[RELEASE] Tuya TS0601 Soil Moisture Sensor Driver
New driver for Tuya TS0601 Soil Moisture sensor. This sensor can be found relatively at cheap prices on Amazon or AliExpress.
States
You can download the driver from:
Hello:
Recently purchase this device and am using your driver. Thank you for the driver
Unfortunately, cannot get Battery voltage, soil moisture and temperature to populate. They all state “unknown”. Not sure that illuminance is accurate either.
I initially paired the device at its outdoor location. Then re-paired it at the hub thinking that it may not have fully paired. No difference in performance.
Any ideas are appreciated.
Thank you George! I updated the driver for Manufacturer _TZE284_aao3yzhs, I updated the DPID mappings for soil moisture and temperature.
  • DP 5 is actually Temperature (not moisture).
  • DP 3 is actually Soil Moisture (not battery voltage).
https://github.com/RBILLC/Hubitat/blob/patch-1/Drivers/Tuya_TS0601_Soil_Sensor_Driver.groovy
