[RELEASE] Tuya Switch Module Driver
Split this out from the Lidl stuff which is made by Tuya but rebranded.
Installation
Search for the keyword "Tuya" on Hubitat Package Manager and you should see "Tuya Drivers from BirdsLikeWires". Requires HPM v1.8.7 or later. Or install manually from the link below.
The IKEA repeater is for scale, it snuck into the picture.
I've got the one, two and three-way versions and intend to update this driver once I've had chance to hook up my test setup again.
This driver has been updated to support the healthStatus custom attribute.
Use @kkossev's Device Health Status to give yourself a nice system overview.
Hi,
I just try to add the healtstatus capability to some drivers (hubitat) and I would like to know if the capability works on yours? I mean, can you use it as trigger with webcore or rule manager?
thanks
Yeah, it needs to be used as a custom attribute in Rule Machine, iirc.
Boop.
Hi there, did you manage to get this module working @birdslikewires. I'm struggling and curious which driver you ended up using? Any help would be appreciated and thanks in advance. See my post below.
Hmm, I have a couple in use which look identical to those (shown in the first post) but that's no guarantee they're the same inside, of course.
I'm still using my own driver for these, though if they're falling off the network that can point to an incompatibility with something else on your Zigbee mesh. I have had that issue with Xiaomi Aqara switches before.
Thanks for this. I'll continue with some more re-pairs. Kkossev has offered some pointers too :+1:
Booping for thread health.
Tuya time!
