Hello! This is my first post in this forum. I have to say I appreciate all the time @kkossev has put into supporting this messy Tuya hardware.
I am in the process of evaluating several TRVs for myself, trying to decide which one to use. Fortunately several are available to purchase here in Romania, and I can return them when I don't like them. I may write about the whole experience when I am done, but, for now, to the issue at hand:
The TRV I am writing about today is an Avatto TRV07. For some reason, the driver or the device seem to be confused about when to use Celsius and when to use Fahrenheit. I am, obviously, only trying to use Celsius, I don't want any Fahrenheit in my life.
For example, using the "Set Heating Setpoint", I can set a temperature of 20 degrees, and the TRV sets it to 20 Celsius. But when I try to set 18, it sets the TRV to 15 degrees Celsius, and I get an info message in the logs saying: Dressing TRV temperature scale is: F (987648)
Also, there is no battery information. And no valve % open, like on other TRVs I've tested.
I am using the latest dev driver from github. I used the prod one with the same issues.
Please let me know if I can help with other information.
Logs
dev:2542023-11-14 13:44:10.984warnDressing TRV Thermostat model group UNKNOWN is not processed! (dp=3, fncmd=212)
dev:2542023-11-14 13:44:10.976debugDressing TRV processing command dp=3 fncmd=212 (lastThermostatMode=heat)
dev:2542023-11-14 13:44:10.968debugDressing TRV dp_id=2 dp=3 fncmd=212
dev:2542023-11-14 13:28:55.509debugDressing TRV device has received Tuya cluster ZCL command 0x24 response 0x00 data = [24, 00]
dev:2542023-11-14 13:28:55.359debugDressing TRV sending time data : [he cmd 0xA6FC 0x01 0xEF00 0x24 {0008655359F765537617}, delay 2000]
dev:2542023-11-14 13:28:55.352debugDressing TRV timezone offset of current location is 7200000 (2 hours), current hour is 13 h
dev:2542023-11-14 13:28:55.342debugDressing TRV time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 A6FC 01 00 0000 24 01 A700, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:A6FC, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[A7, 00]]
dev:2542023-11-14 12:58:55.063debugDressing TRV sending time data : [he cmd 0xA6FC 0x01 0xEF00 0x24 {0008655352EF65536F0F}, delay 2000]
dev:2542023-11-14 12:58:55.055debugDressing TRV timezone offset of current location is 7200000 (2 hours), current hour is 12 h
dev:2542023-11-14 12:58:55.046debugDressing TRV time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 A6FC 01 00 0000 24 01 A500, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:A6FC, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[A5, 00]]
dev:2542023-11-14 12:55:20.886warnDressing TRV Thermostat model group UNKNOWN is not processed! (dp=3, fncmd=217)
dev:2542023-11-14 12:55:20.872debugDressing TRV processing command dp=3 fncmd=217 (lastThermostatMode=heat)
dev:2542023-11-14 12:55:20.855debugDressing TRV dp_id=2 dp=3 fncmd=217
dev:2542023-11-14 12:28:54.623debugDressing TRV device has received Tuya cluster ZCL command 0x24 response 0x00 data = [24, 00]
dev:2542023-11-14 12:28:54.480debugDressing TRV sending time data : [he cmd 0xA6FC 0x01 0xEF00 0x24 {000865534BE665536806}, delay 2000]
dev:2542023-11-14 12:28:54.470debugDressing TRV timezone offset of current location is 7200000 (2 hours), current hour is 12 h
