Thanks again!
EDIT: Sorry for the confusion, but I can now turn it on remotely, via the hub. It definitely wasn't working yesterday. The rest of this post might be unhelpful!
As requested - debug logs showing the BSEED being turned off and back on at the device. Turning on is from 13:48:13.
dev:332022-10-03 13:48:13.958infoBathroom Underfloor Heating temperature is: 21.5°C
dev:332022-10-03 13:48:13.956traceprocessTuyaTemperatureReport dp_id=2 dp=24 :
dev:332022-10-03 13:48:13.954trace dp_id=2 dp=24 fncmd=215
dev:332022-10-03 13:47:54.317warn(duplicate) transid=170 dp_id=4 dp=36 fncmd=1 command=01 data = [15, AA, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:54.266warn(duplicate) transid=169 dp_id=4 dp=36 fncmd=1 command=01 data = [15, A9, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:54.216warn(duplicate) transid=168 dp_id=4 dp=36 fncmd=1 command=01 data = [15, A8, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:54.165warn(duplicate) transid=167 dp_id=4 dp=36 fncmd=1 command=01 data = [15, A7, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:54.110warn(duplicate) transid=166 dp_id=4 dp=36 fncmd=1 command=01 data = [15, A6, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:54.060warn(duplicate) transid=165 dp_id=4 dp=36 fncmd=1 command=01 data = [15, A5, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:54.010warn(duplicate) transid=164 dp_id=4 dp=36 fncmd=1 command=01 data = [15, A4, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.958warn(duplicate) transid=163 dp_id=4 dp=36 fncmd=1 command=01 data = [15, A3, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.909warn(duplicate) transid=162 dp_id=4 dp=36 fncmd=1 command=01 data = [15, A2, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.860warn(duplicate) transid=161 dp_id=4 dp=36 fncmd=1 command=01 data = [15, A1, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.823warn(duplicate) transid=160 dp_id=4 dp=36 fncmd=1 command=01 data = [15, A0, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.773warn(duplicate) transid=159 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 9F, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.705warn(duplicate) transid=158 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 9E, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.654warn(duplicate) transid=157 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 9D, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.605warn(duplicate) transid=156 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 9C, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.553warn(duplicate) transid=155 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 9B, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.505warn(duplicate) transid=154 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 9A, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.452warn(duplicate) transid=153 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 99, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.400warn(duplicate) transid=152 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 98, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.363warn(duplicate) transid=151 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 97, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.318warn(duplicate) transid=150 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 96, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.248warn(duplicate) transid=149 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 95, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.202warn(duplicate) transid=148 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 94, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.147warn(duplicate) transid=147 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 93, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.105warn(duplicate) transid=146 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 92, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.045warn(duplicate) transid=145 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 91, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:53.001warn(duplicate) transid=144 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 90, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:52.958warn(duplicate) transid=143 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 8F, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:52.897warn(duplicate) transid=142 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 8E, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:52.855warn(duplicate) transid=141 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 8D, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:52.797warn(duplicate) transid=140 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 8C, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:52.748warn(duplicate) transid=139 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 8B, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:52.693warn(duplicate) transid=138 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 8A, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:52.644warn(duplicate) transid=137 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 89, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:52.590warn(duplicate) transid=136 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 88, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:52.541warn(duplicate) transid=135 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 87, 24, 04, 00, 01, 01]
dev:332022-10-03 13:47:52.511infoBathroom Underfloor Heating thermostatOperatingState is: idle
dev:332022-10-03 13:47:52.508trace dp_id=4 dp=36 fncmd=1
dev:332022-10-03 13:47:46.978warn(duplicate) transid=144 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 90, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.926warn(duplicate) transid=143 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 8F, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.876warn(duplicate) transid=142 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 8E, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.825warn(duplicate) transid=141 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 8D, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.776warn(duplicate) transid=140 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 8C, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.722warn(duplicate) transid=139 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 8B, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.687warn(duplicate) transid=138 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 8A, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.622warn(duplicate) transid=137 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 89, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.570warn(duplicate) transid=136 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 88, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.523warn(duplicate) transid=135 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 87, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.469warn(duplicate) transid=134 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 86, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.420warn(duplicate) transid=133 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 85, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.368warn(duplicate) transid=132 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 84, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.318warn(duplicate) transid=131 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 83, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.268warn(duplicate) transid=130 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 82, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.219warn(duplicate) transid=129 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 81, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.184warn(duplicate) transid=128 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 80, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.115warn(duplicate) transid=127 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 7F, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.063warn(duplicate) transid=126 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 7E, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:46.012warn(duplicate) transid=125 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 7D, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:45.963warn(duplicate) transid=124 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 7C, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:45.912warn(duplicate) transid=123 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 7B, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:45.860warn(duplicate) transid=122 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 7A, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:45.825warn(duplicate) transid=121 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 79, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:45.759warn(duplicate) transid=120 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 78, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:45.718warn(duplicate) transid=119 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 77, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:45.673warn(duplicate) transid=118 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 76, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:45.615warn(duplicate) transid=117 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 75, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:45.568warn(duplicate) transid=116 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 74, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:47:45.530infoBathroom Underfloor Heating heatingSetpoint is: 10°C
dev:332022-10-03 13:47:45.526trace dp_id=2 dp=16 fncmd=10
dev:332022-10-03 13:47:42.070infoBathroom Underfloor Heating temperature is: 21.0°C
dev:332022-10-03 13:47:42.068traceprocessTuyaTemperatureReport dp_id=2 dp=24 :
dev:332022-10-03 13:47:42.065trace dp_id=2 dp=24 fncmd=210
dev:332022-10-03 13:47:42.037infoBathroom Underfloor Heating Thermostat mode (switch state) reported is: auto (dp=1, fncmd=1)
dev:332022-10-03 13:47:42.034trace dp_id=1 dp=1 fncmd=1
dev:332022-10-03 13:47:13.591infoBathroom Underfloor Heating temperature is: 21.0°C
dev:332022-10-03 13:47:13.589traceprocessTuyaTemperatureReport dp_id=2 dp=24 :
