[RELEASE] Tuya Zigbee Contact Sensor++ w/ healthStatus
Hi @andrew.moyle ,
Please manually update this driver to the latest dev. branch version - '1.2.6' '2024/09/28 9:01 AM'
Make sure the driver is assigned to the Sonoff SNZB-04P contact sensor and that the Debug logging is on. Then, pair the sensor again to your hub (without deleting it). Activate/deactivate the contact sensor once.
I will need the debug logs that follow the pairing process.