dev:2542023-11-14 12:28:54.460debugDressing TRV time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 A6FC 01 00 0000 24 01 A200, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:A6FC, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[A2, 00]]
dev:2542023-11-14 12:27:22.301warnDressing TRV Thermostat model group UNKNOWN is not processed! (dp=3, fncmd=222)
dev:2542023-11-14 12:27:22.293debugDressing TRV processing command dp=3 fncmd=222 (lastThermostatMode=heat)
dev:2542023-11-14 12:27:22.285debugDressing TRV dp_id=2 dp=3 fncmd=222
dev:2542023-11-14 12:09:07.718infoDressing TRV temperature scale is: F (987648)
dev:2542023-11-14 12:09:07.710debugDressing TRV dp_id=0 dp=23 fncmd=987648
dev:2542023-11-14 12:09:07.521warnDressing TRV NOT PROCESSED Tuya cmd: dp=22 value=987648 descMap.data = [00, 9E, 16, 00, 00, 11, 06, 06, 00, 00, 0F, 0C, 00, 00, 0F, 12, 00, 00, 0F, 16, 00, 00, 0F]
dev:2542023-11-14 12:09:07.513debugDressing TRV dp_id=0 dp=22 fncmd=987648
dev:2542023-11-14 12:09:07.335warnDressing TRV ignoring BatteryPercentageResult(1975296)
dev:2542023-11-14 12:09:07.328infoDressing TRV battery is: 987648 % (dp=21)
dev:2542023-11-14 12:09:07.322debugDressing TRV dp_id=0 dp=21 fncmd=987648
dev:2542023-11-14 12:09:07.181infoDressing TRV Dead Zone Temp (hysteresis) is: 987648
dev:2542023-11-14 12:09:07.163debugDressing TRV dp_id=0 dp=20 fncmd=987648
dev:2542023-11-14 12:09:06.933infoDressing TRV UNKNOWN Max Temp Limit is: 987648 C (dp=19, fncmd=987648)
dev:2542023-11-14 12:09:06.925debugDressing TRV dp_id=0 dp=19 fncmd=987648
dev:2542023-11-14 12:09:06.735infoDressing TRV Max Temp Limit is: 987648
dev:2542023-11-14 12:09:06.727debugDressing TRV dp_id=0 dp=18 fncmd=987648
dev:2542023-11-14 12:09:06.538infoDressing TRV Set temperature F is: 987648
dev:2542023-11-14 12:09:06.530debugDressing TRV dp_id=0 dp=17 fncmd=987648
dev:2542023-11-14 12:09:06.370warnDressing TRV Thermostat model group UNKNOWN is not processed! (dp=3, fncmd=227)
dev:2542023-11-14 12:09:06.346debugDressing TRV processing command dp=3 fncmd=227 (lastThermostatMode=heat)
dev:2542023-11-14 12:09:06.335debugDressing TRV dp_id=2 dp=3 fncmd=227
dev:2542023-11-14 12:09:06.177infoDressing TRV heatingSetpoint is: 15.0°C
dev:2542023-11-14 12:09:06.168debugDressing TRV dp_id=2 dp=16 fncmd=15
dev:2542023-11-14 12:09:06.059debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 12:09:05.534debugDressing TRV sendZigbeeCommands(cmd=[he cmd 0xA6FC 0x01 0xEF00 0x00 {00011002000400000012} {}, delay 200])
dev:2542023-11-14 12:09:05.525debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00011002000400000012} {}, delay 200]
dev:2542023-11-14 12:09:05.431debugDressing TRV changing setpoint to 18.0
dev:2542023-11-14 12:09:05.418debugDressing TRV sendTuyaHeatingSetpoint(18.0)
dev:2542023-11-14 12:09:05.411debugDressing TRV setHeatingSetpoint temperature = 18 as int = 18 (previousSetpointt = 20.0)
dev:2542023-11-14 12:08:41.710debugDressing TRV nothing to update
dev:2542023-11-14 12:08:41.645infoDebug logging is true; Description text logging is true
dev:2542023-11-14 12:08:41.636infoForce manual is false; Resend failed is false
dev:2542023-11-14 12:08:41.628infoUpdating Dressing TRV (Avatto TRV07) model TS0601 manufacturer _TZE200_bvrlmajk modelGroupPreference = Auto detect (UNKNOWN)
dev:2542023-11-14 12:08:41.620infoDressing TRV press F5 to refresh the page
dev:2542023-11-14 12:08:41.612infoDressing TRV InitializeVars()... fullInit = false
dev:2542023-11-14 12:08:41.605warnDressing TRV changing the device profile from null to Auto detect
