bind 0x4EA3 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x4EA3 0x01 2820 1291 41 15 60 {0100} {}, delay 2000, he raw 0x4EA3 1 0x01 0x0B04 {10 00 08 00 0B05}, delay 250, zdo bind 0x4EA3 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x4EA3 0x01 2820 1285 33 15 60 {0100} {}, delay 2000, he raw 0x4EA3 1 0x01 0x0B04 {10 00 08 00 0505}, delay 250, zdo bind 0x4EA3 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0x4EA3 0x01 2820 1288 33 15 60 {1900} {}, delay 2000, he raw 0x4EA3 1 0x01 0x0B04 {10 00 08 00 0805}, delay 250]
dev:1752 2023-01-20 08:54:41.557 PMtraceTest configureReporting operation=Write, measurement=Amperage minTime=15, maxTime=60, delta=25 )
dev:1752 2023-01-20 08:54:41.553 PMtraceTest configureReporting operation=Write, measurement=Voltage minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:54:41.547 PMtraceTest configureReporting operation=Write, measurement=Power minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:54:41.543 PMtraceTest configureReporting operation=Write, measurement=Energy minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:54:41.541 PMdebugTest skipping onOff standard configuration for an odd Tuya device...
dev:1752 2023-01-20 08:54:41.540 PMwarnfixing other Tuya oddities ...
dev:1752 2023-01-20 08:54:41.539 PMdebugTest ep=01 isF2=false
dev:1752 2023-01-20 08:54:41.497 PMinfoTest configure()..
sys:1 2023-01-20 08:54:37.621 PMinfoZigbee Discovery Running
dev:1752 2023-01-20 08:54:30.123 PMtraceTest sendZigbeeCommands : [he raw 0xC2E3 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:1752 2023-01-20 08:54:30.100 PMdebugTest polling all 0x0B04 attributes
dev:1752 2023-01-20 08:54:30.098 PMdebugTest polling.. refreshAll is false
dev:1752 2023-01-20 08:54:30.095 PMdebugTest autoPoll()
dev:1752 2023-01-20 08:54:00.117 PMtraceTest sendZigbeeCommands : [he raw 0xC2E3 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:1752 2023-01-20 08:54:00.095 PMdebugTest polling all 0x0B04 attributes
dev:1752 2023-01-20 08:54:00.093 PMdebugTest polling.. refreshAll is false
dev:1752 2023-01-20 08:54:00.091 PMdebugTest autoPoll()
dev:1752 2023-01-20 08:53:30.166 PMtraceTest sendZigbeeCommands : [he raw 0xC2E3 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:1752 2023-01-20 08:53:30.144 PMdebugTest polling all 0x0B04 attributes
dev:1752 2023-01-20 08:53:30.142 PMdebugTest polling.. refreshAll is false
dev:1752 2023-01-20 08:53:30.140 PMdebugTest autoPoll()
dev:1752 2023-01-20 08:53:00.092 PMtraceTest sendZigbeeCommands : [he raw 0xC2E3 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:1752 2023-01-20 08:53:00.069 PMdebugTest polling all 0x0B04 attributes
dev:1752 2023-01-20 08:53:00.068 PMdebugTest polling.. refreshAll is false
dev:1752 2023-01-20 08:53:00.064 PMdebugTest autoPoll()
dev:1752 2023-01-20 08:52:30.153 PMtraceTest sendZigbeeCommands : [he raw 0xC2E3 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:1752 2023-01-20 08:52:30.130 PMdebugTest polling all 0x0B04 attributes
dev:1752 2023-01-20 08:52:30.128 PMdebugTest polling.. refreshAll is false
dev:1752 2023-01-20 08:52:30.123 PMdebugTest autoPoll()
