alarm
Set the Alarm volume from the Preferences section and hit 'Save Preferences'
This is working on my tests.
What does not work is the complex 'dynamic' change of the volume from the command.
weird command says it worked but sound is same for low vs high with test with db meter on phone now.. and post results.. anyway working well enough to pack back up for when i go back to other house for a week nov 6th.. thanks again.
the problem prior was my first test was alway the play command that would freeze up the device so nothing ever worked.
This is an example of an overcomplicated driver...
I was trying to make a cheap $15 device to have the complex functions of the $80 Aeotec Siren 6 .. ![]()
YEP seems to be same volume for both low and high seems to be around 70 +/- db.
it does work but as you say the aeotec is better but 4x the price.
and this cost me a whole 19 dollars on ebay.
Hi KKossev i got one of these zigbee sirens
- manufacturer: _TZE204_hcxvyxa5
- model: TS0601
i could get the alarmt to sound only when setting the melody alarm 1
anything else on off does nothing for it. Do you know what could be the problem?
Hi,
This is a new manufacturer - can you post the link to the site where you purchased it?
Please update the driver manually to the new version 1.3.3 2024-11-20 and let me know it it works.
@Rxich How is the solar siren working for you? Would you recommend this or not for Hubitat?
Thank you very much ![]()
Hello Mate, Thanks to @kkossev the siren is working fine. I do find the device itself seems not to execute commands instantly, but it takes between 2-3 seconds to respond. The siren has been on my C7 mesh for about 2 months. During that time the 16 bit address has remained the same from initial pairing, which I think is a good sign
I should mention the siren is located about 4 foot from my C7 hub, next to my desk. The only quirk is the solar charging indicator, under "Current States" never says charging even when I put the siren in full sun. With the included 18650 battery it could easily last a year or more without a charge, provided the alarm is not sounding for long periods, and probably even longer if the solar panel actually works. I can't confirm the solar panel works.
And with Tuya you may or may not get the same version as I received, but the link to the model I bought is above in post 114, not a guarantee but a higher chance of getting the same firmware version I received.
Good luck!
Hi, I've installed my new Tuya Outdoor Siren, but I'm not able to activate the strobe light only. It's turning on both the siren and strobe. I'm running driver version 1.3.3 2024/11/20 8:12 AM. Any help would be appreciated.
Manufacturer _TZE284_nlrfgpny
Model TS0601
This is a new device manufacturer, now included in ver. 1.3.4 2025-02-22 .
The update is also pushed via HPM.
Just stopping by to say thank you for providing this driver!
Using this device as a portable doorbell chime for when we're out on the deck or the patio!
Any chance adding this to You're driver: Immax NEO Smart Siren Zigbee 3.0 driver - #5 by kkossev
Tuya is a developer of chips, but they do not make any devices. Many manufacturers use Tuya chips in their devices. In fact, the chips might power different types of sensors. As long as the device driver supports the Tuya chip and device type, the manufacturer should make no difference.
Thanks! Tried driver, everything seems okay, but testing sounds, nothing comes out. With Frient driver, it works, but sound level is not changeable. Hoped with Tuya driver this feature might work and will get full volume on my siren.