dev:2542023-11-14 12:08:41.596debugDressing TRV current state.deviceProfile=null, settings.modelGroupPreference=Auto detect, getModelGroup()=UNKNOWN
dev:2542023-11-14 11:59:02.148infoDressing TRV temperature scale is: F (3281408)
dev:2542023-11-14 11:59:02.141debugDressing TRV dp_id=0 dp=23 fncmd=3281408
dev:2542023-11-14 11:59:01.953warnDressing TRV NOT PROCESSED Tuya cmd: dp=22 value=3281408 descMap.data = [00, 95, 16, 00, 00, 11, 06, 06, 00, 00, 32, 0C, 00, 00, 32, 12, 00, 00, 32, 16, 00, 00, 32]
dev:2542023-11-14 11:59:01.946debugDressing TRV dp_id=0 dp=22 fncmd=3281408
dev:2542023-11-14 11:59:01.483warnDressing TRV ignoring BatteryPercentageResult(6562816)
dev:2542023-11-14 11:59:01.464infoDressing TRV battery is: 3281408 % (dp=21)
dev:2542023-11-14 11:59:01.451debugDressing TRV dp_id=0 dp=21 fncmd=3281408
dev:2542023-11-14 11:59:01.172infoDressing TRV lower limit F is: 3281408
dev:2542023-11-14 11:59:01.161debugDressing TRV dp_id=0 dp=20 fncmd=3281408
dev:2542023-11-14 11:59:00.977infoDressing TRV AVATTO Max Temp Limit is: 3281408 C (dp=19, fncmd=3281408)
dev:2542023-11-14 11:59:00.895debugDressing TRV dp_id=0 dp=19 fncmd=3281408
dev:2542023-11-14 11:59:00.690infoDressing TRV Set temperature upper limit F is: 3281408
dev:2542023-11-14 11:59:00.666debugDressing TRV dp_id=0 dp=18 fncmd=3281408
dev:2542023-11-14 11:59:00.490infoDressing TRV Set temperature F is: 3281408
dev:2542023-11-14 11:59:00.478debugDressing TRV dp_id=0 dp=17 fncmd=3281408
dev:2542023-11-14 11:59:00.228infoDressing TRV heatingSetpoint is: 20.0°C
dev:2542023-11-14 11:59:00.221debugDressing TRV dp_id=2 dp=16 fncmd=20
dev:2542023-11-14 11:59:00.132debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:58:59.812debugDressing TRV sendZigbeeCommands(cmd=[he cmd 0xA6FC 0x01 0xEF00 0x00 {00041002000400000014} {}, delay 200])
dev:2542023-11-14 11:58:59.805debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00041002000400000014} {}, delay 200]
dev:2542023-11-14 11:58:59.753debugDressing TRV changing setpoint to 20.0
dev:2542023-11-14 11:58:59.744debugDressing TRV sendTuyaHeatingSetpoint(20.0)
dev:2542023-11-14 11:58:59.737debugDressing TRV setHeatingSetpoint temperature = 20 as int = 20 (previousSetpointt = 15.0)
dev:2542023-11-14 11:58:42.040infoDressing TRV temperature scale is: F (987648)
dev:2542023-11-14 11:58:42.033debugDressing TRV dp_id=0 dp=23 fncmd=987648
dev:2542023-11-14 11:58:41.855warnDressing TRV NOT PROCESSED Tuya cmd: dp=22 value=987648 descMap.data = [00, 8D, 16, 00, 00, 11, 06, 06, 00, 00, 0F, 0C, 00, 00, 0F, 12, 00, 00, 0F, 16, 00, 00, 0F]
dev:2542023-11-14 11:58:41.846debugDressing TRV dp_id=0 dp=22 fncmd=987648
dev:2542023-11-14 11:58:41.679warnDressing TRV ignoring BatteryPercentageResult(1975296)
dev:2542023-11-14 11:58:41.671infoDressing TRV battery is: 987648 % (dp=21)
dev:2542023-11-14 11:58:41.661debugDressing TRV dp_id=0 dp=21 fncmd=987648
dev:2542023-11-14 11:58:41.453infoDressing TRV lower limit F is: 987648
dev:2542023-11-14 11:58:41.446debugDressing TRV dp_id=0 dp=20 fncmd=987648
dev:2542023-11-14 11:58:41.297infoDressing TRV AVATTO Max Temp Limit is: 987648 C (dp=19, fncmd=987648)
dev:2542023-11-14 11:58:41.275debugDressing TRV dp_id=0 dp=19 fncmd=987648
dev:2542023-11-14 11:58:41.083infoDressing TRV Set temperature upper limit F is: 987648
dev:2542023-11-14 11:58:41.067debugDressing TRV dp_id=0 dp=18 fncmd=987648
dev:2542023-11-14 11:58:40.864infoDressing TRV Set temperature F is: 987648