dev:1752 2023-01-20 08:52:00.113 PMtraceTest sendZigbeeCommands : [he raw 0xC2E3 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200]
dev:1752 2023-01-20 08:49:24.970 PMtraceTest sendZigbeeCommands : [he raw 0xC2E3 1 0xFF 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0xC2E3 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind C2E3 01 0x01 0x0006 {70B3D52B60019A7E} {}, delay 250, he cr 0xC2E3 01 6 0 16 0 900 {}, delay 250, zdo bind 0xC2E3 0x01 0x01 0x0702 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC2E3 0x01 1794 0 37 15 60 {010000000000} {}, delay 2000, he raw 0xC2E3 1 0x01 0x0702 {10 00 08 00 0000}, delay 250, zdo bind 0xC2E3 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC2E3 0x01 2820 1291 41 15 60 {0100} {}, delay 2000, he raw 0xC2E3 1 0x01 0x0B04 {10 00 08 00 0B05}, delay 250, zdo bind 0xC2E3 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC2E3 0x01 2820 1285 33 15 60 {0100} {}, delay 2000, he raw 0xC2E3 1 0x01 0x0B04 {10 00 08 00 0505}, delay 250, zdo bind 0xC2E3 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC2E3 0x01 2820 1288 33 15 60 {1900} {}, delay 2000, he raw 0xC2E3 1 0x01 0x0B04 {10 00 08 00 0805}, delay 250]
dev:1752 2023-01-20 08:49:24.967 PMtraceTest configureReporting operation=Write, measurement=Amperage minTime=15, maxTime=60, delta=25 )
dev:1752 2023-01-20 08:49:24.964 PMtraceTest configureReporting operation=Write, measurement=Voltage minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:49:24.960 PMtraceTest configureReporting operation=Write, measurement=Power minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:49:24.957 PMtraceTest configureReporting operation=Write, measurement=Energy minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:49:24.955 PMdebugTest skipping onOff standard configuration for an odd Tuya device...
dev:1752 2023-01-20 08:49:24.954 PMwarnfixing other Tuya oddities ...
dev:1752 2023-01-20 08:49:24.953 PMdebugTest ep=01 isF2=false
dev:1752 2023-01-20 08:49:24.917 PMinfoTest configure()..
dev:1752 2023-01-20 08:49:24.914 PMinfoTest configuring the switch and energy reporting..
dev:1752 2023-01-20 08:49:24.913 PMinfoTest Auto polling is enabled, polling interval is 30 seconds
dev:1752 2023-01-20 08:49:24.884 PMinfoTest Debug logging will be automatically switched off after 24 hours
dev:1752 2023-01-20 08:49:24.852 PMinfoTest Debug logging is true Description text logging is true
dev:1752 2023-01-20 08:49:24.850 PMinfoTest Updating Test (Tuya Zigbee Metering Plug) model TS011F presence: present AlwaysOn is false
dev:1752 2023-01-20 08:49:15.866 PMtraceTuya Zigbee Metering Plug sendZigbeeCommands : [he raw 0xC2E3 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200, he raw 0xC2E3 1 0x01 0x0702 {10 00 00 00 00}, delay 200, he rattr 0xC2E3 0x01 6 0 {}, delay 2000]
dev:1752 2023-01-20 08:49:15.831 PMdebugTuya Zigbee Metering Plug polling all 0x0B04 attributes
dev:1752 2023-01-20 08:49:15.826 PMdebugTuya Zigbee Metering Plug polling.. refreshAll is true
dev:1752 2023-01-20 08:49:15.820 PMinfoTuya Zigbee Metering Plug refresh()...