dev:332022-10-03 13:47:13.587trace dp_id=2 dp=24 fncmd=210
dev:332022-10-03 13:46:54.611debugBathroom Underfloor Heating basic cluster report : descMap = [raw:0A090100001801002048E2FF201FE4FF2000, dni:0A09, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:48, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:332022-10-03 13:46:51.967warn(duplicate) transid=131 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 83, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.920warn(duplicate) transid=130 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 82, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.865warn(duplicate) transid=129 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 81, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.821warn(duplicate) transid=128 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 80, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.769warn(duplicate) transid=127 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 7F, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.714warn(duplicate) transid=126 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 7E, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.663warn(duplicate) transid=125 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 7D, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.616warn(duplicate) transid=124 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 7C, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.581warn(duplicate) transid=123 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 7B, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.519warn(duplicate) transid=122 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 7A, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.455warn(duplicate) transid=121 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 79, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.408warn(duplicate) transid=120 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 78, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.353warn(duplicate) transid=119 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 77, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.305warn(duplicate) transid=118 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 76, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.253warn(duplicate) transid=117 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 75, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.209warn(duplicate) transid=116 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 74, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.150warn(duplicate) transid=115 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 73, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.103warn(duplicate) transid=114 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 72, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.048warn(duplicate) transid=113 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 71, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:51.000warn(duplicate) transid=112 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 70, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.949warn(duplicate) transid=111 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 6F, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.901warn(duplicate) transid=110 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 6E, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.847warn(duplicate) transid=109 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 6D, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.795warn(duplicate) transid=108 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 6C, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.745warn(duplicate) transid=107 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 6B, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.699warn(duplicate) transid=106 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 6A, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.644warn(duplicate) transid=105 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 69, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.592warn(duplicate) transid=104 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 68, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.541warn(duplicate) transid=103 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 67, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.494warn(duplicate) transid=102 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 66, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.440warn(duplicate) transid=101 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 65, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.390warn(duplicate) transid=100 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 64, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.340warn(duplicate) transid=99 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 63, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.289warn(duplicate) transid=98 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 62, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.239warn(duplicate) transid=97 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 61, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.199warn(duplicate) transid=96 dp_id=4 dp=36 fncmd=1 command=01 data = [15, 60, 24, 04, 00, 01, 01]
dev:332022-10-03 13:46:50.147infoBathroom Underfloor Heating thermostatOperatingState is: idle
dev:332022-10-03 13:46:50.145trace dp_id=4 dp=36 fncmd=1
dev:332022-10-03 13:46:44.572warn(duplicate) transid=80 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 50, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:44.529warn(duplicate) transid=79 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 4F, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:44.459warn(duplicate) transid=78 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 4E, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:44.407warn(duplicate) transid=77 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 4D, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:44.358warn(duplicate) transid=76 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 4C, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:44.305warn(duplicate) transid=75 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 4B, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:44.255warn(duplicate) transid=74 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 4A, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:44.204warn(duplicate) transid=97 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 61, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:44.154warn(duplicate) transid=96 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 60, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:44.103warn(duplicate) transid=95 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 5F, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:44.051warn(duplicate) transid=94 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 5E, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:44.001warn(duplicate) transid=93 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 5D, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.951warn(duplicate) transid=91 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 5B, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.899warn(duplicate) transid=90 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 5A, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.848warn(duplicate) transid=89 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 59, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.800warn(duplicate) transid=88 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 58, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.747warn(duplicate) transid=87 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 57, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.696warn(duplicate) transid=86 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 56, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.647warn(duplicate) transid=85 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 55, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.596warn(duplicate) transid=84 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 54, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.563warn(duplicate) transid=83 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 53, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.497warn(duplicate) transid=82 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 52, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.445warn(duplicate) transid=81 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 51, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.394warn(duplicate) transid=80 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 50, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.350warn(duplicate) transid=79 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 4F, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.299warn(duplicate) transid=78 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 4E, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.241warn(duplicate) transid=77 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 4D, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.190warn(duplicate) transid=76 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 4C, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:43.159warn(duplicate) transid=75 dp_id=2 dp=16 fncmd=10 command=01 data = [15, 4B, 10, 02, 00, 04, 00, 00, 00, 0A]
dev:332022-10-03 13:46:42.654infoBathroom Underfloor Heating heatingSetpoint is: 10°C
dev:332022-10-03 13:46:42.651trace dp_id=2 dp=16 fncmd=10
dev:332022-10-03 13:46:40.207infoBathroom Underfloor Heating temperature is: 21.0°C
dev:332022-10-03 13:46:40.205traceprocessTuyaTemperatureReport dp_id=2 dp=24 :
dev:332022-10-03 13:46:40.202trace dp_id=2 dp=24 fncmd=210
dev:332022-10-03 13:46:40.166infoBathroom Underfloor Heating Thermostat mode (switch state) reported is: off (dp=1, fncmd=0)
dev:332022-10-03 13:46:40.163trace dp_id=1 dp=1 fncmd=0
Here's the State Variables with the device switched off:
packetID : 50
rxCounter : 47963
setpoint : 0
heatingSetPointRetry : 0
txCounter : 147
duplicateCounter : 45145
old_dp : 36
mode : heat
modeSetRetry : 0
lastThermostatMode : auto
lastThermostatOperatingState : idle
driverVersion : 1.2.3 2022/09/05 11:01 PM
old_fncmd : 1
It's reporting "mode: heat", is that a clue?