dev:2542023-11-14 11:58:40.857debugDressing TRV dp_id=0 dp=17 fncmd=987648
dev:2542023-11-14 11:58:40.756infoDressing TRV heatingSetpoint is: 15.0°C
dev:2542023-11-14 11:58:40.739debugDressing TRV dp_id=2 dp=16 fncmd=15
dev:2542023-11-14 11:58:40.695debugDressing TRV device has received Tuya cluster ZCL command 0x24 response 0x00 data = [24, 00]
dev:2542023-11-14 11:58:40.578debugDressing TRV sending time data : [he cmd 0xA6FC 0x01 0xEF00 0x24 {0008655344D0655360F0}, delay 2000]
dev:2542023-11-14 11:58:40.569debugDressing TRV timezone offset of current location is 7200000 (2 hours), current hour is 11 h
dev:2542023-11-14 11:58:40.558debugDressing TRV time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 A6FC 01 00 0000 24 01 8600, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:A6FC, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[86, 00]]
dev:2542023-11-14 11:58:40.506debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:58:39.643debugDressing TRV sendZigbeeCommands(cmd=[he cmd 0xA6FC 0x01 0xEF00 0x00 {00031002000400000013} {}, delay 200])
dev:2542023-11-14 11:58:39.635debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00031002000400000013} {}, delay 200]
dev:2542023-11-14 11:58:39.577debugDressing TRV changing setpoint to 19.0
dev:2542023-11-14 11:58:39.571debugDressing TRV sendTuyaHeatingSetpoint(19.0)
dev:2542023-11-14 11:58:39.564debugDressing TRV setHeatingSetpoint temperature = 19 as int = 19 (previousSetpointt = 20.0)
dev:2542023-11-14 11:58:16.146infoDressing TRV temperature scale is: F (3281408)
dev:2542023-11-14 11:58:16.139debugDressing TRV dp_id=0 dp=23 fncmd=3281408
dev:2542023-11-14 11:58:15.953warnDressing TRV NOT PROCESSED Tuya cmd: dp=22 value=3281408 descMap.data = [00, 83, 16, 00, 00, 11, 06, 06, 00, 00, 32, 0C, 00, 00, 32, 12, 00, 00, 32, 16, 00, 00, 32]
dev:2542023-11-14 11:58:15.945debugDressing TRV dp_id=0 dp=22 fncmd=3281408
dev:2542023-11-14 11:58:15.759warnDressing TRV ignoring BatteryPercentageResult(6562816)
dev:2542023-11-14 11:58:15.752infoDressing TRV battery is: 3281408 % (dp=21)
dev:2542023-11-14 11:58:15.744debugDressing TRV dp_id=0 dp=21 fncmd=3281408
dev:2542023-11-14 11:58:15.555infoDressing TRV lower limit F is: 3281408
dev:2542023-11-14 11:58:15.547debugDressing TRV dp_id=0 dp=20 fncmd=3281408
dev:2542023-11-14 11:58:15.380infoDressing TRV AVATTO Max Temp Limit is: 3281408 C (dp=19, fncmd=3281408)
dev:2542023-11-14 11:58:15.371debugDressing TRV dp_id=0 dp=19 fncmd=3281408
dev:2542023-11-14 11:58:15.170infoDressing TRV Set temperature upper limit F is: 3281408
dev:2542023-11-14 11:58:15.163debugDressing TRV dp_id=0 dp=18 fncmd=3281408
dev:2542023-11-14 11:58:15.132infoDressing TRV Set temperature F is: 3281408
dev:2542023-11-14 11:58:14.982debugDressing TRV dp_id=0 dp=17 fncmd=3281408
dev:2542023-11-14 11:58:14.707infoDressing TRV Thermostat working status (thermostatOperatingState) reported is: idle (dp=3, fncmd=230)
dev:2542023-11-14 11:58:14.689debugDressing TRV processing command dp=3 fncmd=230 (lastThermostatMode=heat)
dev:2542023-11-14 11:58:14.680debugDressing TRV dp_id=2 dp=3 fncmd=230
dev:2542023-11-14 11:58:14.506infoDressing TRV heatingSetpoint is: 20.0°C
dev:2542023-11-14 11:58:14.491debugDressing TRV dp_id=2 dp=16 fncmd=20
dev:2542023-11-14 11:58:14.376debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:58:14.034debugDressing TRV sendZigbeeCommands(cmd=[he cmd 0xA6FC 0x01 0xEF00 0x00 {00021002000400000014} {}, delay 200])