dev:1752 2023-01-20 08:49:15.040 PMinfoTuya Zigbee Metering Plug Energy (total:0.0 kWh) was reset on 2023-01-20 20:49:14.786
dev:1752 2023-01-20 08:49:14.992 PMinfoTuya Zigbee Metering Plug hourlyEnergy is 0 kWh
dev:1752 2023-01-20 08:49:14.987 PMinfoTuya Zigbee Metering Plug energy is 0.0 kWh (refresh), energyCost=$0.0 (rate=$0.5), duration=0 Mins
dev:1752 2023-01-20 08:49:14.914 PMdebugTuya Zigbee Metering Plug energy_total=0, state.lastResetEnergy=0.0
dev:1752 2023-01-20 08:49:14.785 PMdebugresetEnergy() : state.lastEnergyRaw = 0.0
dev:1752 2023-01-20 08:49:13.764 PMtraceTuya Zigbee Metering Plug destinationEP = 01
dev:1752 2023-01-20 08:49:13.663 PMwarnstate.lastResetEnergy = null, resetting it back to 0!
dev:1752 2023-01-20 08:49:13.662 PMtraceTuya Zigbee Metering Plug model = TS011F
dev:1752 2023-01-20 08:49:13.660 PMwarnTuya Zigbee Metering Plug preservedResetEnergy = 0
dev:1752 2023-01-20 08:49:13.659 PMwarnTuya Zigbee Metering Plug clearing states and preferences ...
dev:1752 2023-01-20 08:49:13.657 PMinfoTuya Zigbee Metering Plug InitializeVars()... fullInit = true
dev:1752 2023-01-20 08:49:13.632 PMwarnTuya Zigbee Metering Plug Initialize()...
dev:1752 2023-01-20 08:49:09.700 PMinfoTuya Zigbee Metering Plug Received bind response, data=[60, 00] (Sequence Number:60, Status: Success)
dev:1752 2023-01-20 08:49:09.697 PMdebugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 C2E3 00 00 0000 00 00 6000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C2E3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[60, 00]]
dev:1752 2023-01-20 08:49:09.693 PMdebugTuya Zigbee Metering Plug parse: description is catchall: 0000 8021 00 00 0040 00 C2E3 00 00 0000 00 00 6000
sys:1 2023-01-20 08:49:09.589 PMinfoZigbee Discovery Stopped
dev:1752 2023-01-20 08:49:09.501 PMinfoTuya Zigbee Metering Plug Tuya Zigbee Metering Plug Tuya Zigbee Metering Plug switch is on (refresh)
dev:1752 2023-01-20 08:49:09.444 PMdebugTuya Zigbee Metering Plug Switch state changed from unknown to on
dev:1752 2023-01-20 08:49:09.442 PMdebugTuya Zigbee Metering Plug Event enter: [name:switch, value:on]
dev:1752 2023-01-20 08:49:09.438 PMdebugTuya Zigbee Metering Plug parse: description is read attr - raw: C2E30100060800001001, dni: C2E3, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01
dev:1752 2023-01-20 08:49:09.429 PMinfoTuya Zigbee Metering Plug Received Configure Reporting Response for cluster:0006 , data=[00] (Status: Success)
dev:1752 2023-01-20 08:49:09.426 PMdebugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 C2E3 00 00 0000 07 01 00, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:C2E3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:1752 2023-01-20 08:49:09.421 PMdebugTuya Zigbee Metering Plug parse: description is catchall: 0104 0006 01 01 0040 00 C2E3 00 00 0000 07 01 00
dev:1752 2023-01-20 08:49:09.196 PMinfoTuya Zigbee Metering Plug Received bind response, data=[5E, 00] (Sequence Number:5E, Status: Success)
dev:1752 2023-01-20 08:49:09.193 PMdebugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 C2E3 00 00 0000 00 00 5E00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C2E3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[5E, 00]]
dev:1752 2023-01-20 08:49:09.188 PMdebugTuya Zigbee Metering Plug parse: description is catchall: 0000 8021 00 00 0040 00 C2E3 00 00 0000 00 00 5E00
dev:1752 2023-01-20 08:49:09.094 PMinfoTuya Zigbee Metering Plug Received Write Attribute Response for cluster:0000 , data=[86, DE, FF] (Status: Failure)
dev:1752 2023-01-20 08:49:09.087 PMdebugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 C2E3 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:C2E3, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:1752 2023-01-20 08:49:09.083 PMdebugTuya Zigbee Metering Plug parse: description is catchall: 0104 0000 01 01 0040 00 C2E3 00 00 0000 04 01 86DEFF
dev:1752 2023-01-20 08:49:09.064 PMdebugTuya Zigbee Metering Plug skipping Tuya parse of cluster 0 attrId 4
dev:1752 2023-01-20 08:49:09.019 PMdebugTuya Zigbee Metering Plug parse: description is read attr - raw: C2E301000064040042105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86, dni: C2E3, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F6F6B617A39746A73000000200201000020A005000042065453303131460700003001FEFF86
sys:1 2023-01-20 08:49:08.828 PMinfoCreated Zigbee Device Tuya Zigbee Metering Plug
dev:1752 2023-01-20 08:49:08.820 PMwarnTuya Zigbee Metering Plug WARNING! This TS011F plug manufacturer _TZ3000_okaz9tjs is known to be problematic with HE!
