I've been working in the last 2 days on a new major update of this driver to allow easier configuration of the temperature and humidity reporting for these devices, that support such configuration. Sonoff SNZB-02 is one of the devices which follow the standard Zigbee specifications.
Once the reporting parameters for T&H are configured, click on the Save Preferences button. A new 'Current State' custom attribute will read * _info : Pending 1 (2) configurations. Wake up the device!
To configure a sleepy device, try any of the methods below :
- Rapidly change the temperature or the humidity
- Remove the battery for at least 1 minute
- Pair the device again to HE
If the reporting configuration was successful, the current states will display "configured"
Current States
- _info : configured
- humidity : 39
- temperature : 25.3
This test version 1.1.0 (EDIT: dev. branch version 1.1.x) can be manually downloaded from this temporary test URL : (EDIT:) Hubitat/Drivers/Tuya Temperature Humidity Illuminance LCD Display with a Clock/Tuya_Temperature_Humidity_Illuminance_LCD_Display_with_a_Clock.groovy at development · kkossev/Hubitat · GitHub
Please note, that it has been tested only with Sonoff SNZB-2 sensor. The new functionality will not work with most of the Tuya T/H sensors which use Tuya specific cluster.