dev:2542023-11-14 11:58:14.027debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00021002000400000014} {}, delay 200]
dev:2542023-11-14 11:58:13.936debugDressing TRV changing setpoint to 20.0
dev:2542023-11-14 11:58:13.930debugDressing TRV sendTuyaHeatingSetpoint(20.0)
dev:2542023-11-14 11:58:13.923debugDressing TRV setHeatingSetpoint temperature = 20 as int = 20 (previousSetpointt = 35.0)
dev:2542023-11-14 11:56:57.213infoDressing TRV temperature scale is: F (2298368)
dev:2542023-11-14 11:56:57.205debugDressing TRV dp_id=0 dp=23 fncmd=2298368
dev:2542023-11-14 11:56:57.015warnDressing TRV NOT PROCESSED Tuya cmd: dp=22 value=2298368 descMap.data = [00, 7A, 16, 00, 00, 11, 06, 06, 00, 00, 23, 0C, 00, 00, 23, 12, 00, 00, 23, 16, 00, 00, 23]
dev:2542023-11-14 11:56:57.008debugDressing TRV dp_id=0 dp=22 fncmd=2298368
dev:2542023-11-14 11:56:56.830warnDressing TRV ignoring BatteryPercentageResult(4596736)
dev:2542023-11-14 11:56:56.822infoDressing TRV battery is: 2298368 % (dp=21)
dev:2542023-11-14 11:56:56.814debugDressing TRV dp_id=0 dp=21 fncmd=2298368
dev:2542023-11-14 11:56:56.624infoDressing TRV lower limit F is: 2298368
dev:2542023-11-14 11:56:56.616debugDressing TRV dp_id=0 dp=20 fncmd=2298368
dev:2542023-11-14 11:56:56.455infoDressing TRV AVATTO Max Temp Limit is: 2298368 C (dp=19, fncmd=2298368)
dev:2542023-11-14 11:56:56.441debugDressing TRV dp_id=0 dp=19 fncmd=2298368
dev:2542023-11-14 11:56:56.289infoDressing TRV Set temperature upper limit F is: 2298368
dev:2542023-11-14 11:56:56.277debugDressing TRV dp_id=0 dp=18 fncmd=2298368
dev:2542023-11-14 11:56:55.937infoDressing TRV Set temperature F is: 2298368
dev:2542023-11-14 11:56:55.928debugDressing TRV dp_id=0 dp=17 fncmd=2298368
dev:2542023-11-14 11:56:55.775infoDressing TRV Thermostat working status (thermostatOperatingState) reported is: idle (dp=3, fncmd=231)
dev:2542023-11-14 11:56:55.756debugDressing TRV processing command dp=3 fncmd=231 (lastThermostatMode=heat)
dev:2542023-11-14 11:56:55.744debugDressing TRV dp_id=2 dp=3 fncmd=231
dev:2542023-11-14 11:56:55.614infoDressing TRV heatingSetpoint is: 35.0°C
dev:2542023-11-14 11:56:55.608debugDressing TRV dp_id=2 dp=16 fncmd=35
dev:2542023-11-14 11:56:55.453debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:56:55.053debugDressing TRV sendZigbeeCommands(cmd=[he cmd 0xA6FC 0x01 0xEF00 0x00 {00011002000400000023} {}, delay 200])
dev:2542023-11-14 11:56:55.042debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00011002000400000023} {}, delay 200]
dev:2542023-11-14 11:56:54.978debugDressing TRV changing setpoint to 35.0
dev:2542023-11-14 11:56:54.970debugDressing TRV sendTuyaHeatingSetpoint(35.0)
dev:2542023-11-14 11:56:54.958debugDressing TRV setHeatingSetpoint temperature = 68 as int = 68 (previousSetpointt = 15.0)
dev:2542023-11-14 11:47:42.718debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:47:42.689infoDressing TRV InitializeVars()... fullInit = false
dev:2542023-11-14 11:47:42.678debugDressing TRV updating the settings from the current driver version 1.3.0 2023/06/03 7:19 PM to the new version 1.3.1 2023/10/30 2:27 PM
dev:2542023-11-14 11:47:42.380debugDressing TRV sendZigbeeCommands(cmd=[he cmd 0xA6FC 0x01 0xEF00 0x00 {00162704000400000000} {}, delay 200])
dev:2542023-11-14 11:47:42.366debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00162704000400000000} {}, delay 200]
dev:2542023-11-14 11:47:42.352debugDressing TRV refresh() AVATTO...