dev:1752 2023-01-20 08:49:08.795 PMtraceTuya Zigbee Metering Plug sendZigbeeCommands : [he raw 0xC2E3 1 0xFF 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0xC2E3 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind C2E3 01 0x01 0x0006 {70B3D52B60019A7E} {}, delay 250, he cr 0xC2E3 01 6 0 16 0 900 {}, delay 250, zdo bind 0xC2E3 0x01 0x01 0x0702 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC2E3 0x01 1794 0 37 15 60 {010000000000} {}, delay 2000, he raw 0xC2E3 1 0x01 0x0702 {10 00 08 00 0000}, delay 250, zdo bind 0xC2E3 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC2E3 0x01 2820 1291 41 15 60 {0100} {}, delay 2000, he raw 0xC2E3 1 0x01 0x0B04 {10 00 08 00 0B05}, delay 250, zdo bind 0xC2E3 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC2E3 0x01 2820 1285 33 15 60 {0100} {}, delay 2000, he raw 0xC2E3 1 0x01 0x0B04 {10 00 08 00 0505}, delay 250, zdo bind 0xC2E3 0x01 0x01 0x0B04 {70B3D52B60019A7E} {}, delay 2000, he cr 0xC2E3 0x01 2820 1288 33 15 60 {1900} {}, delay 2000, he raw 0xC2E3 1 0x01 0x0B04 {10 00 08 00 0805}, delay 250]
dev:1752 2023-01-20 08:49:08.785 PMtraceTuya Zigbee Metering Plug configureReporting operation=Write, measurement=Amperage minTime=15, maxTime=60, delta=25 )
dev:1752 2023-01-20 08:49:08.780 PMtraceTuya Zigbee Metering Plug configureReporting operation=Write, measurement=Voltage minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:49:08.772 PMtraceTuya Zigbee Metering Plug configureReporting operation=Write, measurement=Power minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:49:08.741 PMtraceTuya Zigbee Metering Plug configureReporting operation=Write, measurement=Energy minTime=15, maxTime=60, delta=1 )
dev:1752 2023-01-20 08:49:08.733 PMdebugTuya Zigbee Metering Plug skipping onOff standard configuration for an odd Tuya device...
dev:1752 2023-01-20 08:49:08.731 PMwarnfixing other Tuya oddities ...
dev:1752 2023-01-20 08:49:08.730 PMdebugTuya Zigbee Metering Plug ep=01 isF2=false
dev:1752 2023-01-20 08:49:08.649 PMinfoTuya Zigbee Metering Plug configure()..
dev:1752 2023-01-20 08:49:08.512 PMwarnstate.lastResetEnergy = null, resetting it back to 0!
dev:1752 2023-01-20 08:49:08.505 PMinfoTuya Zigbee Metering Plug Installed()...
sys:1 2023-01-20 08:48:46.044 PMinfoInitializing Zigbee Device 70B3D52B60019A7E, 5EC7
sys:1 2023-01-20 08:48:40.539 PMinfoZigbee Discovery Running