dev:2542023-11-14 11:45:15.218debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:45:15.189debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:45:15.149debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:45:15.096debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:45:14.229debugDressing TRV sendZigbeeCommands(cmd=[he cmd 0xA6FC 0x01 0xEF00 0x00 {00121B02000400000000} {}, delay 200, he cmd 0xA6FC 0x01 0xEF00 0x00 {00136A02000400000000} {}, delay 200, he cmd 0xA6FC 0x01 0xEF00 0x00 {00141A0200040000000A} {}, delay 200, he cmd 0xA6FC 0x01 0xEF00 0x00 {00151302000400000023} {}, delay 200])
dev:2542023-11-14 11:45:14.220infoDressing TRV Update finished
dev:2542023-11-14 11:45:14.211debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00151302000400000023} {}, delay 200]
dev:2542023-11-14 11:45:14.202traceDressing TRV setting maxTemp to= 35
dev:2542023-11-14 11:45:14.193debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00141A0200040000000A} {}, delay 200]
dev:2542023-11-14 11:45:14.182debugDressing TRV setting minTemp to 10
dev:2542023-11-14 11:45:14.174debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00136A02000400000000} {}, delay 200]
dev:2542023-11-14 11:45:14.165debugDressing TRV setting hysteresis to 1.0 (0)
dev:2542023-11-14 11:45:14.157debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00121B02000400000000} {}, delay 200]
dev:2542023-11-14 11:45:14.149debugDressing TRV setting tempCalibration to 0.0 (0)
dev:2542023-11-14 11:45:14.141debugDressing TRV tempCalibration fncmd = 0
dev:2542023-11-14 11:45:14.132debugDressing TRV tempCalibration = 0.0
dev:2542023-11-14 11:45:14.061infoDebug logging is true; Description text logging is true
dev:2542023-11-14 11:45:14.052infoForce manual is false; Resend failed is false
dev:2542023-11-14 11:45:14.044infoUpdating Dressing TRV (Avatto TRV07) model TS0601 manufacturer _TZE200_bvrlmajk modelGroupPreference = AVATTO (AVATTO)
dev:2542023-11-14 11:43:56.385infoDressing TRV temperature scale is: F (3281408)
dev:2542023-11-14 11:43:56.372debugDressing TRV dp_id=0 dp=23 fncmd=3281408
dev:2542023-11-14 11:43:56.145warnDressing TRV NOT PROCESSED Tuya cmd: dp=22 value=3281408 descMap.data = [00, 71, 16, 00, 00, 11, 06, 06, 00, 00, 32, 0C, 00, 00, 32, 12, 00, 00, 32, 16, 00, 00, 32]
dev:2542023-11-14 11:43:56.128debugDressing TRV dp_id=0 dp=22 fncmd=3281408
dev:2542023-11-14 11:43:55.994warnDressing TRV ignoring BatteryPercentageResult(6562816)
dev:2542023-11-14 11:43:55.985infoDressing TRV battery is: 3281408 % (dp=21)
dev:2542023-11-14 11:43:55.978debugDressing TRV dp_id=0 dp=21 fncmd=3281408
dev:2542023-11-14 11:43:55.787infoDressing TRV lower limit F is: 3281408
dev:2542023-11-14 11:43:55.779debugDressing TRV dp_id=0 dp=20 fncmd=3281408
dev:2542023-11-14 11:43:55.590infoDressing TRV AVATTO Max Temp Limit is: 3281408 C (dp=19, fncmd=3281408)
dev:2542023-11-14 11:43:55.579debugDressing TRV dp_id=0 dp=19 fncmd=3281408
dev:2542023-11-14 11:43:55.408infoDressing TRV Set temperature upper limit F is: 3281408
dev:2542023-11-14 11:43:55.395debugDressing TRV dp_id=0 dp=18 fncmd=3281408
dev:2542023-11-14 11:43:55.163infoDressing TRV Set temperature F is: 3281408
dev:2542023-11-14 11:43:55.149debugDressing TRV dp_id=0 dp=17 fncmd=3281408
dev:2542023-11-14 11:43:54.952infoDressing TRV heatingSetpoint is: 15.0°C
dev:2542023-11-14 11:43:54.945debugDressing TRV dp_id=2 dp=16 fncmd=15
dev:2542023-11-14 11:43:54.872debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:43:54.157debugDressing TRV sendZigbeeCommands(cmd=[he cmd 0xA6FC 0x01 0xEF00 0x00 {00111002000400000012} {}, delay 200])
dev:2542023-11-14 11:43:54.137debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00111002000400000012} {}, delay 200]
dev:2542023-11-14 11:43:53.915debugDressing TRV changing setpoint to 18.0
dev:2542023-11-14 11:43:53.896debugDressing TRV sendTuyaHeatingSetpoint(18.0)
dev:2542023-11-14 11:43:53.888debugDressing TRV setHeatingSetpoint temperature = 18 as int = 18 (previousSetpointt = 35.0)
dev:2542023-11-14 11:43:39.336debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:43:38.456debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:43:38.222debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:43:38.192debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:43:37.904debugDressing TRV sendZigbeeCommands(cmd=[he cmd 0xA6FC 0x01 0xEF00 0x00 {000D1B02000400000000} {}, delay 200, he cmd 0xA6FC 0x01 0xEF00 0x00 {000E6A02000400000000} {}, delay 200, he cmd 0xA6FC 0x01 0xEF00 0x00 {000F1A0200040000000A} {}, delay 200, he cmd 0xA6FC 0x01 0xEF00 0x00 {00101302000400000023} {}, delay 200])
dev:2542023-11-14 11:43:37.896infoDressing TRV Update finished
dev:2542023-11-14 11:43:37.887debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {00101302000400000023} {}, delay 200]
dev:2542023-11-14 11:43:37.878traceDressing TRV setting maxTemp to= 35
dev:2542023-11-14 11:43:37.869debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {000F1A0200040000000A} {}, delay 200]
dev:2542023-11-14 11:43:37.860debugDressing TRV setting minTemp to 10
dev:2542023-11-14 11:43:37.851debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {000E6A02000400000000} {}, delay 200]
dev:2542023-11-14 11:43:37.842debugDressing TRV setting hysteresis to 1.0 (0)
dev:2542023-11-14 11:43:37.834debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {000D1B02000400000000} {}, delay 200]
dev:2542023-11-14 11:43:37.824debugDressing TRV setting tempCalibration to 0.0 (0)
dev:2542023-11-14 11:43:37.817debugDressing TRV tempCalibration fncmd = 0
dev:2542023-11-14 11:43:37.808debugDressing TRV tempCalibration = 0.0
dev:2542023-11-14 11:43:37.698infoDebug logging is true; Description text logging is true
dev:2542023-11-14 11:43:37.688infoForce manual is false; Resend failed is false
dev:2542023-11-14 11:43:37.675infoUpdating Dressing TRV (Avatto TRV07) model TS0601 manufacturer _TZE200_bvrlmajk modelGroupPreference = AVATTO (AVATTO)
dev:2542023-11-14 11:41:16.143infoDressing TRV temperature scale is: F (2298368)
dev:2542023-11-14 11:41:16.134debugDressing TRV dp_id=0 dp=23 fncmd=2298368
dev:2542023-11-14 11:41:15.947warnDressing TRV NOT PROCESSED Tuya cmd: dp=22 value=2298368 descMap.data = [00, 69, 16, 00, 00, 11, 06, 06, 00, 00, 23, 0C, 00, 00, 23, 12, 00, 00, 23, 16, 00, 00, 23]
dev:2542023-11-14 11:41:15.939debugDressing TRV dp_id=0 dp=22 fncmd=2298368
dev:2542023-11-14 11:41:15.764warnDressing TRV ignoring BatteryPercentageResult(4596736)
dev:2542023-11-14 11:41:15.755infoDressing TRV battery is: 2298368 % (dp=21)
dev:2542023-11-14 11:41:15.746debugDressing TRV dp_id=0 dp=21 fncmd=2298368
dev:2542023-11-14 11:41:15.560infoDressing TRV Dead Zone Temp (hysteresis) is: 2298368
dev:2542023-11-14 11:41:15.551debugDressing TRV dp_id=0 dp=20 fncmd=2298368
dev:2542023-11-14 11:41:15.363infoDressing TRV UNKNOWN Max Temp Limit is: 2298368 C (dp=19, fncmd=2298368)
dev:2542023-11-14 11:41:15.354debugDressing TRV dp_id=0 dp=19 fncmd=2298368
dev:2542023-11-14 11:41:15.167infoDressing TRV Max Temp Limit is: 2298368
dev:2542023-11-14 11:41:15.157debugDressing TRV dp_id=0 dp=18 fncmd=2298368
dev:2542023-11-14 11:41:15.028infoDressing TRV Set temperature F is: 2298368
dev:2542023-11-14 11:41:15.019debugDressing TRV dp_id=0 dp=17 fncmd=2298368
dev:2542023-11-14 11:41:14.753warnDressing TRV Thermostat model group UNKNOWN is not processed! (dp=3, fncmd=233)
dev:2542023-11-14 11:41:14.745debugDressing TRV processing command dp=3 fncmd=233 (lastThermostatMode=heat)
dev:2542023-11-14 11:41:14.736debugDressing TRV dp_id=2 dp=3 fncmd=233
dev:2542023-11-14 11:41:14.564infoDressing TRV heatingSetpoint is: 35.0°C
dev:2542023-11-14 11:41:14.529debugDressing TRV dp_id=2 dp=16 fncmd=35
dev:2542023-11-14 11:41:14.440debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:41:13.559debugDressing TRV sendZigbeeCommands(cmd=[he cmd 0xA6FC 0x01 0xEF00 0x00 {000C1002000400000023} {}, delay 200])
dev:2542023-11-14 11:41:13.531debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {000C1002000400000023} {}, delay 200]
dev:2542023-11-14 11:41:13.406debugDressing TRV changing setpoint to 35.0
dev:2542023-11-14 11:41:13.397debugDressing TRV sendTuyaHeatingSetpoint(35.0)
dev:2542023-11-14 11:41:13.390debugDressing TRV setHeatingSetpoint temperature = 90 as int = 90 (previousSetpointt = 20.0)
dev:2542023-11-14 11:40:14.682infoDressing TRV temperature scale is: F (3281408)
dev:2542023-11-14 11:40:14.674debugDressing TRV dp_id=0 dp=23 fncmd=3281408
dev:2542023-11-14 11:40:14.487warnDressing TRV NOT PROCESSED Tuya cmd: dp=22 value=3281408 descMap.data = [00, 60, 16, 00, 00, 11, 06, 06, 00, 00, 32, 0C, 00, 00, 32, 12, 00, 00, 32, 16, 00, 00, 32]
dev:2542023-11-14 11:40:14.477debugDressing TRV dp_id=0 dp=22 fncmd=3281408
dev:2542023-11-14 11:40:14.301warnDressing TRV ignoring BatteryPercentageResult(6562816)
dev:2542023-11-14 11:40:14.293infoDressing TRV battery is: 3281408 % (dp=21)
dev:2542023-11-14 11:40:14.284debugDressing TRV dp_id=0 dp=21 fncmd=3281408
dev:2542023-11-14 11:40:14.095infoDressing TRV Dead Zone Temp (hysteresis) is: 3281408
dev:2542023-11-14 11:40:14.086debugDressing TRV dp_id=0 dp=20 fncmd=3281408
dev:2542023-11-14 11:40:13.925infoDressing TRV UNKNOWN Max Temp Limit is: 3281408 C (dp=19, fncmd=3281408)
dev:2542023-11-14 11:40:13.911debugDressing TRV dp_id=0 dp=19 fncmd=3281408
dev:2542023-11-14 11:40:13.751infoDressing TRV Max Temp Limit is: 3281408
dev:2542023-11-14 11:40:13.742debugDressing TRV dp_id=0 dp=18 fncmd=3281408
dev:2542023-11-14 11:40:13.720infoDressing TRV Set temperature F is: 3281408
dev:2542023-11-14 11:40:13.709debugDressing TRV dp_id=0 dp=17 fncmd=3281408
dev:2542023-11-14 11:40:13.344infoDressing TRV heatingSetpoint is: 20.0°C
dev:2542023-11-14 11:40:13.335debugDressing TRV dp_id=2 dp=16 fncmd=20
dev:2542023-11-14 11:40:13.211debugDressing TRV device has received Tuya cluster ZCL command 0x00 response 0x00 data = [00, 00]
dev:2542023-11-14 11:40:12.875debugDressing TRV sendZigbeeCommands(cmd=[he cmd 0xA6FC 0x01 0xEF00 0x00 {000B1002000400000014} {}, delay 200])
dev:2542023-11-14 11:40:12.864debugDressing TRV sendTuyaCommand = [he cmd 0xA6FC 0x01 0xEF00 0x00 {000B1002000400000014} {}, delay 200]
dev:2542023-11-14 11:40:12.778debugDressing TRV changing setpoint to 20.0
dev:2542023-11-14 11:40:12.768debugDressing TRV sendTuyaHeatingSetpoint(20.0)
dev:2542023-11-14 11:40:12.758debugDressing TRV setHeatingSetpoint temperature = 20 as int = 20 (previousSetpointt = 15.0)
